Table of contents
INDEX
Subject
Page
ORDERING CODE…………………………....…………………………………………………………………………………..……………1~5
CHIP ANTENNA…………………………....…………………………………………………………………………………………………… 5~12
■ 1.575GHz GPS BAND WORKING FREQUENCY
■ Bluetooth/WiFi BAND WORKING FREQUENCY
■ WiMAX BAND WORKING FREQUENCY
■ UHF BAND WORKING FREQUENCY
HIGH FREQUENCY MULTILAYER BAND PASS FILTER………………………………………………………………………..………13~29
■ 2.4GHz BAND WORKING FREQUENCY
■ 5GHz BAND WORKING FREQUENCY
■ 1558 ~ 1606 MHz GNSS Band Applications
■ 860~960MHz/1805~2025 MHz Band Application
■ MoCA / Docsis Application
■ LTE BAND Application
HIGH FREQUENCY MULTILAYER BALANCED FILTER……………………………………………………………………..…………30~33
HIGH FREQUENCY MULTILAYER LOW PASS FILTER………………………………………………………………………..…………34~43
■ GSM850/900GHz BAND WORKING FREQUENCY
■ DCS/PCS BAND WORKING FREQUENCY
■ LTE BAND APPLICATION
■ MoCA Application
HIGH FREQUENCY MULTILAYER HIGH PASS FILTER………………………………………………………………………..…………44~45
■ 2496 ~ 2690 MHz BAND WORKING FREQUENCY
■ MoCA Application
BALUN TRANSFORMERS………………………………………………………………………………………………………..……………46~55
■ ISM Band 2.4GHz Application
■ ISM Band 5GHz Application
■ LTE Band Application
■ GSM 850/ GSM 900/ DCS1800/ PCS1900 Application
DIPLEXER…………………………………………………………………………………………………………………………..…………… 56~66
■ ISM Band 2.4GHz/5GHz Application
■ GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application
■ 892 MHz & 1.94GHz Band Working Frequency
TRIPLEXER……………………………………………………………………………………………………………………………..……… 67~70
■ GPS 1.575GHz/ISM 2.4GHz/5GHz Band RF Application
COMMON MODE FILTER……………………………………………………………………………………………………………..……………71
■ DISCRETE CMF for HIGH SPEED TRANSMISSION LINES、USB2.0、IEEE1394、LVDS(mini)
COUPLER…………………………………………………………………………………………………………………………..……………72~76
■ ISM Band 2.4/5GHz Application
SAW FILTER………………………………………………………………………………………………………………………..……………77~85
ANTENNA SWITCH (GPIO) ……………………………………………………………………………………………………..……………86~87
ANTENNA SWITCH (MIPI) …………………………………………………………………………………………………………..………88~89
ANTENNA SWITCH (LTE Antenna Tuner- GPIO)……………….……………………………………………………………..……………90
ANTENNA SWITCH (Network-GPIO)………………………………………………………………………………………….……………….91
Customer made Antenna………………………………………………………………………………………………………..…………92~102
■ Dipole Antenna (None Cable and With Cable)
■ PCB Antenna
■ FPA Antenna
■ Metal Antenna
■ NFC Antenna
■ Connector
*The specifications are subject to change or our products in it may be discontinued without advance notice. Please check with our sales representatives or
product engineers before ordering.
*This catalog has only typical specifications because there is no space for detailed specifications. Therefore, please approve our product specifications or
transact the approval sheet for product specifications before ordering.
ORDERING CODE
CHIP ANTENNA
RF
ANT
321612
A
5
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF/RG:
device
ANT : Antenna
FRA : Free Antenna
ECA : SMD Antenna
Per 2 digits of Length, Width,
Thickness
321612 =
Length =32
Width = 16
Thickness = 12
0 : 0.1 mm
1 : 1.0 mm
A: 2.4GHz ISM Band
E : GPS 1.5GHz
L : 2.4/5.2/5.8GHz Tri Band
W : WiMAX
Code from 0~9
dependent on
different electrical
specification
T: 7” Reeled
G: 13” Reeled
RF
BPF
322515
A
4
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF device
BPF : Band Pass Filter
Thickness
322515 =
Length =32
Width = 25
Thickness = 15
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
W : WiMAX
K : ISM 5.2/5.8 Dual Band
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
RF
BPB
252009
A
7
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF/RG: device
BPB : Balanced Type
Band Pass Filter
Thickness
252009 =
Length =25
Width = 20
Thickness = 09
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
W : WiMAX
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
RF
LPF
201211
A
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF device
LPF : Low Pass Filter
Thickness
201210 =
Length =20
Width = 12
Thickness = 11
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
RF
HPF
252009
L
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
RF device
HPF : High Pass Filter
Thickness
252009 =
Length =2.5
Width = 2.0
Thickness = 0.9
0 : 0.1 mm
1 : 1.0 mm
L : 2.4/4.9/5.2/5.8GHz
Multiband Application
Code from 0~9
dependent on
specification
T: 7” Reeled
G: 13” Reeled
BALUN TRANSFORMERS
RF
BLN
201208
A
4
T
Type code
Product code
Dimension code
Unit of dimension
Application
Specification
Packing
Code from 0~9
dependent on different
electrical specification
T: 7” Reeled
G: 13” Reeled
RF/RG:
device
1
BLN : BALUN
Thickness
201208 =
Length =20
Width = 12
Thickness = 08
0 : 0.1 mm
1 : 1.0 mm
A : 2.4GHz ISM Band
ORDERING CODE
DIPLEXER
RF
DIP
Type code
Product code
RF device
201210
L
T
Dimension code
Unit of dimension
Application
Specification
Packing
Thickness
201210 =
Length =20
Width = 12
Thickness = 10
DIP : Diplexer
0 : 0.1 mm
1 : 1.0 mm
Code from 0~9
T : 7” Reeled
G:13” Reeled
TRIPLEXER
RF
TIP
2109
A
T
M0T63
Type code
Product code
Dimension code
Pin Define
Application
Specification
RF device
Thickness
e.g. :
21 =
Length 2.0 mm,
Width 1.2 mm,
09=
Thickness 0.9 mm
TIP : Triplexer
Design Code
T: GPS/ ISM 2.4GHz/5 GHz
Design Code
COMMON MODE FILTER
RF
CMF
Type code
Product code
RF/RG:
device
CMF : Common Mode
Filter
122010
M
3
T
Dimension code
Unit of dimension
Application
Specification
Packing
Code from 0~9
T : 7” Reeled
Per 2 digits of Length, Width.
122010 =
Length =12
Width = 20
Thickness = 10
0 : 0.1 mm
1 : 1.0 mm
M: USB 2.0/ IEEE1394
COUPLER
RF
CPL
Type code
Product code
RF device
18
10
B
2450
T
Dimension code
Coupling Factor
Unit
Application
Packing
e.g. :
18 =
Length 16,
Width 08,
15=
Length 10,
Width 05,
Coupler
10 dB
dB
2.4 GHZ ISM Band
T : 7” Reeled
SAW FILTER
SF
1411
Product code
Dimension code
1411=
Length 1.4mm
Width 1.1mm
SF:SAW Filter
DF:SAW
DUPLEXER
2595
B38
03
T
Frequency
Application
Serial Number
Packing
2595:Center Freq (2595MHz)
B38:Band38
Design Code
T: 7” Reeled
ANTENNA SWITCH
RF
ASW
D
H2418A
T
Type code
Product code
Application
Serial Number
Packing
RF device
ASW: Antenna Switch
D: SP8T
Design Code
T: 7” Reeled
ANTENNA SWITCH MODULE
RM
ASM
N
T1492A
T
Type code
Product code
Application
Serial Number
Packing
RM:
Walsin RF Module Device
ASM: Antenna Switch Module
N: SP16T
Design Code
T: 7” Reeled
2
ORDERING CODE
Dipole Antenna
RF
DPA
8709
00
S
B
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
RF
device
DPA:
Dipole
Antenna
Per 2 digits of
Length, Width
8709 =
Length = 87
Width = 9.95
A: N
C:MCX
D:IPEX III
E: IPEX IV
F: IPEX A13
2 digits for cable
H: Hirose
length
I: IPEX
00=
K:F
None Cable
M: MMCX
S: SMA
T: TNC
U:MURATA
N: None
A
B
8
01
Application code
Project
status code
Wire
Diameter code
Project
code
0: 0GHz
5: 5 GHz
A: 2.4GHz ISM band
A: Reverse Female B: GSM 900/1800 dual
B: Reverse Male
band
F: Female
G: GPS band
M: Male
L: 2.4/5.2/5.8 GHz
N: None
tri-band
T:LTE band
U:UHF
W: WCDMA band
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9:Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
PCB Antenna
RF
PCA
4305
10
N
N
A
B
4
01
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application code
Project
status code
Wire
Diameter code
Project
code
RF
device
A: N
C:MCX
D:IPEX III
E: IPEX IV
Per 2 digits of 2 digits for cable F: IPEX A13
H: Hirose
Length, Width length
PCA:
I: IPEX
4305 =
10=
PCB Antenna
K:F
Length = 43
Cable Length:
M: MMCX
Width = 5
10cm
S: SMA
T: TNC
U:MURATA
N: None
0: 0GHz
5: 5 GHz
A: 2.4GHz ISM band
B: Reverse Male
band
F: Female
G: GPS band
M: Male
L: 2.4/5.2/5.8 GHz
N: None
tri-band
T:LTE band
U:UHF
W: WCDMA band
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
FPA Antenna
RF
FPA
3025
10
I
M
A
B
3
01
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application code
Project
status code
Wire
Diameter code
Project
code
RF
device
A: N
C:MCX
D:IPEX III
E: IPEX IV
H: Hirose
FPA:
I: IPEX
3025 =
10=
FPA Antenna
K:F
Length = 30
Cable Length:
M: MMCX
Width = 25
10cm
S: SMA
T: TNC
U:MURATA
N: None
0: 0GHz
5: 5 GHz
A: 2.4GHz ISM band
band
B: Reverse Male
G: GPS band
F: Female
L: 2.4/5.2/5.8 GHz
M: Male
tri-band
N: None
T:LTE band
U:UHF
W: WCDMA band
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
Metal Antenna
RF
MTA
3109
10
I
M
L
B
7
01
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application code
Project
status code
Wire
Diameter code
Project
code
RF
device
3
MTA:
Metal
Antenna
A: N
C:MCX
D:IPEX III
E: IPEX IV
H: Hirose
I: IPEX
3109 =
10=
K:F
Length = 31
Cable Length:
M: MMCX
Width = 9
10cm
S: SMA
T: TNC
U:MURATA
N: None
0: 0GHz
5: 5 GHz
A: 2.4GHz ISM band
B: Reverse Male
band
F: Female
G: GPS band
M: Male
L: 2.4/5.2/5.8 GHz
N: None
tri-band
T:LTE band
U:UHF
W: WCDMA band
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
ORDERING CODE
Cable Assembly
RF
CBA
1613
10
I
M
3
B
7
01
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application
code
Project
status code
Wire
Diameter code
Project
code
RF
device
CBA:
Cable
Assembly
Per 2 digits of
Length, Width
1613 =
Length = 16.8
Width = 13.7
A: N
C:MCX
D:IPEX III
E: IPEX IV
H: Hirose
length
I: IPEX
10=
K:F
Cable Length:
M: MMCX
10cm
S: SMA
T: TNC
U:MURATA
N: None
A: Reverse Female
B: Reverse Male
F: Female
M: Male
N: None
0: 0GHz
3: 3GHz
6: 6GHz
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
Connector
RF
CON
0201
00
D
F
6
B
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application
code
Project
status code
Wire
Diameter code
Project
code
RF
device
CON:
Connector
Per 2 digits of
Length, Width
0201 =
Length = 2.05
Width = 1.40
A: N
C:MCX
D:IPEX III
E: IPEX IV
F: IPEX A13
2 digits for cable
H: Hirose
length
I: IPEX
00=
K:F
None Cable
M: MMCX
S: SMA
T: TNC
U:MURATA
N: None
A: Reverse Female
B: Reverse Male
F: Female
M: Male
N: None
0: 0GHz
3: 3GHz
6: 6GHz
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
NFC Antenna
RF
NFC
0201
00
N
N
N
B
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application
code
Project
status code
Wire
Diameter code
Project
code
RF
device
Per 2 digits of
NFC:Near
Length, Width
Field
5339 =
Communicati
Length = 53.7
on Antenna
Width = 39.7
A: N
C:MCX
D:IPEX III
E: IPEX IV
F: IPEX A13
2 digits for cable
H: Hirose
length
I: IPEX
00=
K:F
None Cable
M: MMCX
S: SMA
T: TNC
U:MURATA
N: None
A: Reverse Female
B: Reverse Male
F: Female
M: Male
N: None
N: NFC
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
WPC Antenna
RF
WPC
5830
00
N
N
N
B
Type
code
Product
code
Dimension
code
Cable
Length code
Connector
Brand code
Type of
Connector code
Application
code
Project
status code
Wire
Diameter code
Project
code
RF
device
WPC:
Wireless
Power
Charging
Antenna
Per 2 digits of
Length, Width
5830 =
Length = 58
Width = 30
A: N
C:MCX
D:IPEX III
E: IPEX IV
F: IPEX A13
2 digits for cable
H: Hirose
length
I: IPEX
00=
K:F
None Cable
M: MMCX
S: SMA
T: TNC
U:MURATA
N: None
A: Reverse Female
B: Reverse Male
F: Female
M: Male
N: None
N: NFC
B: MP
T:During Test
X: Pile Run
0:None
1:∅0.81
2:∅1.32
3:∅1.13
4:Low Loss∅1.13
5:∅0.50
6:RG316
7:∅1.37
8:RG178
9: Low Loss∅1.37
A:RG174
B:1.5C-2V
01~99
series
number
Remark:
1.
Central Frequency should be defined after customers’ application approval.
4
CHIP ANTENNA
CHIP ANTENNA
STRUCTURE AND PIN ASSOCIATED
STRUCTURE A
a
STRUCTURE B
STRUCTURE C
STRUCTURE D
STRUCTURE F
STRUCTURE G
STRUCTURE H
Mark
a
W
L
T
STRUCTURE E
STRUCTURE AND DIMENSION
Structure\Dimension
L
W
T
a
10 ± 0.20
3.2 ± 0.20
0.8 ± 0.10
0.8 ± 0.10
2.0 ± 0.20
1.25 ± 0.20
0.90 ± 0.10
0.25 ± 0.15
0.60 ± 0.10
0.25 ± 0.20
1.20 ± 0.10
3.20 ± 0.20
A
Unit: mm
1.60 ± 0.20
b
c
d
1
2
3
0.25 ± 0.15
1.30 ± 0.20
0.40 ± 0.20
1.15 ± 0.10
0.40 ± 0.25
1.15 ± 0.15
0.40 ± 0.25
5.20 ± 0.20
2.00 ± 0.20
5.8 + 0.1
- 0.3
3.0 + 0.1
- 0.3
1.1 + 0.2
- 0.1
0.4 ± 0.25
8.00 ± 0.20
1.05 ± 0.20
0.80 ± 0.10
0.30 ± 0.20
9.10 ± 0.20
3.00 ± 0.20
2.00 ± 0.10
0.20 ± 0.20
9.50 ± 0.20
2.10 ± 0.20
1.15 ± 0.10
0.50 ± 0.30
1.60 ± 0.20
0.80 ± 0.20
0.50 ± 0.10
0.10 ± 0.05
2.00 ± 0.20
1.20 ± 0.20
0.50 ± 0.10
0.15 ± 0.05
10.40 ± 0.15
12.00 ± 0.15
4.00 ± 0.15
1.60 ± 0.15
4.00 ± 0.15
0.80 ± 0.10
B
5.9 ± 0.3
5.1 ± 0.3
1.1 ± 0.1
0.45 ± 0.2
1.0 ± 0.2
1.0 ± 0.2
2.0 ± 0.2
1.0 ± 0.2
1.0 ± 0.2
1.0 ± 0.2
C
7.6 ± 0.3
3.5 ± 0.2
1.1 ± 0.1
0.8 ± 0.2
0.8 ± 0.2
0.8 ± 0.2
0.5 ± 0.2
0.5 ± 0.2
0.8 ± 0.2
0.50 ± 0.2
Structure\Dimension
L
W
T
PW
P1
P2
P3
P4
P5
D
9.90±0.15
3.70±0.15
3.80±0.20
3.48±0.10
1.4±0.10
1.9±0.10
2.4±0.15
E
19.0±0.15
3.00±0.15
3.80±0.20
3.00±0.10
1.0±0.10
1.0±0.10
1.0±0.10
1.0±0.10
F
12.8±0.15
3.90±0.15
1.10±0.10
1.00±0.10
2.0±0.10
2.0±0.10
2.0±0.10
2.0±0.10
2.0±0.10
G
12.0±0.15
4.00±0.15
2.00±0.10
3.60±0.10
1.0±0.10
1.0±0.10
1.0±0.10
H
9.90±0.15
3.70±0.15
3.80±0.20
3.48±0.10
1.4±0.10
1.9±0.10
2.4±0.15
5
CHIP ANTENNA
ELECTRICAL SPECIFICATION
1.575GHz BAND WORKING FREQUENCY
Part Number
Frequency Range
(GHz)
Azimuth Beamwidth
( MHz )
Gain
(dBi)
VSWR
(max.)
