1001013
1001013
    ETHERTRONICS
    ANT WLAN 802.11BG 2.4GHZ PCB SMT
1001013 数据手册
PRODUCT BRIEF: Embedded 2.4GHz Antenna Part No. 1001013 PresttaTM WLAN b/g/n Embedded Antenna 2.4GHz KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) embedded antennas address the challenges facing today’s product designers. IMD’s high performance and isolation characteristics offer better connectivity and minimal interference. Prestta antennas can be used in a variety of applications including:        Handsets Tablets M2M Automatic Meter Reading Healthcare Point of Sale Tracking TECHNOLOGY ADVANTAGES Stays in Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Ethertronics IMD antennas resist de-tuning; providing a robust radio link regardless of the usage position. Prestta antennas use patented IMD technology in a stamped metal configuration to provide high performance. IMD antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-to-market, without sacrificing RF performance. Reduced Costs and Time-to-Market  Standard antenna eliminates design fees and cycle time associated with a custom solution; getting products to market faster. Greater Flexibility with Unique Form Factors  Ethertronics’ IMD technology helps you deliver more advanced ergonomic designs without adverse impact on product performance.  SMD mountable design enables faster and lower cost manufacturing. RoHS Compliant  Ethertronics’ antennas are fully compliant with the European RoHS Directive 2002/95/EC. END USER ADVANTAGES Unique Form Factors Support Advanced Industrial Designs  Smaller, more efficient IMD embedded antennas break through restrictive design rules and provide new freedom in component placement. Superior Range  Better antenna function means longer range and greater sensitivity to critically precise signals—delivering greater customer satisfaction while building brand loyalty. SERVICE AND SUPPORT Extensive RF Experience  Our Prestta antennas are supported by documentation, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support  Ethertronics’ global operations supports an integrated network of design centers that can take projects from concept to production. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Embedded 2.4GHz Antenna - P/N 1001013 Example: Ethertronics’ BT & WLAN Internal (Embedded) Antenna Specifications. Below are the typical performances. Electrical Specifications Measurements taken on a 50 x 70 mm ground plane. 2400-2485 MHz WiFi Antenna (MHz) Typical Characteristics Peak Gain Average Efficiency VSWR Match Feed Point Impedance Power Handling On Ground (no clearance) 0.7 dBi Off Ground (with 4mm clearance) 1.2dBi 48% 63% 1.3:1 max 1.09:1 max 50 ohms unbalanced (other if required) 2 Watt CW Polarization Mechanical Specifications Linear Maximum Dimensions 15.0x3.2x3.3mm Mechanical Mounting Antenna Assembly is Surface Mounted onto main PCB. RF Mounting RF and Ground feed pads are Surface Mounted onto main PCB. P/N 1001013 performances on ground Typical Efficiency Typical Return Loss Antenna Radiation Patterns Typical Performance (2450MHz) ETHERTRONICS P/N 1001013 performances with 4mm ground clearance Typical Efficiency Typical Return Loss Antenna Radiation Patterns Typical Performance (2450MHz) Antenna Layout © 2013 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. 1001013 12Oct2015
1001013 价格&库存
很抱歉,暂时无法提供与“1001013”相匹配的价格&库存,您可以联系我们找货
