Latona Antenna for LP-WAN applications
Part No. SR4C033-L SR4C033-R
1.
lamiiANT ®
Product Specification
Features
2.
Antenna for LP-WAN applications. Including NB-IOT, LoRa, SigFox, ISM and
Weightless-P
Frequency bands from 791- 960MHz
Maintains high performance on device: DFI (Designed for Integration)
Corner placement to save space
Low profile innovative design.
SMD mounting
Supplied on Tape and Reel
Automotive temperature rating.
Description
Latona uses a ground plane on the host PCB to radiate effectively. The antenna
itself requires a clearance underneath. An external matching circuit is used to
optimise the antenna within a device to the required bands. Designed specifically for
LP-WAN applications that require a small robust solution. Latona comes in Left and
Right hand versions to optimise placement.
3.
Applications
Remote monitoring/ Smart meters
Network Devices
Smart Buildings
Smart cities
Manufacturing automation
Agriculture/Environment
Consumer tracking
Antennas for Wireless M2M Applications
Product Specification SR4C033-PS-1.0
Page 1
Latona
Part No. SR4C033
4.
Part Number
Latona Left: SR4C033-L
Latona Right: SR4C033-R
5.
General Data
Product name
Latona
Part Number
SR4C033
Frequency
791 – 960MHz
Polarization
Linear
Operating temperature
-40°C to140°C
Environmental Condition Test
ISO16750-4 5.1.1.1/5.1.2.1/5.3.2
Impedance with matching
50 Ω
Weight
< 2g
Antenna type
SMD
Dimensions
20.0 x 11.0 x 1.6 (mm)
6.
RF Characteristics
791 – 862 MHz
0.5dBi
824 – 960 MHz
0.8dBi
-1.50dBi
-1.50dBi
Average efficiency
>60%
>65%
Maximum return loss
-9dB
-7dB
Maximum VSWR
2.1:1
2.6:1
Peak gain
Average gain (Linear)
All data measured on Antenova’s evaluation PCB
Part No. SR4C033-EVB-1
Page 2
Latona
Part No. SR4C033
7.
RF Performance
The performance is shown for two tuned variants (Tuning dependant on required
band). Matching circuit is used for band selection.
B20: 791 – 862MHz
B5 and B8: 824-894MHz; 880- 960MHz
7.1 Return Loss
7.2 VSWR
Page 3
Latona
Part No. SR4C033
7.3 Antenna pattern
7.3.1
791 – 862 MHz
3D pattern at 830 MHz
Drag to rotate pattern and PCB by using Adobe Reader
(Click to Activate)
Page 4
Latona
Part No. SR4C033
7.3.2
824 – 960 MHz
3D pattern at 880 MHz
(Click to Activate)
Page 5
Latona
Part No. SR4C033
8.
Antenna Dimensions
Top side
L
W
H
Length
Width
Height
20.0 ±0.1
11.0 ±0.1
1.6 ±0.1
All Dimensions in (mm)
Bottom Side
9
8
7
6
6
6
3
4
1
2
6
5
6
5
7
8
9
6
6
6
4
3
2
1
Page 6
Latona
Part No. SR4C033
9.0 Schematic symbol and Pin definition
The circuit symbol for the antenna is shown below. The antenna has 9 pins with only
two as functional. All other pins are for mechanical strength.
Pin
Description
2
Feed
1
Band Select (B.SEL)
3,4,5,6,7,8,9
Not used (Mechanical only)
10.0 Antenna footprint
The recommended host PCB footprint is below.
9 copper pads all 1.8 x 1.3 (mm)
All Dimensions in mm
Page 7
Latona
Part No. SR4C033
11. Electrical Interface
11.1 Transmission Line
All transmission lines should be designed to have a characteristic impedance of 50Ω.
• The length of the transmission lines should be kept to a minimum.
• Any other parts of the RF system like transceivers, power amplifiers, etc, should also
be designed to have an impedance of 50 Ω.
Once the material for the PCB has been chosen (PCB thickness and dielectric constant),
a coplanar transmission line can easily be designed using any of the commercial
software packages for transmission line design. For the chosen PCB thickness, copper
thickness and substrate dielectric constant, the program will calculate the appropriate
transmission line width and gaps on either side of the track so the characteristic
impedance of the co-planar transmission is 50 Ω.
11.2 Matching Circuit
The antenna requires a matching circuit that must be optimized for each product. The
matching circuit will require up to five components and the following circuit should be
designed into the host PCB. Not all components may be required but should be included
as a precaution. The matching network must be placed close to the antenna feed to
ensure it is more effective in tuning the antenna.
Page 8
Latona
Part No. SR4C033
12.0 Antenna Integration Guide
12.1 Antenna Placement
Whatever the size of the host PCB, the antenna should ideally be placed on the host
PCB’s shortest side, in the corner. The left / right antennas are placed in the
corresponding corner of the PCB: SR4C033-L (Left Corner) and SR4C033-R (Right
Corner).
12.2 Host PCB Layout
The footprint and clearance on the host PCB must meet the antenna specification. An
example of the PCB layout shows the antenna footprint with clearance. The feed (Pin 2)
connects to the matching circuit close to the antenna. For Pin 1 (B.SEL) the component
should be close to this pin.
Example host layout
1
Page 9
Latona
Part No. SR4C033
12.3 Host PCB Clearance
Below shows the antenna footprint and clearance through all layers on the PCB. Only
the antenna pads and connections to feed and GND are present within this clearance
area. The clearance area required is 20.0 x 11.0 (mm).