Impedance
(Ω)
Polarization
Size
(mm)
Structure
RFANT5830110E0T
1.575
Omni-directional
0~2
2.0
50
Linear
5.80x3.00x1.10
A
RFECA1003011E0T
1.575
Omni-directional
2~3
2.0
50
Linear
10.0x3.20x0.80
A
RFECA3216060E□T
1.575
Omni-directional
3
2.0
50
Linear
3.20x1.60x0.60
A
Part Number
Frequency Range
(GHz)
Azimuth Beamwidth
( MHz )
Gain
(dBi)
VSWR
(max.)
Impedance
(Ω)
Polarization
Size
(mm)
Structure
RFECA3216060L1T
2.4~2.5
5.25~5.85
Omni-directional
0.6/2
2.1
50
Linear
3.20x1.60x0.60
A
RFANT6050110L0T
2.4~2.5
4.9~5.9
Omni-directional
4
2.0
50
Linear
5.90x5.10x1.10
B
RFANT6050110L1T
2.4~2.5
4.9~5.9
Omni-directional
4
2.0
50
Linear
5.90x5.10x1.10
B
RFANT2012090A0T
2.4~2.5
Omni-directional
1.72
2.0
50
Linear
2.00x1.25x0.90
A
RFANT3216120A1T
2.4~2.5
Omni-directional
2
2.0
50
Linear
3.20x1.60x1.20
A
RFANT3216120A3T
2.4~2.5
Omni-directional
2
2.0
50
Linear
3.20x1.60x1.20
A
RFANT3216120A5T
2.4~2.5
Omni-directional
2
2.0
50
Linear
3.20x1.60x1.20
A
RFANT5220110A0T
2.4~2.5
Omni-directional
2
2.0
50
Linear
5.20x2.00x1.10
A
RFANT5220110A2T
2.4~2.5
Omni-directional
2
2.0
50
Linear
5.20x2.00x1.10
A
RFANT7635110A1T
2.4~2.5
Omni-directional
0~2
2.0
50
Linear
7.60x3.50x1.10
C
RFANT8010080A3T
2.4~2.5
Omni-directional
2
2.0
50
Linear
8.00x1.00x0.80
A
RFANT9520120A0T
2.4~2.5
Omni-directional
2
2.0
50
Linear
9.50x2.00x1.20
A
RFECA3216060A1T
2.4~2.5
Omni-directional
2
2.1
50
Linear
3.20x1.60x0.60
A
RFECA3216060K1T
4.9~5.85
Omni-directional
2.8
2.0
50
Linear
3.20x1.60x0.60
A
RFANT9030200A1T
2.4~2.4835
Omni-directional
2
2.1
50
Linear
9.00x 3.00x2.00
A
RGFRA1903041A1T
2.4~2.5
Omni-directional
2
2.0
50
Linear
19.0x3.00x3.80
E
RGFRA1903041A5T
2.4~2.5
Omni-directional
2
2.0
50
Linear
19.0x3.00x3.80
E
RGFRA9937380A3T
2.4~2.55
Omni-directional
2
2.0
50
Linear
9.90x3.70x3.80
D
RGFRA1304011A1T
2.4~2.5
Omni-directional
2
2.1
50
Linear
12.8x3.90x1.10
F
RGFRA1204021A1T
2.4~2.5
Omni-directional
2
2.0
50
Linear
12.0x4.00x2.00
G
RFANT2012090A0T
2.4~2.5
Omni-directional
2
2.0
50
Linear
2.00x1.25x0.90
A
RFECA1608050A0T
2.4~2.5
Omni-directional
0.7
3.0
50
Linear
1.60x0.80x0.50
A
RFECA2012050A3T
2.4~2.5
Omni-directional
0.29
2.6
50
Linear
2.00x1.20x0.5
A
Part Number
Frequency Range
(GHz)
Azimuth Beamwidth
(MHz )
Gain
(dBi)
VSWR
(max.)
Impedance
(Ω)
Polarization
Size
(mm)
Structure
RFANT32162G6W0T
2.5~2.69
Omni-directional
1
3.0
50
Linear
3.20x1.60x1.20
A
RFANT32163G5W0T
3.3~3.8
Omni-directional
2~3
2.0
50
Linear
3.20x1.60x1.20
A
Part Number
Frequency Range
(MHz)
Azimuth Beamwidth
(MHz )
Gain
(dBi)
VSWR
(max.)
Impedance
(Ω)
Polarization
Size
(mm)
Structure
RGFRA1204011DCT
900~930
Omni-directional
1
2.0
50
Linear
12.00x4.00x1.60
A
RGFRA1204011DET
855~885
Omni-directional
1
2.0
50
Linear
12.00x4.00x1.60
A
For more information, please contact with local sales representative
All specifications are subject to change without notice
6
CHIP ANTENNA
TYPICAL ELECTRICAL CHARACTERISTICS
RFANT5220110A0T
X-Z Plane Vertical
X-Y Plane Vertical
Test Board
Y-Z Plane Vertical
3.3mm
Empty Area
18x9 mm
1.5mm
Empty Area
WTC
2.5mm
1mm
18mm
50 Feed
line
GROUND
30x18 mm
Peak Gain= -5.97dBi
Average Gain=-3.24 dBi
Peak Gain= -5.97dBi
Average Gain=-3.12 dBi
Return Loss (S11)
X-Y Plane Horizontal
X-Z Plane Horizontal
Peak Gain= 2.66dBi
Average Gain=-8.61 dBi
Peak Gain= 2.59dBi
Average Gain=-9.24 dBi
Peak Gain= 1.69dBi
Average Gain=-3.22 dBi
Y-Z Plane Horizontal
Peak Gain= -5.42dBi
Average Gain=-8.98 dBi
RGFAR1903041A1T
Test Board
X-Y Plane Vertical
Peak Gain= -7.42 dBi
Average Gain= -10.48 dBi
Return Loss (S11)
Peak Gain= 2.0 dBi
Average Gain= -2.31 dBi
7
X-Z Plane Vertical
Peak Gain= 1.95 dBi
Average Gain= -0.81 dBi
Peak Gain= -2.65 dBi
Average Gain= -8.4dBi
Y-Z Plane Vertical
Peak Gain= -0.26dBi
Average Gain=-5 dBi
Peak Gain = 1.11dBi
Average Gain = -4.37 dBi
CHIP ANTENNA
RFANT8010080A3T
Test Board
X-Y Plane Vertical
X-Z Plane Vertical
Peak Gain= 0.76 dBi
Average Gain= -5.81dBi
Return Loss (S11)
Peak Gain= -3.76 dBi
Average Gain= -8.72dBi
Peak Gain= 1.37 dBi
Average Gain= -2.67 dBi
Peak Gain= -0.25 dBi
Average Gain= -4.24 dBi
Y-Z Plane Vertical
Peak Gain = 3.03 dBi
Average Gain = 0.71 dBi
Peak Gain= -1.37 dBi
Average Gain=-8.6 dBi
RGFAR9937380A3T
Test Board
X-Y Plane Vertical
Peak Gain= -4.48 dBi
Average Gain= -8.02 dBi
Return Loss (S11)
Peak Gain= 3.19 dBi
Average Gain= -2.65 dBi
X-Z Plane Vertical
Peak Gain= 2.49 dBi
Average Gain= -2.47 dBi
Peak Gain= 3.05 dBi
Average Gain= -4.10dBi
Y-Z Plane Vertical
Peak Gain= -4.05dBi
Average Gain=-8.03 dBi
Peak Gain = 0.95dBi
Average Gain = -4.26 dBi
8
CHIP ANTENNA
RFECA3216060A1T
Test Board
X-Y Plane Vertical
Peak Gain= 0.83 dBi
Average Gain= -1.35 dBi
Peak Gain = 3.37 dBi
Average Gain = -0.65 dBi
Return Loss (S11)
X-Z Plane Vertical
Peak Gain= -4.62 dBi
Average Gain=-10.42 dBi
Peak Gain= 0.51 dBi
Average Gain= -4.07 dBi
Y-Z Plane Vertical
Peak Gain= -9.59 dBi
Average Gain= -15.40 dBi
Peak Gain= 1.39 dBi
Average Gain= -2.07 dBi
RFECA1003011E0T
Antenna S11 on Test Board
X-Y Plane Vertical
Peak Gain = 3.12dBi
Average Gain = -3.99 dBi
Antenna VSWR on Test Board
Peak Gain = +0.48dBi
Average Gain = -4.59dBi
9
X-Z Plane Vertical
Peak Gain= 1.97dBi
Average Gain= -1.44 dBi
Peak Gain = +4.99dBi
Average Gain = -1.31dBi
Y-Z Plane Vertical
Peak Gain = 3.32dBi
Average Gain = 1.02 dBi
Peak Gain = +3.02dBi
Average Gain = -0.85dBi
CHIP ANTENNA
RFECA3216060E1T
Land Pattern
X-Y Plane Vertical
Peak Gain= -5.51 dBi
Average Gain= -7.48 dBi
Return Loss (S11)
X-Z Plane Vertical
Peak Gain= -0.85 dBi
Average Gain= -5.22 dBi
Peak Gain= 4.85 dBi
Average Gain= 1.21 dBi
Peak Gain= 5.36 dBi
Average Gain= 1.25 dBi
Y-Z Plane Vertical
Peak Gain = 6.74 dBi
Average Gain = 4.81 dBi
Peak Gain= -6.99 dBi
Average Gain=-14.30 dBi
RFECA3216060K1T
Land Pattern
X-Y Plane Vertical
Average Gain= -11.78 dBi
Return Loss (S11)
Peak Gain= 2.3 dBi
Average Gain= -1.1 dBi
X-Z Plane Vertical
Peak Gain= 2.86 dBi
Average Gain= 0.86 dBi
Peak Gain=-2.49 dBi
Average Gain= -9.61dBi
Y-Z Plane Vertical
Peak Gain= -0.55dBi
Average Gain=-4.9 dBi
Peak Gain = 0.73dBi
Average Gain = -2.86 dBi
10
CHIP ANTENNA
RFECA1608050A0T
Test Board
X-Y Plane
X-Z Plane
Y-Z Plane
Peak Gain= -0.65 dBi
Average Gain= -2.38 dBi
Peak Gain= -2.12 dBi
Average Gain= -5.11 dBi
Peak Gain= -0.67dBi
Average Gain=-2.45 dBi
X-Y Plane
X-Z Plane
Y-Z Plane
Peak Gain= --1.07 dBi
Average Gain= -3.81 dBi
Peak Gain=0.29 dBi
Average Gain= 0.89 dBi
Peak Gain= -0.03dBi
Average Gain=-4.36 dBi
X-Y Plane
X-Z Plane
Y-Z Plane
Peak Gain= -0.19 dBi
Average Gain= -3.72 dBi
Peak Gain= --0.23 dBi
Average Gain= -4.23 dBi
Peak Gain= -1.29dBi
Average Gain=-1.46 dBi
Return Loss (S11)
RFECA2012050A3T
Test Board
Return Loss (S11)
RFANT2012090A0T
Test Board
Return Loss (S11)
11
CHIP ANTENNA
RGFRA1204011DCT
Test Board
X-Y Plane
X-Z Plane
Y-Z Plane
Peak Gain= -0.82 dBi
Average Gain= -1.11 dBi
Peak Gain= 0.56 dBi
Average Gain= -3.41 dBi
Peak Gain= 0.94dBi
Average Gain=-1.48 dBi
Return Loss (S11)
RGFRA1204011DET
Test Board
X-Y Plane
X-Z Plane
Y-Z Plane
Average Gain= -0.74 dBi
Peak Gain= -1.06 dBi
Average Gain= -3.01 dBi
Peak Gain= -0.82dBi
Average Gain=-1.29 dBi
Return Loss (S11)
RGFRA1204011DET
Test Board
X-Y Plane
X-Z Plane
Y-Z Plane
Peak Gain= -0.82dBi
Return Loss (S11)
12
HIGH FREQUENCY
STRUCTURE A
STRUCTURE B
STRUCTURE C
STRUCTURE D
STRUCTURE E
STRUCTURE F
STRUCTURE K
STRUCTURE L
V
STRUCTURE G
STRUCTURE H
STRUCTURE I
STRUCTURE J
V
13
HIGH FREQUENCY
Structure\
Dimension
A
L
T
A
B
C
D
E
0.70±0.10
0.20±0.20
0.55±0.20
0.50±0.20
0.25±0.20
0.90±0.10
0.20±0.20
0.55±0.20
0.50±0.20
0.20±0.20
1.00±0.10
0.20±0.20
0.55±0.20
0.50±0.20
1.05±0.10
0.25±0.20
0.50±0.20
1.20±0.10
0.25±0.20
0.50±0.20
2.05±0.20
0.70±0.20
0.25±0.20
3.20±0.20
2.50±0.10
1.50±0.10
1.00±0.10
0.50±0.10
0.40±0.10
2.50±0.20
1.60±0.15
W
2.00±0.20
0.80±0.15
1.20±015
B
2.00±.15
1.25±0.15
F
G
H
I
0.20±0.20
0.20±0.20
0.25±0.20
0.20±0.20
0.50±0.20
0.25±0.20
0.25±0.20
0.50±0.20
0.25±0.20
0.25±0.20
0.50±0.20
0.50±0.20
0.25±0.20
0.25±0.20
0.20±0.20
0.75±0.20
0.60±0.20
0.20±0.15
0.40±0.20
0.35±0.10
0.30±0.10
0.15±0.10
0.15±0.10
0.30±0.10
0.50±0.10
0.45±0.15
0.70±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.25±0.15
0.60±0.10
0.45±0.15
0.70±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.25±0.15
0.70±0.10
0.40±0.15
0.80±0.15
0.20±0.10
0.20±0.10
0.30±0.15
0.25±0.15
0.70±0.10
0.45±0.15
0.70±0.15
0.20±0.10
0.20±0.10
0.30±0.15
0.25±0.15
0.50±0.10
0.40±0.15
0.80±0.15
0.20±0.10
0.20±0.10
0.30±0.15
0.45±0.15
0.20±0.15
1.60±0.15
0.20±0.15
0.20±0.15
0.40±0.15
0.40±0.15
0.20±0.15
1.60±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.45±0.15
0.45±0.15
1.10±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.45±0.15
0.50±0.15
1.00±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.45±0.15
0.60±0.10
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.475±0.15
0.80±0.10
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.475±0.15
0.90±0.10
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.475±0.15
0.35±0.15
1.30±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.475±0.15
0.35±0.15
1.30±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.475±0.15
0.50±0.15
1.00±0.15
0.25±0.15
0.25±0.15
0.30±0.15
0.475±0.15
0.55±0.10
0.40±0.20
0.40±0.20
0.40±0.20
0.20±0.10
0.60±0.10
0.40±0.20
0.40±0.20
0.40±0.20
0.20±0.10
0.80±0.10
0.40±0.20
0.40±0.20
0.40±0.20
0.20±0.10
0.60±0.10
0.55±0.10
0.25±0.10
0.23±0.10
0.40±0.10
0.12±0.10
0.125±0.10
0.45±0.10
0.95±0.10
0.275±0.20
0.25±0.10
0.60±0.10
0.175±0.10
0.15±0.10
0.70 max
0.95±0.10
0.275±0.10
0.25±0.10
0.60±0.10
0.175±0.10
0.15±0.10
0.80±0.10
0.95±0.10
0.275±0.10
0.25±0.10
0.60±0.10
0.175±0.10
0.15±0.10
0.90±0.10
0.95±0.10
C
D
E
F
G
Unit: mm
2.00±.15
1.20±0.20
1.60±0.15
0.80±0.15
2.00±.15
1.25±0.10
1.10±0.10
0.90±0.10
0.60±0.10
0.25±0.10
0.18±0.10
0.205±0.10
0.25±0.10
1.40±0.15
1.10±0.10
0.60±0.10
0.325±0.10
0.25±0.10
0.25±0.10
0.25±0.10
1.40±0.15
1.10±0.15
0.70±0.10
0.325±0.10
0.25±0.10
0.25±0.10
0.25±0.10
2.00±0.20
1.25±0.20
1.60±0.15
0.80±0.15
1.60±0.10
0.80±0.10
2.00±0.15
1.25±0.10
1.00 max.
0.325±0.10
0.25±0.10
0.25±0.10
0.25±0.10
0.40±0.10
0.55±0.15
0.50±0.15
0.35±0.15
0.50±0.15
0.20±0.15
0.60±0.10
0.55±0.15
0.50±0.15
0.35±0.15
0.50±0.15
0.20±0.15
0.70 max.
