HLA.01
HLA.01
    TAOGLASLIMITED
    HLA.01
HLA.01 数据手册
SPECIFICATION Part No. : HLA.01 Product Name : 5150-5900 MHz Ceramic Loop antenna WLAN/ Wi-Fi/ HDMI Feature : 3.2mm *1.6mm * 0.5mm Low profile Peak gain 2.1dBi 65%+ Efficiency Typical Compact Size RoHS Compliant HLAD.01 EVB Board Bottom Top SPE-12-8-116/B/SS Page 1 of 19 1. Introduction The HLA.01 5150-5900 MHz ceramic chip antenna is specifically designed for Wi-Fi/ WHDMI applications where high data throughput is needed. It is a high efficiency miniature SMD edge mounted ceramic antenna with minimum footprint requirement. This ceramic chip antenna uses the main PCB as its ground plane, thereby increasing antenna efficiency. It is tuned for different PCB sizes by simply changing the value of the matching circuit. The HLA.01 with dimension of 3.2mm *1.6mm * 0.5mm, is one of the smallest antennas available worldwide. This antenna is delivered on tape and reel. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain SPE-12-8-116/B/SS Page 2 of 19 of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. Applications IEEE802.11a (5150-5900 MHz) WHDMI PCMCIA cards or Wireless USB dongles 2. Specification Table Electrical Center Frequency (MHz) 5500 SPE-12-8-116/B/SS Page 3 of 19 Bandwidth (MHz) 524 Peak Gain (dBi) 2.1 (typical) Efficiency (%) 65 (typical) VSWR 2 max. Impedance (Ω) 50 Polarization Linear Radiation Pattern Omni Input Power(W) 50 MECHANICAL Dimensions (mm) 3.2 x 1.6 x 0.5 Ground plane (mm) 80x40 Material AS 6 ENVIRONMENTAL Temperature Range Temperature Coefficient of Frequency (ppm/°C) Humidity -40°C to 85°C 0±20 max. (@-40°C to 85°C) Non-condensing 65°C 95% RH SPE-12-8-116/B/SS Page 4 of 19 3. Return Loss SPE-12-8-116/B/SS Page 5 of 19 4. Smith Chart SPE-12-8-116/B/SS Page 6 of 19 5. Efficiency SPE-12-8-116/B/SS Page 7 of 19 6. Antenna Radiation Patterns Y X Z 6.1 3D Gain pattern @ 5150 MHz SPE-12-8-116/B/SS Page 8 of 19 SPE-12-8-116/B/SS Page 9 of 19 6.2 3D Gain pattern @ 5350 MHz SPE-12-8-116/B/SS Page 10 of 19 6.3 3D Gain pattern @ 5700 MHz SPE-12-8-116/B/SS Page 11 of 19 SPE-12-8-116/B/SS Page 12 of 19 6.4 3D Gain pattern @ 5850 MHz SPE-12-8-116/B/SS Page 13 of 19 SPE-12-8-116/B/SS Page 14 of 19 7. Mechanical Drawing SPE-12-8-116/B/SS Page 15 of 19 8. Layout Guide Solder Land Pattern: SPE-12-8-116/B/SS Page 16 of 19 9. Frequency tuning Antenna tuning scenario: Matching circuit: (Center frequency is 5500MHz at 80x40mm ground plane) SPE-12-8-116/B/SS Page 17 of 19 10. Soldering Conditions Typical Soldering profile for lead-free process: SPE-12-8-116/B/SS Page 18 of 19 11. Packing Quantity: 6000pcs/ Reel Plastic tape: Tape Dimensions (unit: mm) Feature Specification Tolerance W 12.00 ±0.30 P 8.00 ±0.10 E 1.75 ±0.10 F 5.50 ±0.10 Feature Specification Tolerance P2 2.00 ±0.10 Ao 1.90 +0.20 D 1.50 +0.10 / -0.00 Bo 3.50 -0.10 D1 - ±0.10 Ko 0.60 ±0.05 Po 4.00 ±0.10 t 0.30 ±0.05 10Po 40.00 ±0.20 Pocket Dimensions (unit: mm) 1. Cumulative tolerance of 10 pocket hole pitch: ±0.20mm 2. Carrier camber not to exceed 1mm in 250mm 3. Ao and Bo measured on a plane above the inside bottom of the pocket 4. Ko measured from a plane on the inside bottom of the pocket to the top surface of the carrier 5. All dimensions meet EIA-481-B requirements 6. Material – Clear non Anti-Static Polystyrene, Black Conductive Polystyrene SPE-12-8-116/B/SS Page 19 of 19
HLA.01 价格&库存
很抱歉,暂时无法提供与“HLA.01”相匹配的价格&库存,您可以联系我们找货