The clear-out area is simply defined as the same size as the antenna. No additional
clearance is required.
Clearance area
Page 10
Latona
Part No. SR4C033
13.0 Reference Board
The reference board has been designed for evaluation purposes of SR4C033 antenna and
includes a SMA female connector.
SR4C033-EVB-1 Evaluation Board
(For SR4C033-R)
SR4C033-EVB-2 Evaluation Board
(For SR4C033-L)
To order a reference board contact sales@antenova-m2m.com.
Please state if Left or Right version.
SR4C033-EVB-1 = SR4C033-R (Right)
SR4C033-EVB-2 = SR4C033-L (Left)
Page 11
Latona
Part No. SR4C033
13.1 Reference Board Matching Circuit
The reference board has been designed for evaluation purposes of SR4C033-L and
SR4C033-R and includes a SMA female connector.
Designator
Type
L1
Inductor
L2
Not Fitted
Value
33nH
Description
Murata LQG15HN series
Not Fitted
Not Fitted
C1
Not Fitted
Not Fitted
Not Fitted
C2
Capacitor
0.5pF
Murata GRM15 series
B.SEL (Band Selection pin component)
Frequency band
B20
Designator
Type
Inductor
Value
6.8nH
Description
Murata LQG15 series
L3
B5, B8
L3
Inductor
3.3nH
Murata LQG15 series
Band 20 = 791-862MHz
Band 5 = 880-960MHz
Band 8 = 824-894MHz
Page 12
Latona
Part No. SR4C033
14. Soldering
This antenna is suitable for lead free soldering.
The reflow profile should be adjusted to suit the device, oven and solder paste, while
observing the following conditions:
The maximum temperature should not exceed 240 ºC
However for lead free soldering, a maximum temperature of 255 ºC for no more
than 20 seconds is permitted.
The antenna should not be exposed to temperatures exceeding 120 ºC more
than 3 times during the soldering process.
15. Hazardous Material Regulation Conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova M2M’s website.
16. Packaging
16.1 Optimal Storage Conditions
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf life
24 Months
Storage place
Away from corrosive gas and direct sunlight
Reels should be stored in unopened sealed
manufacturer’s plastic packaging.
Packaging
Note: Storage of open reels of antennas is not recommended due to possible oxidization
of pads on antennas. If short term storage is necessary, then it is highly recommended
that the bag containing the antenna reel is re-sealed and stored in like storage conditions
as in above table.
Page 13
Latona
Part No. SR4C033
16.2 Tape Characteristics
Ko
Ao
Bo
2.80
11.40 ± 0.1
P0
20.40 ± 0.1
P1
4.00 ± 0.1
16.00 ± 0.1
E1
F
W
1.75 ± 0.1
14.2 ± 0.15
32.00 ± 0.3
P2
2.00 ± 0.1
Dimensions in mm
Notes:
1) 10 sprocket hole pitch cumulative tolerance ±0.2mm.
2) Camber not to exceed 1mm in 100mm.
3) Ao and Bo measured on a plane 0.1mm above the bottom of the packet.
4) Ko measured from a plane on the inside bottom of the packet to the top surface carrier.
Page 14
Latona
Part No. SR4C033
16.3 Reel Dimensions
A
330.0 ± 2.0
C
13.0 ± 0.5
N
W1
80.0 ± 0.2
44.4 ± 0.3
All dimensions in mm
Page 15
Latona
Part No. SR4C033
16.4 Box Dimensions
Width
(W)
350mm
Breadth Thickness
(B)
(H)
355mm
70mm
16.5 Bag Properties
Reels are supplied in protective plastic packaging.
16.6 Reel Label Information
Antenova Limited
4F, No 324, Sec 1, Nei-Hu Road
Nei-Hu District, Taipei 11493, Taiwan, ROC
60mm
info@antenova-m2m.com / www.antenova-m2m.com
Description: Latona
Part number: SR4C033-R
Quantity: 1,000
Date Code: YYWW
Manufacturer’s code number:
lamiiANT
90mm
Page 16
Latona
Part No. SR4C033
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Limited
nd
2 Floor Titan Court
3 Bishop Square
Hatfield
AL10 9NA
UK
Antenova Limited
100 Brush Creek Road
Suite 103, Santa Rosa
California 95404,
USA
Antenova Asia Limited
4F, No. 324, Sec. 1, Nei-Hu Road
Nei-Hu District
Taipei 11493
Taiwan, ROC
Tel: +44 1223 810600
Email: sales@antenova-m2m.com
Tel: +1 707 890 5202
Tel: +886 (0) 2 8797 8630
Fax: +886 (0) 2 8797 6890
Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ® , the Antenova
product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks
of Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within this
information. Antenova further assumes no responsibility for the use of this information, and all such information
shall be entirely at the user’s risk.
Product Specification SR4C033-PS-1.0 Released March 2017
Page 17
很抱歉,暂时无法提供与“SR4C033-L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+22.682681+2.93435
- 10+16.8332210+2.17764
- 25+15.3734125+1.98879
- 100+13.77591100+1.78213
- 250+13.01318250+1.68346
- 500+12.56036500+1.62488
- 国内价格 香港价格
- 1000+12.174871000+1.57501
- 2000+11.863412000+1.53472
- 3000+11.707403000+1.51453
- 5000+11.534595000+1.49218
- 7000+11.433627000+1.47912