0.55±0.10
0.25±0.10
0.23±0.10
0.40±0.10
0.12±0.10
0.195±0.10
0.21±0.10
0.125±0.10
0.80±0.10
0.95±0.10
0.40±0.10
0.30±0.10
0.30±0.10
0.15±0.10
0.30±0.10
0.35±0.10
0.15±0.10
0.90±0.10
0.95±0.10
0.40±0.10
0.30±0.10
0.30±0.10
0.15±0.10
0.30±0.10
0.35±0.10
0.15±0.10
2.50±0.20
2.00±0.20
0.90±0.10
1.70±0.20
0.60±0.20
0.30±0.20
0.40±0.20
0.15±0.10
0.60±0.10
0.50±0.10
0.15±0.10
H
1.60±0.15
0.80±0.10
0.60 max.
0.25±0.10
0.23±0.05
0.40±0.10
0.30±0.10
0.55±0.10
0.60±0.10
I
2.00±0.15
1.25±0.10
1.00 max.
1.80±0.10
0.35±0.10
0.25±0.10
0.25±0.10
0.275±0.10
0.35±0.10
0.25±0.10
0.25±0.10
0.275±0.10
J
2.50±0.15
2.00±0.15
0.90±0.10
0.30±0.10
0.40±0.10
0.55±0.10
0.40±0.10
0.90±0.10
0.30±0.10
2.00±0.15
1.25±0.15
1.05±0.15
0.475±0.15
0.30±0.15
0.20±0.15
0.50±0.15
0.60±0.15
0.95±0.15
3.20±0.20
2.50±0.20
1.80±0.20
0.95±0.20
0.60±0.20
0.30±0.15
0.70±0.15
1.20±0.15
2.00±0.15
2.00±0.15
1.25±0.10
1.05 max.
0.20±0.10
0.35±0.10
0.30±0.10
0.65±0.10
0.20±0.10
0.20±0.10
0.475±0.10
0.30±0.10
K
L
14
HIGH FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
RBBPF1005040A1T
2.4~2.5
2.5
25(824~960MHz)
20(1710~1910MHz)
20(4800~5000MHz)
15(7200~7500MHz)
2.0
50
1.00x0.50x0.40
B
2.4~2.5
1.5max.(25℃)
1.7max.(-40~+85℃)
13(824~915MHz)
5(1545~1605MHz)
34(4800~5000MHz)
27(7200~7500MHz)
2.1
50
1.00x0.50x0.40
B
2.0
50
1.10x 0.90x0.60
E
2.0
50
1.40x1.10x0.60
E
2.0
50
1.40x1.10x0.60
E
RFBPF1005040A3T
RFBPF1109060A0T
2.4~2.5
1.8
RFBPF1411060A1T
2.4~2.5
1.8max.(25℃)
2.1max.(-40~+85℃)
35(824~960MHz)
38(1545~1605MHz)
20(1710~1990MHz)
8(2110~2170MHz)
35(3600MHz)
35(4800~5000MHz)
35(7200~7500MHz)
40(824~960MHz)
40(1545~1605MHz)
20(1710~1990MHz)
8(2110~2170MHz)
35(3600MHz)
35(4800~5000MHz)
35(7200~7500MHz)
RFBPF1411060A2T
2.4~2.5
1.5
30(500~960MHz)
25(1500~1650MHz)
19(3200~3300MHz)
40(4800~5000MHz)
30(7200~7500MHz)
RBBPF1411060A3T
2.4~2.5
1.1
20( 50~960MHz)
10( 1710~1990MHz)
9( 3600MHz)
22( 4800~7200MHz)
2.0
50
1.40x1.10x0.60
E
RBBPF1411060A8T
2.4~2.5
1.0max.(25℃)
1.2max.(-40~+85℃)
15(50~960MHz)
10(1710~1990MHz)
15(3600MHz)
25(4800~7200MHz)
2.0
50
1.40x1.10x0.60
E
RFBPF1608060AA7M1U
2.4~2.5
0.95max.(25℃)
1.25max.(-40~+85℃)
20(500~960MHz)
23(3200MHz)
30(4800~5000MHz)
32(7200~7500MHz)
2.0
50
1.60x0.80x0.60
H
2.0
50
1.60x0.80x0.60
B
RFBPF1608060ADT
2.4~2.5
1.8max.(25℃)
2.1max.(-40~+85℃)
25(800~1000MHz)
22.5(1200~1300MHz)
5.5(2000MHz)
10.5(3000MHz)
23.5(3600~3800MHz)
35(4800~5000MHz)
35(7200~7500MHz)
RFBPF1608060AET
2.4~2.5
1.7max.(25℃)
2.0max.(-40~+85℃)
25(880MHz)
20(3200MHz)
35(4800~5000MHz)
25(7200~7500MHz)
2.0
50
1.60x0.80x0.60
F
2.4~2.5
2.4max.(25℃)
2.7max.(-40~+85℃)
24.5(880~960MHz)
20(1710~1990MHz)
8.5(2170MHz)
15(4800~5000MHz)
20(7200~7500MHz)
2.0
50
1.60x0.80x0.70
B
2.4~2.5
2.0max.(25℃)
2.2max.(-40~+85℃)
30 (960MHz)
25(1910MHz)
20(1990MHz)
25(4800MHz)
15(7200MHz)
2.0
50
1.60x0.80x0.70
B
2.4~2.5
2.0max.(25℃)
2.2max.(-40~+85℃)
20(960MHz)
20(1910MHz)
15(1990MHz)
18(4800MHz)
25(7200MHz)
2.0
50
1.60x0.80x0.50
B
2.8
25(695~800MHz)
20(1910MHz)
35(3200MHz)
20(4800~5000MHz)
20(7200~7500MHz)
2.0
50
1.60x0.80x0.60
B
3.0
25(695~800MHz)
20(1910MHz)
35(3200MHz)
20(4800~5000MHz)
20(7200~7500MHz)
2.0
50
1.60x0.80x0.60
B
RFBPF1608070AFT
RFBPF1608070AWT
RFBPF1608050A0T
RFBPF1608060A1T
RFBPF1608060A7T
15
2.4~2.5
2.4~2.5
HIGH FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
RFBPF1608070A3T
2.4~2.5
1.8max.(25℃)
2.1max.(-40~+85℃)
27(800~900MHz)
25(4800~5000MHz)
30(7200~7500MHz)
2.0
50
1.60x0.80x0.70
B
2.4~2.5
1.8max.(25℃)
2.0max.(-40~+85℃)
30(860~960MHz)
30(1545~1605MHz)
35(1710~1990MHz)
30(2170MHz)
30(4800~5000MHz)
2.0
50
2.00x1.20x0.80
D
2.4~2.5
1.80max.(25℃)
2.00max.(-40~+85℃)
30(860~960MHz)
30(1545~1605MHz)
35(1710~1990MHz)
30(2170MHz)
30(4800~5000MHz)
2.0
50
2.00x1.25x0.80
G
2.0
50
2.00x1.25x0.90
G
RFBPF2012080AM0T62
RFBPF2008A38T
RFBPF2012090AS1T35
2.4~2.5
0.9max.(25℃)
1.1max.(-40~+85℃)
28(824~960MHz)
30(1570~1580MHz)
15(1710~1910MHz)
9.5(1910~1990MHz)
25(4800~5000MHz)
25(7200~7500MHz)
RFBPF2012060AAT
2.4~2.5
1.5max.(25℃)
1.8max.(-40~+85℃)
30(880~960MHz)
25(1710~1910MHz)
25(4800~5000MHz)
30(7200~7500MHz)
2.0
50
2.00x1.20x0.60
C
2.0
50
2.00x1.20x0.40
D
RFBPF2012040ABT
2.4~2.5
2.5
30(824~849MHz)
30(880~915MHz)
30(1545~1605MHz)
30(1565~1585MHz)
35(1710~1785MHz)
40(1850~1910MHz)
32(1920~1980MHz)
7(3168~4752MHz)
11(3300~3800MHz)
35(4800~4967MHz)
26(5150~6000MHz)
23(7200~7450MHz)
RFBPF2012050ACT
2.4~2.5
2.5
35(824~960MHz)
38(1710~1910MHz)
25(4880~5000MHz)
20(7200~7500MHz)
2.0
50
2.00x1.20x0.55
C
2.4~2.5
1.5max.(25℃)
1.7max.(-40~+85℃)
30(860~960MHz)
30(1545~1605MHz)
30(1710~1990MHz)
30(2170MHz)
30(4800~5000MHz)
2.0
50
2.00x1.25x0.80
D
1.8max.(25℃)
2.0max.(-40~+85℃)
30(824~915MHz)
30(1545~1605MHz)
35(1710~1990MHz)
30(2170MHz)
30(4800~4967MHz)
25(5150~6000MHz)
20(7200~7450.5MHz)
2.0
50
2.00x1.25x0.80
D
1.8max.(25℃)
2.0max.(-40~+85℃)
35(824~960MHz)
28(1540~1605MHz)
30(1710~1990MHz)
30(2170MHz)
6(3200MHz)
30(4800~4967MHz)
20(5150~6000MHz)
18(7200~7450MHz)
2.0
50
2.00x1.25x0.80
D
2.5
25(746~764MHz)
30(824~849MHz)
26(869~960MHz)
28(1570~1580MHz)
28(1710~1785MHz)
30(1850~1910MHz)
30(1930~1990MHz)
30(2110~2170MHz)
15(3300~3800MHz)
35(4800~5000MHz)
20(7200~7450.5MHz)
2.0
50
2.00x1.25x0.45
D
2.5max.(typ.2.2)
25(746~764MHz)
30(824~849MHz)
26(869~960MHz)
28(1570~1580MHz)
28(1710~1785MHz)
30(1850~1910MHz)
30(1930~1990MHz)
25(2110~2170MHz)
15(3300~3800MHz)
35(4800~5000MHz)
2.0
50
2.00x1.25x0.45
D
RFBPF2012080ADT
RFBPF2008A40T
RFBPF2008A39T
RFBPF2012040AHT
RBBPF2012050AHT
2.4~2.5
2.4~2.5
2.4~2.5
2.4~2.5
16
HIGH FREQUENCY
Part Number
RFBPF2012090ALT
RFBPF2012090AMT
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.4~2.5
1.0max.(25℃)
1.2max.(-40~+85℃)
28(824~960MHz)
28(1570~1580MHz)
23(1710~1910MHz)
17(1920~1990MHz)
25(4800~5000MHz)
2.0
50
2.00x1.25x0.90
G
2.6
40(880~960MHz)
38(1710~1990MHz)
16(2170MHz)
30(4800~5000MHz)
30(7200~7500MHz)
2.0
50
2.00x1.20x0.90
B
2.0
50
2.00x1.20x1.00
I
2.4~2.5
RFBPF2012100ANT
2.4~2.5
2.3max.(25℃)
2.6max.(-40~+85℃)
40(699~960MHz)
40(1428~1448MHz)
40(1476~1607MHz)
40(1710~1785MHz)
33(1805~1880MHz)
30(1880~1915MHz)
30(1920~1990MHz)
22(2110~2170MHz)
25(4800~5000MHz)
35(7200~7500MHz
RFBPF2012090AQT
2.4~2.5
1.2
20(1600MHz)
25(3200MHz)
20(4800~5000MHz)
2.0
50
2.00x1.20x0.90
B
RFBPF2012090ART
2.4~2.5
1.0
20(1600MHz)
25(3200MHz)
2.0
50
2.00x1.20x0.90
B
2.4~2.5
1.5max.(25℃)
1.7max.(-40~+85℃)
40(699~960MHz)
40(1428~1448MHz)
40(1476~1607MHz)
40(1710~1785MHz)
33(1805~1880MHz)
30(1880~1915MHz)
30(1920~1990MHz)
25(4800~5000MHz)
30(7200~7500MHz
2.0
50
2.00x1.20x1.00
I
2.4~2.5
1.3max.(25℃)
1.5max.(-40~+85℃)
38(50~960MHz)
17(1710~1910MHz)
5(3200MHz)
30(4800~5000MHz)
25(7200~7500MHz)
2.0
50
2.00x1.20x0.90
E
2.4~2.5
1.0max.(25℃)
1.2max.(-40~+85℃)
28(824~960MHz)
28(1570~1580MHz)
23(1710~1910MHz)
17 (1920~1990MHz)
4(2100~2170MHz)
25(4800~5000MHz)
25(7200~7500MHz)
2.0
50
2.00x1.25x0.90
G
RBBPF2010A16T
2.4~2.5
1.3max.(25℃)
1.5max.(-40~+85℃)
38(50~960MHz)
17(1710~1990MHz)
20(3200MHz)
30(4800~5000MHz)
25(7200~7500MHz)
2.0
50
2.00x1.25x1.00
E
RFBPF2009A25T
2.4~2.5
1.7max.(25℃)
1.9max.(-40~+85℃)
30(900MHz)
20(1850MHz)
30(4800MHz)
2.0
50
2.00x1.20x0.90
B
2.4~2.5
1.4max.(25℃)
1.6max.(-40~+85℃)
30(824~960MHz)
30(1710~1910MHz)
20(1920~1990MHz)
6(2110~2170MHz)
20(4800~5000MHz)
2.0
50
2.00x1.20x0.90
B
2.0max.(25℃)
2.2max.(-40~+85℃)
25(746~764MHz)
30(824~849MHz)
26(869~960MHz)
28(1570~1580MHz)
28(1710~1785MHz)
30(1850~1910MHz)
30(1930~1990MHz)
25(2110~2170MHz0
15(3300~3800MHz)
35(4800~5000MHz)
20(7200~7450.5MHz)
2.0
50
2.00x1.25x0.45
D
RFBPF2012100AVT
RBBPF2010A108Q1C
RFBPF2009A12T
RFBPF2009A26T
RFBPF2012040A3T
17
Frequency
Range(GHz)
2.4~2.5
HIGH FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
50
2.00x1.20x0.80
C
RFBPF2012080A6T
2.4~2.5
3.5
30(880~960MHz)
30(1710~1990MHz)
20(2110~2170MHz)
30(4800~5000MHz)
30(7200~7500MHz)
RFBPF2012100A6T
2.4~2.5
1.0max.(25℃)
1.2max.(-40~+85℃)
21(902~928MHz)
26(4800~5000MHz)
34(7200~7500MHz)
29(9600~10000MHz)
2.0
50
2.00x1.20x1.00
L
2.8
(typ.2.5)
40(DC~1600MHz)
35(1710MHz)
25(1900MHz)
12(2100MHz)
8(2170MHz)
30(3100MHz)
40(4800~5000MHz)
20(7200~7500MHz)
2.0
50
2.00x1.20x0.80
B
2.8
30(960MHz)
30(1600MHz)
20(1990MHz)
35(3200MHz)
40(4800MHz)
25(7200MHz)
2.0
50
2.00x1.20x0.60
B
2.1max.(25℃)
2.3max.(-40~+85℃)
43(806~960MHz)
43(1570~1580MHz)
43(1710~1990MHz)
20(2110~2170MHz)
30(4800~5000MHz)
25(7200~7500MHz)
2.0
50
2.50x2.00x0.90
G
2.0max.(25℃)
2.2max.(-40~+85℃)
45(824~960MHz)
45(1570~1580MHz)
45(1710~1785MHz)
40(1805~1850MHz)
35(1850~1910MHz)
35(1920~1990MHz)
25(2110~2170MHz)
5(2750~3000MHz)
15(3000~4800MHz)
30(4800~5000MHz)
30(5150~5850MHz)
20(7200~7500MHz)
2.0
50
2.50x2.00x0.70
A
2.2
30(900MHz)
30(1850MHz)
33(2170MHz)
35(4800MHz)
25(7200MHz)
2.0
50
2.50x2.00x0.70
A
2.0
50
2.50x2.00x1.20
A
RFBPF2012080A7T
RFBPF2012060A9T
RFBPF2520090ACT
RFBPF2520070AMT
RFBPF2520080AUT
2.4~2.5
2.4~2.5
2.4~2.5
2.4~2.5
2.4~2.5
RFBPF2520120A1T
2.4~2.5
1.7
30(900MHz)
30(1850MHz)
20(2100MHz)
40(4800MHz)
25(7200MHz)
RFBPF2520120A2T
2.4~2.5
2.1
30(900MHz)
30(1850MHz)
30(4800MHz)
2.0
50
2.50x2.00x1.20
A
RFBPF2520120A3T
2.4~2.5
≦1.2(25℃)
30(900MHz)
30(1850MHz)
25(4800MHz)
2.0
50
2.50x2.00x1.20
A
RFBPF2520120A4T
2.4~2.5
≦1.7(25℃)
30(900MHz)
30(1850MHz)
25(4800MHz)
2.0
50
2.50x2.00x1.20
A
RFBPF2520100A6T
2.4~2.5
1.4
35(1900/4800 MHz)
2.0
50
2.50x2.00x1.00
A
18
HIGH FREQUENCY
Part Number
Frequency
Range(GHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
RFBPF1608060K2T
4.9~5.84
1.5max.(25℃)
1.7max.(-40~+85℃)
33(100~2170MHz)
29(2170~2500MHz)
32(9800~12000MHz)
2.0
50
1.60x0.80x0.70
B
2.0
50
1.60x0.80x0.60
D
RFBPF1608060K68Q1C
4.9~5.9
1.3max.(25℃)
1.5max.(-40~+85℃)
38(30~2700MHz)
16(3453~3547MHz)
33(3667~3883MHz)
9(6900~7093MHz)
32(7333~7750MHz)
40(10600~11650MHz)
18(15540~17760MHz)
RFBPF1608060K78Q1C
5.15~5.95
0.8max.(25℃)
1.0max.(-40~+85℃)
40(30~2700MHz)
45(3400~3800MHz)
20(7250~7800MHz)
20(10300~11700MHz)
1.5
50
1.60x0.80x0.60
D
RFBPF1608060K88Q1C
5.15~5.95
0.7max.(25℃)
0.85max.(-40~+85℃)
35(30~2700MHz)
30(3400~3800MHz)
12(7250~7800MHz)
20(10300~11700MHz)
1.5
50
1.60x0.80x0.60
D
1.67
50
1.60x0.80x0.60
D
2.0
50
1.60x0.80x0.60
D
40(30~2700MHz)
45(3400~3800MHz)
20(6900MHz)
20(7250~7800MHz)
20(10300~11700MHz)
38(10~2700MHz)
20(2700~3550MHz)
15(3550~4000MHz)
3(4000~4500MHz)
5(4400MHz)
3(6500~7000MHz)
11(7000~7400MHz)
13(7400~9750MHz)
30(9750~10300MHz)
27(10300~12750MHz)
10(15540~17775MHz)
RFBPF1608060KG8D1T
5.15~5.95
0.8
RFBPF1606K12T
5.15~5.925
1.1max.(25℃)
1.3max.(-40~+85℃)
RFBPF2012100KST
4.9~5.9
1.5(4.90GHz)
1.5(5.25GHz)
1.5(5.85GHz)
30(3450MHz)
20(11000MHz)
2.0
50
2.00x1.20x1.00
B
RFBPF2012100K0T
4.9~5.9
1.7(4.90GHz)
1.5(5.25GHz)
1.5(5.85GHz)
30(3450MHz)
20(11000MHz)
2.0
50
2.00x1.20x1.00
B
RFBPF2012090K5T
4.9~5.85
2.2max.(25℃)
2.5max.(-40~+85℃)
35(340~1195MHz)
19(2140~3580MHz)
25(6855~7150MHz)
20(8570~8930MHz)
2.0
50
2.00x1.20x0.90
B
4.9~5.85
1.8max.(25℃)
2.1max.(-40~+85℃)
30(500MHz)
35(3450MHz)
30(4000MHz)
20(4200MHz)
15(9800MHz)
15(11700MHz)
2.0
50
2.00x1.20x0.95
B
5.15~5.85
1.6max.(25℃)
1.8max.(-40~+85℃)
30(500MHz)
40(2000MHz)
35(3450MHz)
30(4000MHz)
20(4200MHz)
2.0
50
2.00x1.20x0.95
B
2.0
50
2.00x1.20x0.95
B
RFBPF2012100K3T
RFBPF2012100K6T
RFBPF2012090K9T
5.725~5.85
2.0
30(500MHz)
30(4000MHz)
20(4200MHz)
32(5000MHz)
15(9800MHz)
15(11750MHz)
RFBPF2520090K1T
4.9~5.85
1.2max.(25℃)
1.5max.(-40~+85℃)
50(824~1910MHz)
15(9880~11700MHz)
2.0
50
2.50x2.00x0.90
A
3.5
50(1000MHz)
35(2500MHz)
20(3500MHz)
7(4250MHz)
15(5150MHz)
20(57500MHz)
2.0
50
2.50x2.00x0.80
A
KFBPF25204G7W09S5K
19
4.4~4.94
HIGH FREQUENCY
Part Number
RFBPF16082G3W0T
Frequency
Range(GHz)
2.3~2.39
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
2.0
29(880~915MHz)
29(1710~1785MHz)
21(1850~1910MHz)
15(1920~1980MHz)
18(4600~4780MHz)
23(6900~7170MHz)
2.0
50
1.60x0.80x0.70
B
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
1.9max.
