ANT-2.4-PML-UFL
ANT-2.4-PML-UFL
    LINXTECHNOLOGIES(灵思)
    ANT-2.4-PML-UFL
ANT-2.4-PML-UFL 数据手册
ANT-2.4-PML-xxx Data Sheet by Product Description 8.2 mm (0.32") Designed for permanent attachment, the PML ½-wave whip tilts 180 degrees and delivers outstanding performance in a cost-effective package. An internal counterpoise eliminates external ground plane dependence and maximizes performance. The antenna is attached by placing its base through a ¼" (6.35 mm) hole in the product and securing it with a nut or by threading it into a PEM-style insert. This method of attachment is highly secure and saves the cost of an antenna connector. The PML attaches to a PCB or connector via 12" (30.48 cm) of RG-178 coax cable. It is also available with 1.32 mm coax cable terminated with a U.FL/MHF compatible connector. This saves the labor of adding a connector while using one that is small enough to fit through the antenna’s mounting hole. Custom lengths and terminations are available by special order. 12.1 mm (0.48") Available with Straight Cut Cable or U.FL Connector 123.0 mm (4.84") 150.3 mm (5.92") I-PEX silhouette shown in shadow 7.9 mm (0.31") Features • • • • • • • 35.2 mm (1.39") Cost-effective Internal counterpoise Tilts 180 degrees Outstanding performance Omni-directional pattern Low VSWR Integral 12" (30.48 cm) RG-178 coax cable or 1.32 mm coax (U.FL) 6.0 mm (0.24") Electrical Specifications Center Frequency: Recom. Freq. Range: Wavelength: VSWR: Impedance: Connection: Cable: Oper. Temp. Range: Ordering Information 2.45GHz 2.35-2.60GHz ½-wave ≤1.9 typical at center 50-ohms Straight-cut or U.FL/MHF 12" (30.48 cm) RG-178 coax or 1.32 mm coax (U.FL) –40°C to +90°C ANT-2.4-PML (with straight cut RG-178 coax) ANT-2.4-PML-UFL (with U.FL/MHF compatible connector and 1.32mm coax) Electrical specifications and plots measured on 10.16 cm x 10.16 cm (4.00" x 4.00") reference ground plane –1– Revised 5/1/15 VSWR Graph VSWR Reflected Power 1.227 3:1 25% 2:1 11% 1:1 2.30GHz 0% 2.60GHz 2.45GHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. –2– Data Sheet ANT-2.4-PML-xxx by
ANT-2.4-PML-UFL 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-PML-UFL”相匹配的价格&库存,您可以联系我们找货
