ANT5320LL24R2455A
ANT5320LL24R2455A
    YAGEO(国巨)
    SMD-3P,5.3x2mm
    ANT5320LL24R2455A
ANT5320LL24R2455A 数据手册
DATA SHEET WIRELESS COMPONENTS Ceramic Chip Antenna ANT5320LL24R2455A 2.4 AND 5 GHZ Product Specification – May 8, 2014 V.0 5320 Series Product specification WIRELESS COMPONENTS FEATURES  Compact size  Omni-directional radiation  Dual-band design  Tape & reel automatic mounting  Reflow process compatible  RoHS compliant Ceramic Chip Antenna 2 7 ORDERING INFORMATION All part numbers are identified by the series, packing type, material, size, antenna type, working frequency and packing quantity. PART NUMBER ANT 5320 L L24 R 2455A (1) (2) (3) (4) (5) (6) (1) PRODUCT APPLICATIONS  2.4 & 5 GHz WiFi device  ISM band equipment ANT = Antenna (2) SIZE 5320 = 5.3 × 2.0 (3) ANTENNA TYPE L,F,A = Chip Antenna (4) SERIAL NO. L24 (5) PACKING STYLE R = Tape and Reel (6) WORKING FREQUENCY 2455 = 2.45/ 5 GHz PHYCOMP CTC CAN4311753242522K 12NC 431175324252 www.yageo.com May. 8, 2014 V.0 Product specification WIRELESS COMPONENTS Ceramic Chip Antenna 3 7 SPECIFICATION Table 1 VALUE DESCRIPTION Centre Frequency 2.45/ 5 GHz Bandwidth 120M / 900 MHz (min) Return Loss 10 dB min Polarization Linear Azimuth Beamwidth Omni-directional Peak Gain 2.17 / 3.51 dBi ( Typ. ) Impedance 50 Ω Operating Temperature -40~105 degree Maximum Power 1W Termination Ag (Environmentally-Friendly Leadless) Resistance to Soldering Heats 260℃ , 10sec. NOTE 1. The specification is defined on Yageo evaluation board DIMENSIONS Table 2 Machinical Dimension DIMENSION L (mm) 5.30 ± 0.10 W (mm) 2.00 ± 0.10 T (mm) 1.15 ± 0.10 A (mm) 0.80 ± 0.10 B (mm) 0.80 ± 0.10 C (mm) 0.50 ± 0.10 D (mm) 2.40 ± 0.10 OUTLINES Table 3 Termination configuration TERMINAL NAME FUNCTION S1 Feeding Point S2 Soldering Point S3 GND Fig. 1 Antenna outlines www.yageo.com May. 8, 2014 V.0 Product specification WIRELESS COMPONENTS Ceramic Chip Antenna 4 7 REFERENCE DESIGN OF EVALUATION BOARD Fig. 3 Outlook and dimension of evaluation board Fig. 4 Details of soldering pad www.yageo.com May. 8, 2014 V.0 Product specification WIRELESS COMPONENTS Ceramic Chip Antenna 5 7 ELECTRICAL PERFORMANCES Marker data 1. 2. 3. 4. 5. 6. 2.38GHz , -10dB 2.45GHz , -16.2dB 2.50GHz , -10dB 4.95GHz , -10dB 5.47GHz , -16.8dB 5.85GHz , -18.2dB Fig. 5 Return loss www.yageo.com May. 8, 2014 V.0 Product specification WIRELESS COMPONENTS 6 7 Ceramic Chip Antenna Frequency= 2.45 GHz Max gain = 2.17 dBi MEG (mean effective gain)= -1.23 dBi Directivity (dB) = 3.48 Efficiency = -1.31dB, 73.98 % Evaluation board and XYZ direction Frequency= 5.47 GHz Max gain = 3.51 dBi MEG (mean effective gain)= -2.68 dBi Directivity (dB) = 4.95 Efficiency = -1.44dB, 71.82 % Fig. 6 Radiation pattern www.yageo.com May. 8, 2014 V.0 Product specification WIRELESS COMPONENTS 7 7 Ceramic Chip Antenna REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version 0 - Jan. 30, 2013 DESCRIPTION - New data sheet for SMD type antenna, 2.4 / 5GHz application, 5320 series PIFA mode www.yageo.com May. 8, 2014 V.0
ANT5320LL24R2455A 价格&库存
很抱歉,暂时无法提供与“ANT5320LL24R2455A”相匹配的价格&库存,您可以联系我们找货