25(960MHz)
8(1850MHz)
15(1990MHz)
20(2170MHz)
35(2400~2500MHz)
35(3400~3800MHz)
2.0
50
1.10x0.90x0.60
E
30(824~849MHz)
30(880~915MHz)
10(1880~1910MHz)
22(1920~1980MHz)
30(2400MHz)
2.0
50
1.40x1.10x0.70
E
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
0.7max.(25℃)
0.75max.(-40~+85℃)
25(430~490MHz)
10(1700~1900MHz)
20(2400~2500MHz)
20(4905~5845MHz)
1.9
50
2.50x2.00x0.90
J
1.1max.(25℃)
1.2max.(-40~+85℃)
25(900~1015MHz)
15(2400~2500MHz)
15(3610~3980MHz)
20(4905~5845MHz)
2.0
Part Number
RFBPF1109060E0T
RFBPF1411070E0T
Frequency
Range (MHz)
1550~1610
1558~1606
1.8max.(25℃)
2.0max.(-40~+85℃)
Part Number
Frequency
Range (MHz)
869~960
Insertion Loss
(dB)
RFBPF2520090B08Q1C
1805~2025
Part Number
Frequency
Range(MHz)
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
RFBPF3225180Y1T
975~1025
3.0
30(54~870MHz)
30(1125~1675MHz)
30(2300MHz)
2.0
75
3.20x2.50x1.80
K
2.0
75
3.20x2.50x1.80
K
RFBPF3225200Y07B1U
475~675
2.5max.(25℃)
2.7max.(-40~+85℃)
60(2.5MHz)
40(2.5~100MHz)
35(100~200MHz)
35(200~300MHz)
8(300~400MHz)
57(950MHz)
47(950~2025MHz)
41(2025~2500MHz)
35(2500~3000MHz)
RBBPF3225180Y27B1U
400~700
2.0
42(1~200MHz)
30(950~2150MHz)
35(2150~3000MHz)
27(3000~5900MHz)
2.0
50
3.20x2.50x1.80
K
KFBPF2012100C67B1U
1125~1675
2.5
35(1~900MHz)
20(900~1002MHz)
35(2000~2500MHz)
20(2500~5900MHz)
2.0
50
2.00x1.25x1.05
K
RFBPF3225180C07B1U
1125~1675
1.8max.(25℃)
2.0max.(-40~+85℃)
30(5~864MHz)
34(864~1002MHz)
32(2300~3000MHz)
2.0
75
3.20x2.50x1.80
K
RBBPF3225180C67B1U
1125~1675
2.0
40(1~900MHz)
25(900~1002MHz)
35(2000~2500MHz)
27(2500~5900MHz)
2.0
50
3.20x2.50x1.80
K
HIGH FREQUENCY
Part Number
Frequency
Range(MHz)
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
STRUCTURE
RFBPF1109B101T
2110~2170
1.7
25(4280MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B201T
1930~1990
1.7
25(3920MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B301T
1805~1880
1.4
25(3685MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B501T
869~894
0.9
12(1763MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B701T
2620~2690
1.2
25(5310MHz)
2
50
1.10x0.90x0.60
E
RFBPF1109B801T
925~960
0.9
12(1885MHz)
2
50
1.10x0.90x0.60
E
2
50
1.60x0.80x0.70
G
RFBPF16081G9DM1T79
1805~2025
1.6max.(25℃)
1.8max.(-40~+85℃)
25(700~950MHz)
15(950~1050MHz)
25(2400~2500MHz)
35(2700~5150MHz)
40(5150~5850MHz)
25(5850~12750MHz )
RFBPF16081G9DMAT79
1880~2025
2.0max.(25℃)
2.2max.(-40~+85℃)
20(1545~1610MHz)
25(2400~2500MHz)
25(5150~5850MHz)
2
50
1.60x0.80x0.70
G
1.6
30(700~950MHz)
15(950~1050MHz)
25(2400~2500MHz)
35(2700~5400MHz)
35(5500~6200MHz)
35(9350~10150MHz)
20(10500~12750MHz
2
50
1.60x0.80x0.70
G
RFBPF16081G9DS8T60
1805~2025
21
RBBPF1005040A1T
RFBPF1005040A3T
RFBPF1109060A0T
RFBPF1411060A1T
HIGH FREQUENCY
RFBPF1411060A2T
RBBPF1411060A3T
RBBPF1411060A8T
RFBPF1608060AA7M1U
RFBPF1608060ADT
RFBPF1608060AET
RFBPF1608070AFT
RFBPF1608070AWT
RFBPF1608050A0T
RFBPF1608060A1T
22
HIGH FREQUENCY
23
RFBPF1608060A7T
RFBPF2008A38T
RFBPF2012080AC2T00
RFBPF2012090AS1T35
RFBPF2012060AAT
RFBPF2012040ABT
RFBPF2012050ACT
RFBPF2012080ADT
RFBPF2008A40T
RFBPF2008A39T
HIGH FREQUENCY
RFBPF2012040AHT
RBBPF2012050AHT
RFBPF2012090ALT
RFBPF2012090AMT
RFBPF2012100ANT
RFBPF2012090AQT
RFBPF2012090ART
RFBPF2012100AVT
RBBPF2010A108Q1C
RFBPF2009A12T
24
HIGH FREQUENCY
25
RBBPF2010A16T
RFBPF2009A25T
RFBPF2009A26T
RFBPF2012040A3T
RFBPF2012080A6T
RFBPF2012100A6T
RFBPF2012080A7T
RFBPF2520090ACT
RFBPF2520070AMT
RFBPF2520080AUT
HIGH FREQUENCY
RFBPF2520120A1T
RFBPF2520100A6T
RFBPF1608060K2T
RFBPF1608060K68Q1C
RFBPF1608060K788Q1C
RFBPF1608060K88Q1C
RFBPF1608060KG8D1T
RFBPF1606K12T
RFBPF2012100KST
RFBPF2012100K0T
26
HIGH FREQUENCY
RFBPF2012090K5T
RFBPF2012100K3T
RFBPF2012100K6T
RFBPF2012090K9T
RFBPF2520090K1T
RFBPF16082G3W0T
RFBPF1109060E0T
RFBPF1411070E0T
RFBPF2520090B08Q1C
Low Band
27
High Band
HIGH FREQUENCY
RFBPF3225180Y1T
RFBPF3225200Y07B1U
RBBPF3225180Y27B1U
KFBPF2012100C67B1U
RFBPF3225180C07B1U
RBBPF3225180C67B1U
RFBPF1109B101T
RFBPF1109B201T
RFBPF1109B301T
RFBPF1109B501T
28
HIGH FREQUENCY
29
RFBPF1109B701T
RFBPF1109B801T
RFBPF16081G9DM1T79
RFBPF16081G9DMAT79
HIGH FREQUENCY
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-2
STRUCTURE B
Structure\
Dimension
A
B
Unit: mm
L
W
T
A
B
C
D
E
F
G
1.60±0.15
0.80±0.15
0.60±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.20±0.15
0.30±0.15
1.20±0.10
0.40±0.10
0.175±0.10
0.35±0.15
0.30±0.15
0.65±0.10
0.20±0.10
0.20±0.15
0.50±0.10
0.50±0.10
0.20±0.15
0.30±0.15
0.35±0.15
0.65±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.60±0.10
0.20±0.15
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.50±0.10
0.90±0.10
0.20±0.15
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.30±0.10
0.63±0.10
0.20±0.15
0.20±0.15
0.50±0.10
1.00±0.10
0.20±0.15
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.10
0.20±0.15
0.50±0.10
1.10±0.10
0.20±0.15
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.55±0.10
0.50±0.10
0.35±0.10
0.65±0.10
0.20±0.15
0.20±0.15
0.50±0.10
2.00±0.15
1.25±0.15
2.50±0.20
2.00±0.20
0.85±0.10
0.35±0.20
0.40±0.10
0.30±0.10
0.70±0.20
0.15(Typical)
0.15(Typical)
1.20±0.20
1.95±0.15
1.25±0.15
0.80±0.10
0.175±0.15
0.30±0.15
0.35±0.15
0.65±0.15
0.25±0.15
2.00±0.15
1.25±0.10
0.60±0.10
0.20±0.10
0.30±0.15
0.35±0.15
0.65±0.10
0.25±0.10
30
HIGH FREQUENCY
Part Number
RFBPB2012090A1T
Impedance(Ω)
Frequency
Range
Unbalance
Balance
(MHz)
2.4~2.5
Insertion
Loss
(dB)
Attenuation
( dB min. )
VSWR
(Max.)
50
Conjugate
match to BC
series of
Bluetooth
chipset
3.5
35(880~960MHz)
30(1710~1880MHz)
20(1880~1990MHz)
30(4800~5000MHz)
2.1
180°± 10
2.8
35(880~960MHz)
30(1575MHz)
25(1710~1880MHz)
30(4800~5000MHz)
2.1
3.5
35(880~960MHz)
30(1710~1880MHz)
20(1880~1990MHz)
30(4800~5000MHz)
Phase
Amplitude
Difference Difference
Size
(mm)
STRUCTURE
2
2.00x1.25x0.90
A-1
180°± 10
2
2.00x1.25x0.90
A-1
2.1
180°± 10
2
2.00x1.25x0.90
A-1
RFBPB2012090A9T
2.4~2.5
50
Conjugate
match to BC
series of
Bluetooth
chipset
RFBPB2012090AAT
2.4~2.5
50
Conjugate
match to CSR
BC03/ 04
series
50
Impedance
match to T.I.
CC253X,CC25 1.5max.(25℃)
4X, CC257X,
1.7max.
CC853X and
(-40~+85℃)
CC852X
Chipsets
12(1000MHz)
15(4800~5000MHz)
20(7200~7500MHz)
2.0
180°± 15
2
2.00x1.25x0.60
B
50
Impedance
match to: Atmel
AT86RF232,
AT86RF233,
ATMega256RF
R2, Zigbit
1.5max.(25℃)
256RFR2,
1.7max.
Zigbit RF233,
(-40~+85℃)
ZigBit
RF233+FEM,
Extension
RF233, USB
RF233
20(4800~5000MHz)
20(7200~7500MHz)
2.0
180°± 10
2
1.95x1.25x0.80
B
3.5
30(880~960MHz)
30(1710~1880MHz)
20(1880~1990MHz)
30(4800~5000MHz)
2.0
180°± 10
2
2.00x1.25x0.90
A-1
2.0
180°± 10
2
2.00x1.25x0.95
A-1
RFBPB2012060ABT
RFBPB2012080AET
RFBPB2012090AHT
RFBPB2012090AM1T59
RFBPB2012090AM1T61
2.4~2.5
2.4~2.5
2.4~2.5
2.4~2.5
2.4~2.5
50
100
50
Conjunction to
MT5931/MT66
28 Chipset
2.5 (typ.2.2)
35( 824~960 MHz)
32(1990 MHz)
18(2170 MHz)
40(4800~5000MHz)
25(7200~7500MHz)
50
Conjugate
match to MTK
MT6611
Bluetooth
chipset
2.8
35(880~960MHz)
30(1710~1880MHz)
20(1880~1900MHz)
30(4800~5000MHz)
2.1
180°± 10
2
2.00x1.25x0.90
A-1
3.5
35(880~960MHz)
30(1710~1880MHz)
20(1880~1900MHz)
40(4800~5000MHz)
2.0
180°± 10
2
2.00x1.25x1.00
A-1
RFBPB2012100A6T
2.4~2.5
50
Conjugate
match to
BC series of
Bluetooth
chipset
RFBPB2012110A5T
2.4~2.5
50
50
2.8
30(880~960 MHz)
30(1710~1880 MHz)
20(1880~1990 MHz)
30(4800~5000 MHz)
2.0
180°± 10
2
2.00x1.25x1.10
A-1
RFBPB2520090A7T
2.4~2.5
50
Conjugate
match to
TI BRF6150
3.5
35(880~960MHz)
30(1710~1880MHz)
25(1880~1990MHz)
25(4800~5000MHz)
2.0
180°± 15
1.5
2.50x2.00x0.90
A-2
31
HIGH FREQUENCY
RFBPB2012090A1T
RFBPB2012090A9T
RFBPB2012060ABT
RFBPB2012080AET
RFBPB2012090AHT
32
HIGH FREQUENCY
RFBPB2012090AM1T59
RFBPB2012090AM1T61
RFBPB2012100A6T
RFBPB2012090AM1T61
33
HIGH FREQUENCY
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-3
STRUCTURE C
STRUCTURE
A-2
STRUCTURE A-4
STRUCTURE B
STRUCTURE B-1
STRUCTURE D
STRUCTURE E
STRUCTURE F
STRUCTURE B-2
STRUCTURE G
STRUCTURE H
STRUCTURE I
34
HIGH FREQUENCY
Structure\Dimension
A
B
C
D
E
L
1.60±0.15
Unit: mm
W
0.80±0.15
A
B
C
D
E
0.20±0.10
0.24±0.10
0.24±0.10
0.50±0.10
0.15±0.10
F
0.60±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.65±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.70max.
