Part No:
PCS.07.A
Description:
Low Profile Cellular SMD Dielectric Antenna
824~960MHz/1710~2170MHz
Features:
High Efficiency Multi-Band SMD antenna
Low profile 35mm * 7mm * 3mm
CE Certified
RoHS & Reach Compliant
SPE-13-8-028-E
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
8
5.
Mechanical Drawing
10
6.
Evaluation Board Drawing
11
7.
Footprint
12
8.
Matching Circuit
13
9.
Solder Reflow Recommendations
14
10. Packaging
15
11. Application Note
17
Changelog
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-13-8-028-E
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
is a low profile SMT cellular antenna designed for direct SMT mount on the device PCB. It provides
1.The PCS.07.A
Introduction
highest efficiency in very small factor 35*7*3mm. It is more resistant to detuning compared to other antenna
integrations. If tuning is required it can be tuned for the device environment, while there is no need for new
tooling. Its rectangular shape and very small size makes it very easy to integrate – can be mounted directly on
the edge of the PCB board.
1.
Introduction
The PCS.07 antenna is suitable for lower cost cellular applications and is especially suitable for telematics and
automotive sector. If higher efficiency or improved radiated spurious emissions are required, especially on
smaller ground-planes, please use our PA series antennas, PA.26 or PA.710. For further information, please
contact your regional Taoglas customer support team.
1.
Introduction
1.
Introduction
SPE-13-8-028-E
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Frequency (MHz)
824~896
Specifications
Cellular
880~960
1710~1880
1850~1990
1920~2170
2.90
2.83
2.57
-2.50
-2.68
-2.42
45.14
52.82
50.11
< -5
< -7
< -6
Peak Gain (dBi)
3.
Antenna
Characteristics
On EVB
-1.96
-1.77
Average Gain (dB)
On EVB
4.
-4.68
-4.44
Efficiency (%)
Antenna Radiation Patterns3.
Antenna
On EVB
Characteristics2.
On EVB
32.02
31.06
Specifications
Return Loss (dB)
< -3
< -4
Impedance
3.
50Ω
Antenna
Polarization Characteristics2.
Specifications
Linear
Radiation Pattern
Omni
Mechanical
3.
4.
Antenna Dimensions
35mm x 7mm x 3mm
Material
Polymer
Soldering Type
SMT through Reflow
Antenna
Environmental
Temperature Range
-40°C to 85°C
Moisture Sensitivity Level (MSL)
3 (168 Hours)
Characteristics
4.
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-13-8-028-E
Specifications
www.taoglas.com
4
5G/4G Bands
Band Number
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746
18
UL: 815 to 830
DL: 860 to 875
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200
24
UL:1625.5 to 1660.5
DL: 1525 to 1559
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869
28
UL: 703 to 748
DL: 758 to 803
29
UL: -
DL: 717 to 728
30
UL: 2305 to 2315
DL: 2350 to 2360
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5
32
UL: -
DL: 1452 – 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
48
3550 to 3700
66
UL: 1710-1780
DL: 2110-2200
71
617 to 698
74/75/76
1427 to 1518
77
3300 to 4200
78
3300 to 3800
79
4400 to 5000
SPE-13-8-028-E
Covered
www.taoglas.com
5
3.
4.
3.1
Return Loss
Characteristics
-2
-4
-6
4.
(dB)
-8
4.
-10
-12
Antenna
-14
Characteristics
-16
Return
Loss
-18
-20
Antenna
Patterns3.
800 Radiation
1000
1200
1400 Antenna
1600
4.
1800
2000
2200 (MHz)
Characteristics
3.2
Efficiency
100
4.
4.
4.
Efficiency (%)
80
60
40
Antenna
Radiation Patterns
Efficiency
Characteristics
4.
1000
1500
SPE-13-8-028-E
2000
2500(MHz)
www.taoglas.com
6
3.3
Average Gain
Average Gain (dB)
-2
-4
-6
-8
-10
Average
Gain
-12
500
3.4
1000
1500
2000
2500 (MHz)
Peak Gain
6
Maximum Gain (dBi)
4
2
-4
-6
Maximum
Gain
-8
-10
500
SPE-13-8-028-E
1000
1500
2000
2500 (MHz)
www.taoglas.com
7
4.
Radiation Patterns
4.
4.
4.
4.1
Test Setup on Evaluation Board
Y
4.
X
Z
4.
4.
4.
4.
SPE-13-8-028-E
www.taoglas.com
8
4.2
2D Radiation Patterns
824-960MHz
XZ Plane
YZ Plane
XY Plane
1710-2170MHz
XY Plane
SPE-13-8-028-E
XZ Plane
YZ Plane
www.taoglas.com
9
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-028-E
Mechanical Drawing
www.taoglas.com
10
6.
Evaluation Board Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-028-E
Mechanical Drawing
www.taoglas.com
11
7.
Footprint
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-13-8-028-E
www.taoglas.com
12
8.
Matching Circuit
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-13-8-028-E
www.taoglas.com
13
9.
The PCS.07.A can be assembled by following the recommended soldering temperatures are as follows:
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
6.
Packaging
Mechanical Drawing
*Temperatures listed within a tolerance of +/- 10º C
is not limited
to the number
of passes through the reflow process. Smaller components
7.The PCS.07.A
Application
Note6.
Packaging
are typically mounted on the first pass, however, we do advise mounting the PCS.07.A when placing
larger components on the board during subsequent reflows.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-028-E
Mechanical Drawing
www.taoglas.com
14
8. Packaging
10.
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-028-E
Mechanical Drawing
www.taoglas.com
15
SPE-13-8-028-E
www.taoglas.com
16
Investigations of PCS.07.A antenna performance on different lengths of ground plane were conducted,
the results are shown below.
4.
11.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
11.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-13-8-028-E
www.taoglas.com
17
11.3
Peak Gain
11.4
Average Gain
SPE-13-8-028-E
www.taoglas.com
18
Changelog for the datasheet
SPE-13-8-042 – PCS.07.A
Revision: F (Current Version)
Date:
Changes:
Changes Made by:
2021-09-09
Solder Reflow Recommendations Amended.
Gary West
Previous Revisions
Revision: E
Date:
Changes:
Changes Made by:
2021-09-09
Added MSL rating, updated font.
Erik Landi
Revision: D
Date:
Changes:
Changes Made by:
2020-12-01
Updated Format and Drawing
Jack Conroy
Revision: C
Date:
Changes:
Changes Made by:
2018-10-23
Updated Drawing
David Connolly
Revision: B
Date:
Changes:
Changes Made by:
2013-08-11
Drawing Updated
Aine Doyle
Revision: A (Original First Release)
Date:
Notes:
2013-04-11
Author:
Wayne Yang
SPE-13-8-028-E
www.taoglas.com
19
www.taoglas.com
SPE-13-8-028-E
© Taoglas 20
www.taoglas.com
很抱歉,暂时无法提供与“PCS.07.A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 54+13.79866
- 270+12.40921
- 国内价格 香港价格
- 1000+13.437441000+1.74647
- 2000+12.925592000+1.67994
- 3000+12.640003000+1.64282
- 5000+12.294075000+1.59786
- 7000+12.074437000+1.56932
- 国内价格 香港价格
- 1+23.117661+3.00460
- 10+19.9023110+2.58670
- 25+18.8013725+2.44361
- 100+17.28139100+2.24606
- 250+16.36970250+2.12757
- 500+15.72515500+2.04380
