DELTA2A/X/SMAM/S/RA/11
    SIRETTA
DELTA2A/X/SMAM/S/RA/11 数据手册
Delta 2A Quad Band GSM, 3G & ISM Stubby Antenna Key Features • • • • Small size Quad band GSM and 3G ISM: 868 and 915MHz Groundplane independent General Description Additional Considerations The Delta 2A Multiband antenna combines good performance with a small size, enabling its use with many of today’s GSM / GPRS, 3G and ISM products. • Suitable for GSM / GPRS and 3G terminal equipment • Meets all EU compliance criteria for electronic goods The omni directional, radiating element is over moulded in black high-grade rubber, which allows flexibility and provides a rugged stylish finish. Terminated with an SMA male or SMA RP right angle connector, it is suited to applications like Point of Sale terminals, metering or alarm panel equipment. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 2.0 Delta 2A Quad Band GSM, 3G & ISM Stubby Antenna Electrical Specifications Mechanical Specifications Operating Temperature range: -20 - +60°C Storage Temperature range: -30 - +75°C Impedance: VSWR: Gain: Operating Frequencies: Radiation: Polarization: Dimensions: L53.5mm Connector: 50 Ohm 2.0 Right angle SMA male, SMA RP Mounting Method: Direct connect Connector plating: Gold/Nickel 2.0 dBi GSM: 800, 900, 1800, 1900MHz 3G: 2100MHz ISM: 868, 915MHz Omni Directional Vertical Unit = mm Return Loss Registered in England No. 08405712 VAT Registration No. GB163 04 0349 VSWR Frequency dB 797.9 MHz 1.752 931.5 MHz 2.271 1763 MHz 2.012 1874 MHz 1.937 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 2.0 Delta 2A Quad Band GSM, 3G & ISM Stubby Antenna Radiation Plots 836.5MHz 897.4 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 2.0 Delta 2A Quad Band GSM, 3G & ISM Stubby Antenna 1747.4 MHz 1868 MHz Ordering Details Part number Description DELTA2A/X/SMAM/S/RA/11 Quad Band GSM/GPRS 3G & ISM Antenna SMA Male Right Angle Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 2.0
DELTA2A/X/SMAM/S/RA/11 价格&库存
很抱歉,暂时无法提供与“DELTA2A/X/SMAM/S/RA/11”相匹配的价格&库存,您可以联系我们找货