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.90±0.10
0.20±0.10
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.10
0.20±0.10
0.95±0.10
0.20±0.10
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.10
0.20±0.10
1.05±0.10
0.20±0.10
0.30±0.10
0.35±0.10
0.65±0.10
0.20±0.10
0.20±0.10
1.00±0.20
0.10min.
0.55±0.15
0.45±0.15
1.00±0.15
0.30±0.15
0.70±0.20
2.00±0.15
1.25±0.10
3.20±0.20
2.50±0.20
1.00±0.10
0.50±0.10
0.40±0.10
0.35±0.10
0.30±0.10
0.15±0.10
0.15±0.10
0.30±0.10
1.60±0.15
0.80±0.15
0.50max.
0.45±0.15
0.70±0.15
0.20±0.15
0.20±0.15
0.30±0.15
0.25±0.15
0.65±0.10
0.50±0.10
0.40max.
0.225±0.10
0.20±0.05
0.10±0.05
0.25±0.05
0.025±0.25
0.65max.
0.23±0.05
0.40±0.10
0.30±0.10
0.65±0.10
0.20±0.05
0.23±0.05
1.60±0.15
1.60±0.10
0.80±0.15
0.80±0.10
F
G
T
0.50max.
2.00±0.15
1.25±0.10
1.00±0.10
0.50±0.10
H
3.20±0.20
2.50±0.20
I
1.60±0.15
0.80±0.10
0.60±0.10
0.23±0.05
0.40±0.10
0.30±0.10
0.65±0.10
0.20±0.05
0.23±0.05
0.70max.
0.25±0.10
0.40±0.10
0.23±0.10
0.55±0.10
0.21±0.10
0.195±0.10
0.55±0.10
0.25±0.10
00.230.10
0.40±0.10
0.12±0.10
0.125±0.10
0.60±0.10
0.25±0.10
0.25±0.10
0.40±0.10
0.10±0.05
0.10±0.05
0.90±0.10
0.95±0.10
0.275±0.10
0.25±0.10
0.60±0.10
0.175±0.10
0.15±0.10
0.15±0.10
0.65max.
1.00max.
0.95±0.10
0.275±0.10
0.25±0.10
0.60±0.10
0.175±0.10
0.40 max.
0.18±0.05
0.18±0.05
0.05±0.05
0.125±0.05
0.15±0.05
0.05±0.05
1.00±0.20
0.95±0.20
0.60±0.20
0.30±0.15
0.70±0.15
1.20±0.15
2.00±0.15
1.80±0.20
0.95±0.20
0.60±0.20
0.30±0.15
0.70±0.15
1.20±0.15
2.00±0.15
0.70±0.10
0.20±0.10
0.50±0.10
0.35±0.10
0.15±0.10
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
Structure
RFLPF06050G9D0T
824~915
0.5max.(25℃)
0.7max.(-40~+85℃)
20(2400~2750MHz)
2.0
50
0.65x0.50x0.40
D
RFLPF06050G9D2T
699~960
0.5max.(25℃)
0.7max.(-40~+85℃)
20(2400~2750MHz)
2.0
50
1.00x0.50x0.40
D
RFLPF10050G9D0T
824~915
0.6
25(1648~1830MHz)
25(2472~2745MHz)
25(3296~3660MHz)
2.0
50
1.00x0.50x0.40
C
RFLPF10050G9D3T
824~915
0.5max.(25℃)
0.7max.(-40~+85℃)
25(1648~1830MHz)
25(2472~2745MHz)
25(3296~3660MHz)
2.0
50
1.00x0.50x0.40
C
RFLPF10050G9D4T
699~915
0.5max.(25℃)
0.7max.(-40~+85℃)
25(1648~1830MHz)
25(2472~2745MHz)
25(3296~3660MHz)
2.0
50
1.00x0.50x0.40
C
RFLPF10050G9D58Q1C
814~915
0.5max.(25℃)
0.65max.(-40~+85℃)
18(1648~1830MHz)
17(2472~2745MHz)
2.0
50
1.00x0.50x0.40
C
RFLPF16080G9D4T
698~960
0.60(698~830MHz)
0.70(830~900MHz)
0.75(900~915MHz)
0.90(915~960MHz)
30(1554~1830MHz)
35(2097~2745MHz)
1.6
50
1.60x0.80x0.65
A-3
RFLPF16080G9DET
698~960
0.4max.(25℃)
0.45max.(-40~+85℃)
15(1574~1605MHz)
23(1648~1830MHz)
23(1805~1850MHz)
23(4944~5850MHz)
2.0
50
1.60x0.80x0.60
E
RFLPF16080G9DJT
434~960
0.6max.(25℃)
0.8max.(-40~+85℃)
25(1554~1610MHz)
30(1710~2700MHz)
2.0
50
1.60x0.80x0.65
A-1
RFLPF16080G9DM1T58
698~960
0.8
16(1565~1610MHz)
32(2110~2155MHz)
2.0
50
1.60x0.80x0.50
A-4
RFLPF10050G9DM1T76
698~960
0.6max.(25℃)
0.65max.(-40~+85℃)
13 (1554~1610MHz)
35(1805~1830MHz)
35(2110~2170MHz)
30(1710~2700MHz)
2.0
50
1.00x0.50x0.40
G
RFLPF20120G9D0T
890~915
0.6max.(25℃)
0.75max.(-40~+85℃)
30(1780~1830MHz)
30(2670~2745MHz)
2.0
50
2.00x1.25x0.95
B-2
RFLPF20120G9D1T
890~915
0.6max.(25℃)
0.75max.(-40~+85℃)
40(1720~1765MHz)
30(1780~1830MHz)
30(2670~2745MHz)
2.0
50
2.00x1.25x0.95
B-2
35
HIGH FREQUENCY
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
RFLPF10051G8D0T
1710~1910
0.8
RFLPF10051G8DM5T51
1710~1910
0.6
RFLPF10051G8D8T
1880~2025
RFLPF16081G8D3T
RFLPF16081G8D78Q1C
Attenuation
( dB min. )
35(3420~3570MHz)
35(3700~3820MHz)
35(5130~5730MHz)
VSWR
(max.)
Impedance
(Ω)
Size(mm)
Structure
2.0
50
1.00x0.50x0.40
C
26(3420~3570MHz)
21(3700~3820MHz)
21(5130~5730MHz)
2.0
50
1.00x0.50x0.40
C
1.4max.(25℃)
1.6max.(-40~+85℃)
10(2400~2500MHz)
22(3760~4050MHz)
22(5150~5850MHz)
22(5640~6075MHz)
2.0
50
1.00x0.50x0.40
G
1710~1910
0.45max.(25℃)
0.55max.(-40~+85℃)
30(3420~3570MHz)
25(3700~3820MHz)
25(5130~5730MHz)
2.0
50
1.60x0.80x0.50
C
1880~2025
1.4
25(2400~2500MHz)
18(4020~4045MHz)
25(6030~6075MHz)
2.0
50
1.60x0.80x0.60
F
RFLPF16081G8DC8Q1C
1880~2170
0.60(1880~1920MHz)
0.70(1920~1980MHz)
0.80(2010~2170MHz)
2.00(2025~2170MHz)
15(2400~2500MHz)
20(3760~4050MHz)
12(5150~5850MHz)
12(5640~6075MHz)
5(7520~8100MHz)
2.0
1.60x0.80x0.60
E
RFLPF16081G8DHT
1710~1990
0.6max.(25℃)
0.8max.(-40~+85℃)
30.5(3420~3980MHz)
28.5(5130~5970MHz)
25.0(5970~12500MHz)
2.0
50
1.60x0.80x0.70
I
RFLPF20121G8D1T
1880~2025
1.35max.(25℃)
1.50max.(-40~+85℃)
38(2400~2500MHz)
25(4020~4045MHz)
27(6030~6075MHz)
1.9
50
2.00x1.20x0.90
F
VSWR
(max.)
Impedance
(Ω)
Size(mm)
Structure
1.7
50
1.00x0.50x0.40
C
Part Number
Frequency Range
(MHz)
RFLPF1005040A0T
2450±50
RFLPF1005040A1T
RFLPF1005040A2T
Insertion Loss
(dB)
0.45max.(25℃)
0.55max.(-40~+85℃)
Attenuation
( dB min. )
21(4800~5000MHz)
21(7200~7500MHz)
2450±50
0.75
33(4800~5000MHz)
37(7200~7500MHz)
2.0
50
1.00x0.50x0.40
C
2450±50
0.75max.(25℃)
0.90max.(-40~+85℃)
32(4800~5000MHz)
35(7200~7500MHz)
2.0
50
1.00x0.50x0.40
C
2.0
50
1.60x0.80x0.70
A-1
RFLPF1608060AAT
2450±50
0.65
20(3603~3720MHz)
30(4804~4960MHz)
10(6005~6200MHz)
20(7206~7440MHz)
10(8407~8680MHz)
20(9608~9920MHz)
10(10809~11160MHz)
10(12010~12400MHz)
10(13211~13640MHz)
15(14412~14880MHz)
10(15613~16120MHz)
10(16814~17360MHz)
RFLPF1608060ABT
2450±50
0.50
35(4800~5000MHz)
25(7200~7500MHz)
2.0
50
1.60x0.80x0.60
A-1
RFLPF1608060A0T
2450±50
0.65
(typ.0.48)
35(4800MHz(typ.40))
27(7200MHz(typ.40))
1.5
50
1.60x0.80x0.60
A-1
RFLPF1608060A1T
2450±50
0.6
27(4800~5000MHz)
30(7200~7500MHz)
2.0
50
1.60x0.80x0.60
A-2
1.5
50
1.60x0.80x0.60
A-1
RFLPF1608060A2T
2450±50
0.42
25(4800MHz)
18(7200MHz)
RFLPF1608060A9T
2450±50
0.50max.(25℃)
0.60max.(-40~+85℃)
20(3400MHz)
20(3600MHz)
30(4800~5000MHz)
30(7200~7500MHz)
2.0
50
1.60x0.80x0.60
E
RFLPF2012110A0T
2450±50
0.7
30(2x(fo±BW/2))
20(3x(fo±BW/2))
1.5
50
2.00x1.25x1.05
B-1
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
Structure
2.0
50
1.60x0.85x0.50
C
2.0
50
2.00x1.25x0.90
B-1
Part Number
Frequency Range
(MHz)
RFLPF1608050K0T
5400±500
0.60(25℃)
0.70(-40~+85℃)
25(9800MHz)
30(11900MHz)
20(17850MHz)
(for reference)
RFLPF2012090K0T
5400±500
0.55(25℃)
0.65(-40~+85℃)
30(9800MHz)
30(11800MHz)
20(17550MHz
(for reference)
36
HIGH FREQUENCY
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
Structure
RFLPF1005040YM1T76
746~878
0.60(25℃)
0.65(-40~+85℃)
30(1554~1610MHz)
25(2238~2361MHz)
2.0
50
1.00x0.50x0.40
G
RFLPF1608060Y08Q1C
470~787
0.65(25℃)
0.71(-40~+85℃)
26(1429~1501MHz)
30(1565~1607MHz)
35(1570~1580MHz)
18(1920~1980MHz)
2.0
50
1.60x0.85x0.65
A-3
RFLPF1608060Y18Q1C
698~960
0.60(698~830MHz)
0.70(830~900MHz)
0.75(900~915MHz)
0.90(915~960MHz)
30(1554~1830MHz)
35(2097~2745MHz)
1.6
50
1.60x0.85x0.65
A-3
RFLPF2012090Y2T
400~470
0.50(25℃)
0.65(-40~+85℃)
33(800~940MHz)
2.0
50
2.00x1.25x0.90
F
RFLPF2012090Y3T
500~700
0.65(25℃)
0.80(-40~+85℃)
33(1000~1400MHz)
2.0
50
2.00x1.25x0.90
F
RFLPF2012100Y0T
DC~500
0.70
9(824~960MHz)
25(1710~1990MHz)
25(2400~4000MHz)
2.0
50
2.00x1.25x0.95
B-2
RFLPF1608060E0T
1400~2690
0.25(25℃)
0.30(-40~+85℃)
25(4905~5845MHz)
1.92
50
1.60x0.85x0.65
F
RFLPF1608060F0T
600~2700
0.50
30(4800~8000MHz)
25(8500~12500MHz)
2.0
50
1.60x0.85x0.65
F
0.50
35(4950~6000MHz)
35(6000~7500MHz)
35(7500~8100MHz)
35(8100~10500MHz)
27(10500~12500MHz)
2.0
50
1.60x0.85x0.65
F
RFLPF1608060F18Q1C
673~2690
RFLPF1608060F88Q1C
10~2700
0.5
30(4900~5950MHz)
2.0
50
1.60x0.85x0.65
E
673~2690
0.25(25℃)
0.35(-40~+85℃)
25(4905~5845MHz)
1.92
50
1.60x0.85x0.65
F
1.30(25℃)
1.50(-40~+85℃)
15(2400~2500MHz)
25(3250~3350MHz)
25(3420~3570MHz)
23(3700~3820MHz)
23(3840~3960MHz)
23(4100~4600MHz)
25(4905~5845MHz)
23(5850~6400MHz)
20(6600~7350MHz)
1.56
50
2.00x1.25x1.00
B-2
10(2400~2500MHz)
23(3250~3350MHz)
20(3420~3570MHz)
18(3700~3820MHz)
18(3840~3960MHz)
18(4100~4600MHz)
20(4905~5845MHz)
18(5850~6400MHz)
5(6600~7350MHz)
2.0
50
2.00x1.25x1.00
F
2.0
50
1.60x0.80x0.60
A-2
2.0
50
1.60x0.80x0.60
A-2
RFLPF1608060FAT
RFLPF2012100F18Q1C
1710~2170
RFLPF2012100F28Q1C
DC~2170
0.75(25℃)
0.85(-40~+85℃)
RFLPF16082G6W0T
2400~2690
0.6
RFLPF16082G6W2T
2300~2700
0.40(25℃)
0.43(-40~+85℃)
RFLPF16082G5W0T
2300~2700
0.90(25℃)
1.00(-40~+85℃)
30(4600~5400MHz)
30(6900~8100MHz)
20(9200~10800MHz)
15(11500~13500MHz)
1.8
50
1.60x0.80x0.60
A-1
RFLPF16082G5WM0T29
2300~2690
0.80
(typ.0.40)
25(4600~5400MHz)
25(6900~8070MHz)
2.0
50
1.60x0.80x0.60
A-1
1.9
50
1.60x0.80x0.60
A-3
26(4800~5390MHz)
23(7200~8085MHz)
21(4600~5400MHz)
22(6900~8100MHz)
RFLPF16083G5W7T
3300~3800
0.55
17(6600~7600MHz)
20(9900~11400MHz)
RFLPF2012090BM0T29
800~1000
1700~1910
2010~2025
0.5(800~1000MHz)
0.8(1700~1910MHz)
1.5(2010~2025MHz)
20(2300~3700MHz)
30(3700~4100MHz)
20(4100~6100MHz)
10(6100~8000MHz)
2.0
50
2.00x1.25x0.90
F
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
Attenuation
( dB min. )
VSWR
(max.)
Impedance
(Ω)
Size(mm)
Structure
RFLPF3225180Y1T
54~870
2.5
35(975~1675MHz)
2.0
75
3.20x2.50x1.80
H
RFLPF3225100Q07B1U
5~1002
2.4(25℃)
2.6(-40~+85℃)
36(1125~1675MHz)
2.0
75
3.20x2.50x1.00
H
RFLPF3225100Q2T
5~1002
2.4(25℃)
2.6(-40~+85℃)
28(1125~1675MHz)
1.9
75
3.20x2.50x1.00
B-1
RFLPF3225200Q5T
5~1002
1.8(25℃)
2.05(-40~+85℃)
33(1125~1400MHz)
26(1400~1675MHz)
2.0
75
3.20x2.50x1.80
H
MoCA APPLICATION
37
HIGH FREQUENCY
RFLPF06050G9D0T
RFLPF06050G9D2T
RFLPF10050G9D0T
RFLPF10050G9D3T
RFLPF10050G9D4T
RFLPF10050G9D58Q1C
RFLPF16080G9D4T
RFLPF16080G9DET
RFLPF16080G9DJT
RFLPF16080G9DM1T58
38
HIGH FREQUENCY
39
RFLPF10050G9D8T
RFLPF20120G9D0T
RFLPF20120G9D1T
RFLPF10051G8D0T
RFLPF10051G8DM5T51
RFLPF10051G8D8T
RFLPF16081G8D3T
RFLPF16081G8D78Q1C
RFLPF16081G8DC8Q1C
RFLPF20121G8D1T
HIGH FREQUENCY
RFLPF1005040A0T
RFLPF1005040A1T
RFLPF1005040A2T
RFLPF1608060AAT
RFLPF1608060ABT
RFLPF160806A0T
RFLPF1608060A1T
RFLPF1608060A2T
RFLPF1608060A9T
RFLPF1608050K0T
40
HIGH FREQUENCY
41
RFLPF2012090K0T
RFLPF1005040YM1T76
RFLPF1608060Y08Q1C
RFLPF1608060Y18Q1C
RFLPF2012090Y2T
RFLPF2012090Y3T
RFLPF2012100Y0T
RFLPF1608060E0T
RFLPF1608060F0T
RFLPF1608060F18Q1C
HIGH FREQUENCY
RFLPF1608060F88Q1C
RFLPF1608060FAT
RFLPF2012100F18Q1C
RFLPF2012100F28Q1C
RFLPF16082G6W0T
RFLPF16082G6W2T
RFLPF16082G5W0T
RFLPF16082G5WM0T29
RFLPF16083G5W7T
RFLPF2012090BM0T29
42
HIGH FREQUENCY
43
RFLPF3225180Y1T
RFLPF3225100Q07B1U
RFLPF3225100Q2T
RFLPF3225200Q5T
HIGH FREQUENCY
STRUCTURE A
STRUCTURE B
STRUCTURE C
STRUCTURE D
Structure\
Dimension
L
W
A
0.65 ± 0.10
B
1.60 ± 0.15
C
D
Unit: mm
T
A
B
C
D
E
F
0.50 ± 0.10
0.4 max.
0.225 ± 0.10
0.20 ± 0.05
0.10 ± 0.10
0.20 ± 0.05
0.05 ± 0.05
0.80 ± 0.15
0.60 ± 0.1.0
0.23 ± 0.05
0.40 ± 0.10
0.30 ± 0.10
0.65 ± 0.10
0.20 ± 0.05
0.23 ± 0.05
1.60 ± 0.10
0.80 ± 0.10
0.65 max.
0.65 ± 0.10
0.25 ± 0.10
0.275 ± 0.10
0.40 ± 0.10
0.075 ± 0.05
0.075 ± 0.05
3.20 ± 0.20
2.50 ± 0.20
1.7 max.
0.95 ± 0.20
0.60 ± 0.20
0.30 ± 0.15
0.70 ± 0.15
1.20 ± 0.15
2.00 ± 0.15
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Size
(mm)
Structure
RFHPF16082G5W0T
2496~2690
1.2max.(25℃)
1.3max.(-40~+85℃)
25(1710~1995MHz)
2.0
1.6 X 0.8 X 0.6
B
RFHPF16082G5W1T
2496~2690
0.9max.(25℃)
1.2max.(-40~+85℃)
22(1710~2010MHz)
2.0
1.6 X 0.8 X 0.6
C
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Size
(mm)
Structure
RFHPF0605040K0T
4900~5840
0.60max.(25℃)
0.65max.(-40~+85℃)
14(2400~2500MHz)
1.6
0.65 X 0.5 X 0.4
A
RFHPF0605040K1T
4900~5850
0.65
20(2450~2500MHz)
2.0
0.65 X 0.5 X 0.4
A
Part Number
Frequency Range
(MHz)
Insertion Loss
(dB)
Attenuation
(dB min. )
VSWR
(max.)
Size
(mm)
Structure
RFHPF3225170F07B1U
950~2150
2.00max.(25℃)
2.2max.(-40~+85℃)
50(475~675MHz)
2.0
3.2 X 2.5 X 1.7
D
MoCA Application
44
HIGH FREQUENCY
RFHPF16082G5W0T
RFHPF16082G5W1T
RFHPF0605040K0T
RFHPF0605040K1T
RFHPF3225170F07B1U
45
BALUN TRANSFORMERS
BALUN TRANSFORMERS
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-2
STRUCTURE A-3
STRUCTURE A-4
STRUCTURE B
STRUCTURE B-1
STRUCTURE B-2
STRUCTURE C
STRUCTURE D
STRUCTURE C-1
STRUCTURE C-2
STRUCTURE E
STRUCTURE F
46
BALUN TRANSFORMERS
Structure\
Dimension
L
1.60±0.10
1.60±0.15
A
W
T
0.85±0.10
0.70±0.10
0.20±0.10
0.20±0.10
0.30±0.10
0.50±0.05
0.50±0.05
0.80±0.10
0.50±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.85±0.10
A
C
D
E
F
G
H
0.40 max.
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.65±0.10
1.25±0.15
B
0.60±0.10
0.70±0.10
0.85±0.15
2.00±0.15
Unit: mm
0.80±0.10
0.20±0.20
0.30±0.20
0.35±0.20
0.65±0.20
0.85±0.10
0.20±0.20
0.30±0.20
0.35±0.20
0.65±0.20
0.80±0.10
0.20±0.15
0.30±0.20
0.35±0.20
0.65±0.20
0.95±0.10
0.20±0.20
0.30±0.20
0.35±0.20
0.65±0.20
1.00±0.10
0.50±0.10
0.37±0.10
0.10±0.10
0.30±0.10
0.20±0.10
0.50±0.10
0.125±0.10
1.00±0.10
0.50±0.10
0.40±0.10
0.10±0.10
0.30±0.10
0.20±0.10
0.50±0.10
0.125±0.10
C
2.00±0.10
1.25±0.15
0.90±0.10
0.125±0.10
0.25±0.10
0.25±0.10
0.50±0.10
0.475±0.10
0.30±0.10
0.20±0.15
0.20±0.15
D
1.60±0.15
0.80±0.15
0.50±0.10
0.175±0.10
0.25±0.10
0.25±0.10
0.50±0.10
0.25±0.10
E
0.65±0.10
0.50±0.10
0.40±0.10
0.20±0.05
0.20±0.05
0.025±0.025
0.10±0.05
0.25±0.05
0.025±0.025
F
1.00±0.10
0.50±0.10
0.5 max.
0.35±0.10
0.30±0.10
0.15±0.10
0.15±0.10
0.30±0.10
B
ISM Band 2.4GHz APPLICATION
Impedance(Ω)
Part Number
Frequency
Range
(MHz)
Balance
Return Loss
(dB) Min.
Insertion Loss
(dB)
Amplitude
Difference
(dB) Max.
Unbalance
Phase
Difference
Size(mm)
Structure
RFBLN1005040A6T
2400~2500
50
50
10
0.8
2.0
180± 10
1.00x0.50x0.40
B-2
RFBLN1608050AAT
2400~2500
50
Conjugate match to
AR6003 chipset
10
1.2
2.0
180± 10
1.60x0.80x0.50
D
RFBLN1608050AM8T62
2400~2500
50
50
10
1.2
2.0
180± 10
1.60x0.80x0.50
A-2
RFBLN1608050AM0T63
2400~2500
50
50
10
1.0
1.0
180± 10
1.60x0.80x0.55
A-2
RFBLN1608050AM6T30
2400~2500
50
35
10
1.0
1.0
180± 10
1.60x0.80x0.55
A-2
RFBLN1608060AC6T40
2400~2500
50
Conjugate match to
TI CC26XX Chipset
10
1.6(25℃)
1.8(-40~+85℃)
2.3
180± 18
1.60x0.80x0.60
A-3
RGBLN1608070A1T
2400~2500
50
100
10
1.5
2.0
180± 15
1.60x0.85x0.70
A-1
RGBLN1608070A5T
2400~2500
50
100
10
1.2
2.0
180± 10
1.60x0.80x0.70
A-2
RGBLN2012080A5T
2400~2500
50
50
12
1.0
1.0
180± 10
2.00x1.25x0.85
A-2
RFBLN2012080A7T
2400~2500
50
100
10
1.0
2.0
180± 10
2.00x1.25x0.80
A-2
RGBLN2012090A0T
2400~2500
50
50
10
1.2
2.0
180± 10
2.00x1.25x0.95
A-2
RFBLN2012090A1T
2400~2500
50
100
10
1.0
2.0
180± 10
2.00x1.25x0.95
A-2
Insertion Loss
(dB)
Amplitude
Difference
(dB) Max.
Phase
Difference
Size
(mm)
Structure
ISM Band 5GHz APPLICATION
47
Part Number
Frequency
Range
(MHz)
Unbalance
Balance
Return Loss
(dB) Min
RFBLN1005040K1T
4900~5950
50
50
10
1.2
2.0
180± 10
1.00x0.50x0.40
B-2
RFBLN1005040K5T
4900~5950
50
100
10
0.55(25℃)
0.75(-40~+85℃)
2.5
180± 10
1.00x0.50x0.40
B-2
RFBLN1005040K6T
4900~5950
50
50
10
0.60(25℃)
0.80(-40~+85℃)
2.5
180± 15
1.00x0.50x0.40
B-2
RFBLN2012090K1T
4900~5900
50
100
10
1.2
2.0
180± 10
2.00x1.25x0.95
A-4
Impedance(Ω)
BALUN TRANSFORMERS
LTE Band APPLICATION
Part Number
Frequency
Range
(MHz)
Unbalance
Balance
Return Loss
(dB)Min
Amplitude
Difference
(dB) Max.
Phase
Difference
Size
(mm)
Structure
RFBLN0605040Y1T
717~821
50
100
15
2.0
180± 10
0.65x0.50x0.40
E
RFBLN0605040YM9T16
729~821
50
100
10
2.0
180± 10
0.65x0.50x0.40
E
RFBLN1005040YM1T69
703~803
50
100
10
2.0
180± 12
1.00x0.50x0.40
F
RFBLN06050G9D0T
729~960
50
100
15
4.8
180± 10
0.65x0.50x0.40
E
RFBLN16080G9D2T
699~960
50
100
10
2.5
180± 15
1.60x0.80x0.70
A-4
RFBLN16080G9D3T
824~894
50
50
10
1.2
1.0
180± 10
1.60x0.80x0.60
A-2
RFBLN20120G9D0T
824~894
50
100
10
1.2
1.0
180± 10
2.00x1.25x0.90
A-2
RFBLN20120G9D5T
880~960
50
100
10
1.1
1.0
180± 10
2.00x1.25x0.90
A-2
RFBLN20120G9D8T
800~1000
50
50
10
1.2
2.0
180± 10
2.00x1.25x0.90
A-2
1.8
180± 10
0.65x0.50x0.40
E
3.0
180± 15
0.65x0.50x0.40
E
2.0
180± 10
2.00x1.25x0.95
A-2
2.0
180± 10
1.00x0.50x0.40
B-2
2.2
180± 12
1.00x0.50x0.40
B-2
1.2
180± 15
1.00x0.50x0.40
F
1.5
180± 17
1.60x0.80x0.70
A-4
2.0
180± 10
1.60x0.80x0.60
A-2
Impedance(Ω)
RFBLN06051G8DM1T69
1805~1990
50
100
10
RFBLN06051G8D1T
1805~2170
50
100
10
RFBLN20121G8D1T
1700~2000
50
100
10
Insertion Loss
(dB)
0.55(25℃)
0.65(-40~+85℃)
0.55(25℃)
0.65(-40~+85℃)
0.8
0.85(25℃)
0.95(-40~+85℃)
1.05(25℃)
1.15(-40~+85℃)
0.60(25℃)
0.65(-40~+85℃)
0.65(25℃)
0.70(-40~+85℃)
1.0
0.65(25℃)
0.75(-40~+85℃)
0.60(25℃)
0.70(-40~+85℃)
0.70(25℃)
0.80(-40~+85℃)
1.7(25℃)
2.0(-40~+85℃)
1.20(25℃)
1.40(-40~+85℃)
RFBLN10051G9D0T
1805~2020
50
100
10
RFBLN10051G9D1T
1805~1990
50
100
10
RFBLN1005040F0T
1805~2170
50
100
10
RFBLN1608070F48Q1C
673~2700
50
100
10
RFBLN1608060FET
1710~2200
50
50
10
RFBLN2012090F0T
1920~1980
2110~2170
50
50
10
1.0
2.0
180± 10
2.00x1.25x0.95
A-2
RFBLN0605040E0T
2000~2500
50
100
10
0.60(25℃)
0.70(-40~+85℃)
3.5
180± 10
0.65x0.50x0.40
E
RFBLN2012090E0T
1500~3000
50
100
10
1.0
2.0
180± 10
2.00x1.25x0.90
A-4
2.5
180± 10
0.65x0.50x0.40
E
2.5
180± 10
1.00x0.50x0.40
B-1
2.5
180± 10
1.00x0.50x0.40
B-2
2.0
180± 10
1.60x0.80x0.70
A-2
0.55(25℃)
0.65(-40~+85℃)
0.55(25℃)
0.65(-40~+85℃)
0.65(25℃)
0.75(-40~+85℃)
RFBLN06052G5WM9T16
2300~2690
50
100
10
RFBLN10052G5WM9T16
2300~2690
50
100
10
RFBLN10052G5W37N2T
2300~2690
50
100
10
RFBLN16082G5W0T
2300~2700
50
100
10
1.1
1.0
180± 10
1.60x0.80x0.40
A-4
2.0
180± 10
1.60x0.80x0.50
A-2
RFBLN16082G5W38Q1C
2300~2700
50
100
10
0.55(25℃)
0.65(-40~+85℃)
RFBLN16082G5W4T
2300~2700
50
50
10
1.2
GSM 850/ GSM 900/ DCS1800/ PCS1900 APPLICATION
Part Number
Frequency
Range
(MHz)
Unbalance Balance
Return
Loss
(dB) Min
Insertion Loss
(dB)
Amplitude
Difference
(dB) Max
869~960
50
200
10
1.1
2.0
1805~2025
50
200
10
1.8
2.0
869~960
50
200
10
1.1(25℃)
1.3(-40~+85℃)
2.0
1805~1990
50
200
10
1.6(25℃)
1.8(-40~+85℃)
2.0
869~960
50
200
10
1.1(25℃)
1.3(-40~+85℃)
2.0
1805~2025
50
200
10
1.8(25℃)
2.0(-40~+85℃)
2.0
RFBLN2012090BM5T25
RFBLN2012090BS0T53
RFBLN2012090BS0T50
Attenuation
(dB min.)
10(1738~1920MHz)
20(2400~2500MHz)
20(2607~2880MHz)
15(2400~2500MHz)
20(3610~3980MHz)
20(5415~5970MHz)
10(1738~1920MHz)
20(2400~2500MHz)
20(2607~2880MHz)
15(2400~2500MHz)
15(3610~3980MHz)
20(5415~5970MHz)
10(1738~1920MHz)
20(2400~2500MHz)
20(2607~2880MHz)
15(2400~2500MHz)
15(3610~3980MHz)
20(5415~5970MHz)
Phase
Difference
Size(mm)
Structure
2.00x1.25x0.95
C-1
2.00x1.25x0.95
C-1
2.00x1.25x0.95
C-2
180± 10
180± 15
180± 15
180± 15
180± 15
180± 15
48
BALUN TRANSFORMERS
RFBLN1005040A6T
RFBLN1608050AAT
RFBLN1608050AM8T62
RFBLN1608050AM0T63
RFBLN2012080A7T
49
BALUN TRANSFORMERS
RGBLN2012090A0T
RFBLN1005040K1T
RFBLN1005040K5T
RFBLN0605040Y1T
RFBLN0605040YM9T16
50
BALUN TRANSFORMERS
RFBLN1005040YM1T69
RFBLN06050G9D0T
RFBLN16080G9D2T
RFBLN16080G9D3T
RFBLN20120G9D0T
51
BALUN TRANSFORMERS
RFBLN20120G9D5T
RFBLN20120G9D8T
RFBLN06051G8DM1T69
RFBLN06051G8D1T
RFBLN20121G8D1T
52
BALUN TRANSFORMERS
RFBLN10051G9D0T
RFBLN10051G9D1T
RFBLN1005040F0T
RFBLN1608070F48Q1C
RFBLN2012090F0T
53
BALUN TRANSFORMERS
RFBLN0605040E0T
RFBLN2012090E0T
RFBLN06052G5WM9T16
RFBLN10052G5WM9T16
RFBLN10052G5W37N2T
54
BALUN TRANSFORMERS
RFBLN16082G5W0T
RFBLN16082G5W38Q1C
RFBLN2012090BM5T25
Low Band
High Band
RFBLN2012090BS0T53
Low Band
55
High Band
DIPLEXER
DIPLEXER
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-2
STRUCTURE A-3
STRUCTURE A-4
STRUCTURE B
STRUCTURE C
STRUCTURE D
STRUCTURE E
STRUCTURE B-1
STRUCTURE C-1
STRUCTURE D-1
STRUCTURE E-1
STRUCTURE B-2
STRUCTURE C-2
STRUCTURE D-2
STRUCTURE E-2
STRUCTURE F
STRUCTURE G
STRUCTURE H
56
DIPLEXER
Structure\
Dimension
A
B
Unit: mm
L
W
T
A
B
C
D
E
F
1.60±0.15
0.80±0.15
0.60±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
2.00±0.10
1.25±0.20
0.55±0.15
0.20±0.15
0.30±0.15
0.35±0.15
0.65±0.15
0.20±0.10
2.00±0.15
1.25±0.15
0.95±0.10
0.20±0.20
0.30±0.20
0.35±0.20
0.65±0.20
1.60±0.15
0.80±0.15
0.60±0.10
0.65±0.15
0.30±0.15
0.20±0.15
0.20±0.15
0.25±0.15
0.30±0.15
0.70±0.10
0.35±0.10
0.30±0.10
0.65±0.10
0.60±0.10
0.275±0.10
0.90±0.10
0.35±0.10
0.30±0.10
0.65±0.10
0.60±0.10
0.275±0.10
2.00±0.15
1.25±0.15
2.50±0.15
2.00±0.15
0.80±0.15
0.30±0.15
0.35±0.15
0.65±0.15
0.75±0.15
0.525±0.15
D
1.60±0.15
0.80±0.15
0.60±0.10
0.175±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
E
2.50±0.15
2.00±0.15
0.70±0.10
0.30±0.10
0.40±0.10
0.60±0.10
1.10±0.10
C
F
2.50±0.15
2.00±0.15
1.0max.
0.375±0.15
0.25±0.15
0.25±0.15
0.50±0.15
0.20±0.15
G
1.60±0.15
0.80±0.15
0.60±0.10
0.65±0.15
0.30±0.15
0.20±0.15
0.20±0.15
0.25±0.15
0.30±0.15
H
1.00±0.10
0.50±0.10
0.40max.
0.10±0.10
0.30±0.10
0.20±0.10
0.50±0.10
0.125±0.10
ISM Band 2.4GHz/5GHz APPLICATION
Part Number
Frequency
(MHz)
Impedance Insertion Loss
(Ω)
(dB)
2400~2500
50
0.5(25℃)
0.6(-40~+85℃)
25(4800~6000MHz)
25(7200~7500MHz)
4900~5900
50
0.8(25℃)
1.3(-40~+85℃)
27(30~2400MHz)
30(2400~2500MHz)
24(2500~2690MHz)
20(9800~11900MHz)
2400~2500
50
0.6
20(4800~5000MHz)
20(7200~7500MHz)
RFDIP1004L10AT
RFDIP1608060LCT
4900~5900
50
1.4
28(30~2700MHz)
10(9800~11900MHz)
2400~2500
50
0.6
18(4800~5000MHz)
18(7200~7500MHz)
4900~5900
50
1.4
20(3700~3900MHz)
20(1800~2500MHz)
10(9800~11800MHz))
2400~2500
50
0.6
18(4800~5000MHz)
18(7200~7500MHz)
4900~5900
50
1.4
20(3700~3900MHz)
20(1800~2500MHz)
10(9800~11800MHz)
0.5
10(3600~3750MHz)
20(4800~5000MHz)
20(5000~5950MHz)
10(7200~7500MHz)
10(9600~10000MHz)
RFDIP1608060LET
RFDIP1608060LFT
2400~2500
50
RFDIP160806BLM6T25
4900~5950
50
0.6
2400~2500
50
0.5
25(860~960MHz)
25(1545~1605MHz)
25(1710~1990MHz)
30(2170 MHz)
10(8100~8800MHz)
15(8820~9800MHz)
25(9800~11900MHz)
10(3600~3750MHz)
20(4800~5000MHz)
20(5000~5950MHz)
10(7200~7500MHz)
10(9600~10000MHz)
4900~5950
50
0.6
25(860~960MHz)
25(1545~1605MHz)
25(1710~1990MHz)
30(2170MHz)
10(8100~8800MHz)
15(8820~9800MHz)
25(9800~11900MHz)
2400~2500
50
0.75(25℃)
0.95(-40~+85℃)
20(4800~5000MHz)
20(7200~7500MHz)
4900~5950
50
1.0(25℃)
1.3(-40~+85℃)
20(1800~2500MHz
20(9800~11800MHz
RFDIP160806ALM6T30
RFDIP1608060LM0T60
57
Attenuation
( dB )
Return Loss
(dB) Min
Isolation
Size (mm)
Structure
10
1.00x0.50x0.40
H
10
28(30~2700 MHz)
26(4900~5950 MHz)
1.60x0.80x0.60
A-4
10
1.60x0.80x0.60
A-1
10
1.60x0.80x0.60
A-2
1.60x0.80x0.60
A-1
1.60x0.80x0.60
A-2
1.60x0.80x0.60
A-2
10
25(4800~5000 MHz)
10
25(4800~5000 MHz)
10
DIPLEXER
ISM Band 2.4/5GHz Application
Part Number
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
(dB)
2400~2500
50
0.50(25℃)
0.65(-40~+85℃)
21(4800~5000MHz)
21(5000~5950MHz)
25(7200~7500MHz)
4900~5950
50
0.60(25℃)
0.75(-40~+85℃)
27(824~2170MHz)
30(2400~2500MHz
20(9800~11900MHz
2400~2500
50
0.6
RFDIP160806BLM6T68
RFDIP1608060LVT
4900~5950
50
0.8
32(30~2700MHz)
15(9800~11900MHz)
11(14700~17850MHz)
2400~2500
50
0.5(25℃)
0.6(-40~+85℃)
22(4800~5000MHz)
24(7200~7500MHz)
5100~5900
50
1.1(25℃)
1.3(-40~+85℃)
25(1800~2500MHz)
24(3700~3900MHz)
22(9800~11900MHz)
2400~2496
50
0.5
35(4800~5000MHz)
15(7200~7500MHz)
RFDIP1608060LST
5150~5950
50
1.0
30(70~2000MHz)
30(2400~2690MHz
12(7250~7800MHz
25(10300~12000MHz)
10(15000~18000MHz)
2400~2500
50
0.55(25℃)
0.60(-40~+85℃)
29(4800~5000MHz)
24(7200~7500MHz)
4900~5950
50
0.70(25℃)
0.80(-40~+85℃)
32(30~2700MHz)
15(9800~11900MHz)
11(14700~17850MHz)
2400~2500
50
0.6
23(4800~5000MHz)
30(7200~7500MHz)
25(2400~2500MHz)
15(3400~3600MHz)
10(3600~3900MHz)
20(6900~7550MHz)
30(10600~11700MHz)
20(15300~16200MHz)
RFDIP1608060LY8Q1C
RFDIP1606L168M1U
RFDIP1606L23T
5150~5850
50
1.5
2400~2500
50
0.5
5150~5850
50
0.6
2400~2500
50
0.75(25℃)
0.95(-40~+85℃)
23(4800~5000MHz)
30(7200~7500MHz)
25(2400~2500MHz)
15(3400~3600MHz)
10(3600~3900MHz)
20(6900~7550MHz)
30(10600~11700MHz)
20(15300~16200MHz)
25(4800~5000MHz)
20(7200~7500MHz)
4900~5950
50
1.10(25℃)
1.30(-40~+85℃)
20(1800~2500MHz)
15(9800~11900MHz)
2400~2500
50
0.35(25℃)
0.45(-40~+85℃)
20(4800~5000MHz)
22(5000~5950MHz)
20(7200~7500MHz)
4900~5850
50
0.50(25℃)
0.60(-40~+85℃)
26(824~2170MHz)
30(2400~2500MHz)
25(9500~11900MHz)
2400~2500
50
0.40(25℃)
0.45(-40~+85℃)
21(4800~5000MHz)
23(5000~5500MHz)
28(5500~5950MHz)
21(7200~7500MHz)
0.50(25℃)
0.60(-40~+85℃)
27(824~2170MHz)
31(2400~2500MHz)
26(9800~11900MHz)
0.5
10(3600~3750MHz)
20(4800~5000MHz)
20(5000~5950MHz)
10(7200~7500MHz)
10(9600~10000MHz)
0.6
25(860~960MHz)
25(1545~1605MHz)
25(1710~1990MHz)
30(2170MHz)
25(2400~2500MHz)
10(8100~8800MHz)
15(8820~9800MHz)
25(9800~11900MHz)
RFDIP1606L24T
RFDIP1606L29T
RFDIP1606L51T
RFDIP1606L52T
4900~5850
2400~2500
50
50
RFDIP1606L53T
5150~5850
50
Return Loss
(dB) Min
Isolation
Size (mm)
Structure
10
32(2400~2500MHz)
25(4900~6000MHz)
10
A-2
10
32 (30~2700 MHz)
28(4900~5950 MHz)
1.60x0.80x0.60
A-4
10
1.60x0.80x0.60
G
12
1.60x0.80x0.60
A-3
10
32(30~2700MHz)
28(4900~5950 MHz)
1.60x0.80x0.60
A-3
10
1.60x0.80x0.60
A-3
10
1.60x0.80x0.60
A-4
10
1.60x0.80x0.60
A-2
10
1.60x0.80x0.60
B-2
10
1.60x0.80x0.60
B-1
10
1.60x0.80x0.60
A-3
58
DIPLEXER
Part Number
Frequency
(MHz)
2400~2500
Impedance
(Ω)
50
Insertion Loss
(dB)
Attenuation
(dB)
0.5
10(3600~3750MHz)
20(4800~5000MHz)
20(5000~5950MHz)
10(7200~7500MHz)
10(9600~10000MHz)
25(860~960MHz)
25(1545~1605MHz)
25(1710~1990MHz)
30(2170MHz)
25(2400~2500MHz)
10(8100~8800MHz)
15(8820~9800MHz)
25(9800~11900MHz)
RFDIP1606L54T
4900~5950
50
0.6
2400~2500
50
0.90(25℃)
1.05(-40~+85℃)
RFDIP1607L898D1T
4900~5950
50
0.80(25℃)
0.95(-40~+85℃)
2400~2500
50
0.48(25℃)
0.58(-40~+85℃)
4900~5950
50
0.68(25℃)
0.78(-40~+85℃)
26(824~2170MHz)
30(2400~2500MHz)
25(9800~11900MHz)
20(15450~17550MHz)
2400~2500
50
0.60(25℃)
0.65(-40~+85℃)
32(4800~4992MHz)
24(7200~7488MHz)
4900~5950
50
0.70(25℃)
0.80(-40~+85℃)
32(30~2700MHz)
15(9800~11900MHz)
11(14700~17850MHz)
2400~2500
50
0.5
10(3600MHz)
20(4800~5000MHz)
20(7200~7500MHz)
RFDIP1606L110C8Q1C
RFDIP1608060LS3T55
KFDIP2004L157B1U
4900~5950
50
1.0
2400~2500
50
0.5
20(824~915MHz)
20(1800~2500MHz)
10(3000~3900MHz)
4(7250MHz)
20(9800~11900MHz)
20(14700~17850MHz)
10(3600MHz)
20(4800~5000MHz)
20(7200~7500MHz)
4900~5950
50
1.0
20(824~915MHz)
20(1800~2500MHz)
10(3000~3900MHz)
4(7250MHz)
20(9800~11900MHz)
20(14700~17850MHz)
2400~2500
50
0.6
15(3600MHz)
25(4800~5000MHz)
20(7200~7500MHz)
KFDIP2004L167B1U
4900~5950
50
1.0
20(824~915MHz)
18(1800~2500MHz)
14(3000~3900MHz)
20(9800~11900MHz)
20(14700~17850MHz)
2400~2500
50
0.7
18(4800~6000MHz)
18(7200~7500 MHz)
4900~5900
50
1.0
19(1800~2500MHz)
25(10300~10700MHz)
2400~2500
50
0.7
18(4800~6000MHz)
18(7200~7500MHz)
4900~5900
50
1.0
19(1800~2500MHz)
25(10300~10700MHz)
2300~2500
50
0.65(25℃)
0.8(-40~+85℃)
20(4600~5000MHz)
20(6900~7500MHz)
4900~5950
50
1.0
19(1800~2500MHz)
25(10300~10700MHz)
KFDIP2004L197B1U
RFDIP2012050L5T
RFDIP2012050L7T
RFDIP2012050L8T
59
15(700~1300MHz)
25(4800~5000MHz)
30(7000~7500MHz)
27(1200~1500MHz)
26(1500~2000MHz)
20(2300~3000MHz)
25(9800~11900MHz)
15(14700~17850MHz)
20(4800~5000MHz)
22(5000~5950MHz)
20(7200~7500MHz)
Return Loss
(dB)Min
Isolation
Size (mm)
Structure
10
1.60x0.80x0.60
A-4
10
30(2400~2500MHz)
25(4900~5950MHz)
1.60x0.80x0.70
A-4
10
1.60x0.80x0.60
A-3
10
32(30~2700MHz)
28(4900~5950MHz)
1.60x0.80x0.60
A-4
10
20(DC~2500MHz)
20(4900~5950MHz)
2.00x1.25x0.40
A-3
10
20(DC~2500MHz)
20(4900~5950MHz)
2.00x1.25x0.40
A-4
10
20(DC~2500MHz)
20(4900~5950MHz)
2.00x1.25x0.40
A-3
10
2.00x1.25x0.55
A-1
10
2.00x1.25x0.55
A-2
10
2.00x1.25x0.55
A-3
DIPLEXER
Part Number
RFDIP2012100L0T
RFDIP2012100L3T
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
(dB)
Return Loss
(dB) Min
Isolation
Size (mm)
Structure
2400~2500
50
0.7
20(4900MHz)
25(5200MHz)
25(5800MHz)
10
2.00x1.25x0.95
A-3
4900~5900
50
0.9
25(2450MHz)
2400~2500
50
0.7
20(4900MHz)
25(5200MHz)
25(5800MHz)
10
2.00x1.25x0.95
A-2
4900~5900
50
0.9
25(2450MHz)
2400~2500
50
0.5(25℃)
0.55(-40~+85℃)
23(4800~6000MHz)
20(7200~7500MHz)
20(800~2500MHz)
15(9800~11900MHz)
2.00x1.25x055
A-1
50
0.65(25℃)
0.75(-40~+85℃)
10
4900~5950
2400~2500
50
0.5(25℃)
0.55(-40~+85℃)
23(4800~6000MHz)
20(7200~7500MHz)
20(800~2500MHz)
15(9800~11900MHz)
2.00x1.25x0.55
A-2
50
0.65(25℃)
0.75(-40~+85℃)
10
4900~5950
2.2(25℃)
2.4(-40~+85℃)
30(824~915MHz)
30(1545~1610MHz)
30(1710~1990MHz)
25(2110~2170MHz)
8(3200~3600MHz)
12(3700~3900MHz)
28(4800~5000MHz)
25(7200~7500MHz)
10
2.00x1.25x0.80
A-1
1.2(25℃)
1.5(-40~+85℃)
20(1545~1610MHz)
20(1710~1990MHz)
20(2110~2170MHz)
23(2400~2500MHz)
8(3450~3900MHz)
8(7250~7800MHz)
20(9800~11700MHz)
2.2(25℃)
2.4(-40~+85℃)
30(824~915MHz)
30(1545~1610MHz)
30(1710~1990MHz)
25(2110~2170MHz)
8(3200~3600MHz)
12(3700~3900MHz)
28(4800~5000MHz)
25(7200~7500MHz)
10
2.00x1.25x0.80
A-2
1.2(25℃)
1.5(-40~+85℃)
20(1545~1610MHz)
20(1710~1990MHz)
20(2110~2170MHz)
23(2400~2500MHz)
8(3450~3900MHz)
8(7250~7800MHz)
20(9800~11700MHz)
2.4(25℃)
2.7(-40~+85℃)
30(824~915MHz)
30(1545~1610MHz)
24(1710~1990MHz)
15(2110~2170MHz)
30(4800~5000MHz)
20(7200~7500MHz)
2.50x2.00x0.70
E-1
2.00x1.25x0.80
E-2
RFDIP2012050LPT
RFDIP2012050LQT
2400~2500
50
RFDIP2008L107N3T
5150~5850
2400~2500
50
50
RFDIP2008L117N3T
5150~5850
2400~2500
50
50
AMDIP2520070L3T
5150~5850
2400~2500
50
50
1.2(25℃)
1.5(-40~+85℃)
25(1545~1610MHz)
25(2400~2500MHz)
15(10300~11700MHz)
2.4(25℃)
2.7(-40~+85℃)
30(824~915MHz)
30(1545~1610MHz)
24(1710~1990MHz)
15(2110~2170MHz)
30(4800~5000MHz)
20(7200~7500MHz)
AMDIP2520070L4T
5150~5850
50
1.2(25℃)
1.5(-40~+85℃)
10
10
25(1545~1610MHz)
25(2400~2500MHz)
15(10300~11700MHz)
60
DIPLEXER
GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application
Part Number
RFDIP1608060T1T
RFDIP1608060TM7T62
RFDIP1608060TAT
RFDIP1608060TCT
RFDIP1608060TDT
RFDIP2012090T2T
RFDIP2520080T1T
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
(dB)
1574~1577
50
0.65
20(2400~2500MHz)
2400~2500
50
0.8
20(1574~1577MHz)
1570~1610
50
0.6(typ.0.5)
20(2400~2500MHz)
20(4900~5900MHz)
2400~2500
4900~5900
50
0.65(typ.0.55)
20(1570~1610MHz)
698~960
1427~1511
1560~1607
50
0.40
0.55
0.65
20(2400~2500MHz)
20(2620~2690MHz)
20(5150~5850MHz)
2400~2500
2620~2690
5150~5850
50
0.70
0.60
0.80
20(698~960MHz)
20(1427~1511MHz)
20(1560~1607MHz)
1570~1610
50
0.6(typ.0.5)
20(2400~2500MHz)
20(4900~5900MHz)
2400~2500
4900~5900
50
0.65(typ.0.55)
20(1570~1610MHz)
1570~1610
50
0.65(25℃)
0.75(-40~+85℃)
13(2170MHz)
20(2400~2500MHz)
2400~2500
50
0.80(25℃)
0.90(-40~+85℃)
20(1565~1616MHz)
15(1710MHz)
1572.5~1578.5
1597~1607
50
0.40
0.50
13(2400~2500MHz)
2400~2500
50
0.55(25℃)
0.65(-40~+85℃)
22(1572.5~1578.5MHz)
20(1597~1607MHz)
1710~1990
1990~2110
2110~2170
50
1.00
1.50
2.50
5(2300~2350MHz)
10(2350~2500MHz)
10(2500~2690MHz)
50
2.65
1.50
0.65
8(1710~1990MHz)
8(1990~2110MHz)
5(2110~2170MHz)
2300~2350
2350~2500
2500~2690
Return Loss
(dB)Min.
Size (mm)
Structure
10
1.60x0.80x0.60
B-1
10
1.60x0.80x0.60
A-4
10
1.60x0.80x0.60
B-1
10
1.60x0.80x0.60
A-4
10
1.60x0.80x0.60
B-2
10
2.00x1.25x0.90
A-3
10
2.50x2.00x0.80
C-2
Return Loss
(dB)Min.
Size (mm)
Structure
10
1.60x0.80x0.60
D-2
10
2.00x1.25x0.70
C-1
10
2.00x1.25x0.90
A-4
10
2.00x1.25x0.90
C-1
10
2.50x2.00x1.00
F
892 MHz & 1.94GHz Band Working Frequency
Part Number
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
(dB)
0.8(typ.0.45)
25(1710~2700MHz)
0.7(typ.0.50)
20(698~960MHz)
20(5150~5850MHz)
0.75
20(1427~2700MHz)
0.85
20(570~960MHz)
0.65
15(1554~1580MHz)
20(1710~2700MHz)
1710~2700
0.65
20(824~960MHz)
698~960
0.4(25℃)
0.45(-40~+85℃
13(1710~2690MHz)
1710~2690
0.55(25℃)
0.65(-40~+85℃
19(698~960MHz)
698~960
0.35(25℃)
0.45(-40~+85℃
20(1710~2690MHz)
0.55(25℃)
0.65(-40~+85℃
25(698~960MHz)
5(3420~3820MHz)
698~960
RFDIP1608070GM1T76
RFDIP2012070G5T
RFDIP2012090G77N2T
1710~2700
570~960
1427~2700
698~960
RFDIP2012090GM1T58
50
50
50
RFDIP2520100G2T
50
1710~2690
61
50
DIPLEXER
RFDIP1004L10T
RFDIP1608060LCT
RFDIP1608060LET
RFDIP1608060LFT
RFDIP160806BLM6T25
RFDIP160806ALM6T30
RFDIP1608060LM0T60
RFDIP160806BLM6T68
RFDIP1608060LVT
RFDIP1608060LST
62
DIPLEXER
RFDIP1608060LY8Q1C
RFDIP1606L168M1U
RFDIP1606L23T
RFDIP1606L24T
RFDIP1606L29T
RFDIP1606L51T
RFDIP1606L52T
RFDIP1606L53T
RFDIP1606L54T
RFDIP1607L898D1T
-5
-15
-35
63
DIPLEXER
RFDIP1606L110C8Q1C
RFDIP1608060LS3T55
KFDIP2004L157B1U
KFDIP2004L167B1U
KFDIP2004L197B1U
RFDIP2012050L5T
RFDIP2012050L7T
RFDIP2012050L8T
RFDIP2012050LPT
RFDIP2012050LQT
64
DIPLEXER
RFDIP2008L107N3T
RFDIP2008L117N3T
AMDIP2520070L3T
AMDIP2520070L4T
RFDIP1608060T1T
RFDIP1608060TM7T62
S-parameter (dB)
S-parameter (dB)
-20
dB(S(2,1))
dB(S(1,1))
dB(S(3,1))
-30
-40
0.5
dB(S(2,1))
dB(S(1,1))
dB(S(3,1))
-10
-10
1.5
2.5
3.5
Frequency (GHz)
4.5
5.5
-20
-30
-40
6.5
-50
0.5
1.5
RFDIP1608060TAT
5.5
6.5
-10
S-parameter (dB)
S-parameter (dB)
4.5
-20
-30
dB(S(2,1))
dB(S(1,1))
dB(S(3,1))
-40
1.5
2.5
3.5
Frequency (GHz)
4.5
RFDIP1608060TDT
65
3.5
Frequency (GHz)
RFDIP1608060TCT
0.5
2.5
-20
-30
-40
dB(S(2,1))
dB(S(1,1))
dB(S(3,1))
-50
5.5
6.5
-60
0.5
1.5
2.5
3.5
Frequency (GHz)
4.5
RFDIP2012090T2T
5.5
6.5
DIPLEXER
RFDIP2520080T1T
RFDIP1608070GM1T76
RFDIP2012070G5T
RFDIP2012090G77N2T
RFDIP2012090GM1T58
RFDIP2520100G2T
-20
-30
dB(S(2,1))
dB(S(1,1))
dB(S(3,1))
-40
-50
0.5
1
1.5
2
2.5
Frequency (GHz)
3
3.5
4
66
TRIPLEXER
TRIPLEXER
STRUCTURE AND PIN ASSOCIATED
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-2
STRUCTURE A-3
STRUCTURE B
STRUCTURE AND DIMENSION
Unit: mm
Structure\
Dimension
L
W
T
A
B
C
D
E
F
G
A
2.00±0.15
1.25±0.15
0.90±0.10
0.20±0.20
0.30±0.20
0.35±0.20
0.65±0.20
0.20±0.20
0.20±0.20
0.30±0.20
B
2.50±0.15
2.00±0.15
0.90±0.10
0.30±0.10
0.40±0.10
0.55±0.10
0.40±0.10
0.90±0.10
0.30±0.10
0.30±0.10
ELECTRICAL SPECIFICATION
GPS 1.575GHz/ISM 2.4GHz/5GHz band RF application
Part Number
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
( dB )
Return Loss
(dB) Min
Isolation
1560~1606
50
0.6
15(2400~2500 MHz)
15(4800~6000 MHz)
10
0.7
10(860~960 MHz)
15(1545~1605 MHz)
10(3600~3750 MHz)
20(4800~6000 MHz)
10(7200~7500 MHz)
10(9600~10000 MHz)
10
20(1559~1606 MHz)
25(4800~5000 MHz)
25(860~960 MHz)
25(1545~1605 MHz)
25(1710~1990 MHz)
30(2170 MHz)
10(8100~8800 MHz)
15(8820~9800 MHz)
25(9800~11900 MHz)
10
2400~2500
50
RFTIP2012090T18Q1C
4900~5950
67
50
0.8
20(1559~1606 MHz)
Size (mm)
Structure
2.00x1.25x0.90
A-1
TRIPLEXER
GPS 1.575GHz/ ISM 2.4GHz/5GHz band RF application
Part Number
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
( dB )
Return Loss
(dB) Min
Isolation
1560~1606
50
0.65(25℃)
0.70(-40~+85℃)
20(2400~2500 MHz)
20(4900~6000 MHz)
10
0.70(25℃)
0.85(-40~+85℃)
10(860~960 MHz)
15(1545~1610 MHz)
10(3600~3750 MHz)
20(4800~6000 MHz)
10(7200~7500 MHz)
10(9600~10000 MHz)
10
20(1559~1606 MHz)
20(4800~5000 MHz)
10
2400~2500
50
RFTIP2012090T27N3T
4900~5950
50
0.80(25℃)
0.95(-40~+85℃)
25(1559~1606 MHz)
35(2400~2500 MHz)
12(3400~3600 MHz)
12(3600~3900 MHz)
10(6900~7200 MHz)
10(7200~7800 MHz)
25(10300~11700 MHz)
15(15300~16200 MHz)
1560~1606
50
0.7
15(2400~2500 MHz)
15(4800~6000 MHz)
10
0.8
10(860~960 MHz)
15(1545~1605 MHz)
8(3600~3750 MHz)
20(4800~5000 MHz)
10(7200~7500 MHz)
10(9600~10000 MHz)
10
10
2400~2500
50
RFTIP2012090T9T
4900~5950
50
0.9
25(860~960 MHz)
25(1545~1605 MHz)
25(1710~1990 MHz)
30(2170 MHz)
38(2400~2500 MHz)
8(8100~8800 MHz)
15(8820~9800 MHz)
22(9800~11900 MHz)
1560~1606
50
0.70(25℃)
0.80(-40~+85℃)
14(2400~2500 MHz)
15(4800~6000 MHz)
10
0.80(25℃)
0.95(-40~+85℃)
10(860~960 MHz)
10(1545~1605 MHz)
8(3600~3750 MHz)
20(4800~5000 MHz)
10(7200~7500 MHz)
5(9600~10000 MHz))
10
10
2400~2500
50
RFTIP2012090TLT
Size (mm)
Structure
2.00x1.25x0.90
A-2
2.00x1.25x0.90
A-3
2.00x1.25x0.90
A-1
2.00x1.25x0.90
A-1
20(1559~1606 MHz)
4900~5950
50
0.90(25℃)
1.10(-40~+85℃)
24(860~960 MHz)
24(1545~1605 MHz)
25(1710~1990 MHz)
25(2170 MHz)
0.2(3920~4720 MHz)
10(8100~8800 MHz)
14(8820~9800 MHz)
20(9800~11900 MHz)
1560~1606
50
0.60(25℃)
0.80(-40~+85℃)
15(2400~2500 MHz)
15(4800~6000 MHz)
10
0.70(25℃)
0.90(-40~+85℃)
10(860~960 MHz)
15(1545~1605 MHz)
10(3600~3750 MHz)
20(4800~5000 MHz)
10(7200~7500 MHz)
10(9600~10000 MHz)
10
20(1559~1606 MHz)
25(4800~5000 MHz)
25(860~960 MHz)
25(1545~1605 MHz)
25(1710~1990 MHz)
30(2170 MHz)
10(8100~8800 MHz)
15(8820~9800 MHz)
25(9800~11900 MHz)
10
2400~2500
50
RFTIP2109ATM0T63
4900~5950
50
0.80(25℃)
1.00(-40~+85℃)
25(1559~1606 MHz)
68
TRIPLEXER
Part Number
Frequency
(MHz)
Impedance
(Ω)
Insertion Loss
(dB)
Attenuation
( dB )
Return Loss
(dB )Min
Isolation
1560~1606
50
0.60(25℃)
0.80(-40~+85℃)
15(2400~2500 MHz)
15(4800~6000 MHz)
10
0.70(25℃)
0.90(-40~+85℃)
10(860~960 MHz)
15(1545~1605 MHz)
10(3600~3750 MHz)
20(4800~5000 MHz)
10(7200~7500 MHz)
10(9600~10000 MHz)
10
20(1559~1606 MHz)
25(4800~5000 MHz)
10
25(1559~1606 MHz)
2400~2500
50
RFTIP2109BTM5T62
RFTIP2520090T3T
4900~5950
50
0.80(25℃)
1.00(-40~+85℃)
25(860~960 MHz)
25(1545~1605 MHz)
25(1710~1990 MHz)
30(2170 MHz)
10(8100~8800 MHz)
15(8820~9800 MHz)
25(9800~11900 MHz)
698~960
50
0.70(25℃)
0.80(-40~+85℃)
20(1710~2200 MHz)
20(2500~2690 MHz)
10
20(1710~2200 MHz)
20(2500~2690 MHz)
1710~2200
50
1.40(25℃)
1.60(-40~+85℃)
20(698~960 MHz)
15(2500~2690 MHz)
10
18(698~960 MHz)
18(2500~2690 MHz)
2500~2690
50
1.80(25℃)
2.00(-40~+85℃)
15(698~960 MHz)
15(1710~2200 MHz)
10
20(698~960 MHz)
20(1710~2200 MHz)
Size (mm)
Structure
2.00x1.25x0.90
A-2
2.50x2.00x0.90
C
TYPICAL ELECTRICAL CHARACTERISTICS
RFTIP2012090T18Q1C
Low band
Middle band
High band
RFTIP2012090T27N3T
Low band
Middle band
High band
RFTIP2012090T9T
Low band
69
Middle band
High band
TRIPLEXER
RFTIP2012090TLT
Low band
Middle band
High band
RFTIP2109ATM0T63
Low band
Middle band
High band
RFTIP2109BTM5T62
Low band
Middle band
High band
RFTIP2520090T3T
Low band
Middle band
High band
For more information, please contact with local sales representative
All specifications are subject to change without notice
70
COMMON MODE FILTER
COMMON MODE FILTER
STRUCTURE A
Unit: mm
Structure\
Dimension
A
L
W
T
a
b
c
1.20+0.40
-0.20
2.00+0.40
-0.20
1.00±0.20
0.45±0.20
0.40±0.20
0.80±0.10
1.60±0.20
3.20±0.20
0.95±0.20
0.60±0.20
0.50±0.20
1.10±0.20
1.00±0.20
0.60±0.20
0.50±0.20
1.10±0.20
DISCRETE CMF for HIGH SPEED TRANSMISSION LINES
Part Number
Characteristic Impedance
(Differential)
RFCMF1220100M3T
RFCMF1220100M4T
USB2.0
IEEE1394
LVDS(mini)
Common Mode
Attenuation (Min. )
DC Resistance
(Ω) max.
Rated Current
(mA)
Size(mm)
Structure
90 ohm
9.0(240MHz ~ 1GHz)
1.5
300
1.20x2.00x1.00
A
90 ohm
9.0(130 MHz ~ 1GHz)
2.5
200
1.20x2.00x1.00
A
RFCMF1632090M1T
90 ohm
9.0(140 MHz ~ 1.0 GHz)
1.5
300
1.60x3.20x0.95
A
RFCMF1632100M3T
90 ohm
9.0(240 MHz ~ 1.0 GHz)
1.5
300
1.60x3.20x1.00
A
RFCMF1220100M3T
RFCMF1220100M4T
Impedance vs Frequency Characteristic:
-10
-20
-20
dB
dB
-30
-40
-40
Common Mode Attenuation
Differential Mode Loss
-50
0.48
Fre uenc
0.72
GHz
0.96
1.
-50
0.48
Fre uenc
0.72
GHz
0.96
RFCMF1632090M1T
RFCMF1632100M3T
71
1.
COUPLER
COUPLER
STRUCTURE A
STRUCTURE A-1
STRUCTURE A-2
STRUCTURE B
STRUCTURE A-3
STRUCTURE C
Unit: mm
Structure\
Dimension
A
L
W
T
A
B
C
D
E
F
1.60±0.10
0.80±0.10
0.60±0.10
0.10±0.10
0.30±0.10
0.25±0.10
0.55±0.10
0.20±0.10
1.60±0.10
0.80±0.10
0.60±0.10
0.175±0.10
0.25±0.10
0.25±0.10
0.50±0.10
0.20±0.10
B
0.65±0.04
0.50±0.04
0.35±0.10
0.20±0.04
0.20±0.04
0.025±0.025
0.10±0.04
0.25±0.04
0.025±0.025
C
0.65±0.10
0.50±0.10
0.35±0.05
0.225±0.10
0.20±0.05
0.10±0.05
0.25±0.05
0.025±0.025
ISM Band 2.4GHz Application
Part Number
Frequency
(MHz)
Insertion Loss
(dB)
Coupling in BW
Directivity in BW
dB (min.)
Isolation in BW
dB (min.)
VSWR
Dimension
( mm³)
Structure
RFCPL1806B2450T
2400~2500
1.83
6.5 ± 1.0 dB
21.0 dB min
1.5
1.60x1.80x0.60
A-1
RFCPL1810B2450T
2400~2500
0.74
10.0 ±1.0 dB
22.0 dB min
1.8
1.60x1.80x0.60
A-1
TFCPL0605B24508Q1C
2400~2500
0.32(25℃)
0.40(-40~+85℃)
14.6 ± 1.0 dB
20.0 dB min.
1.3
0.60x0.50x0.35
B
Dimension
( mm³)
Structure
0.65x0.50x0.35
B
0.65x0.50x0.35
B
0.65x0.50x0.35
C
Part Number
TFCPL0605030L18A1U
TFCPL0605030L28Q1C
RFCPL0605030L58Q1C
Frequency
(MHz)
Insertion Loss
(dB)
Coupling in BW
Directivity in BW
dB (min.)
Isolation in BW
dB (min.)
VSWR
2400~2500
0.5
19.0±1.5dB
15 dB min.
1.3
4900~5850
0.5
12.5±1.5dB
15 dB min.
1.3
2400~2500
0.2
19.3±0.7dB
15 dB min.
1.3
5150~5850
0.5
13.0±1.5dB
15 dB min.
1.3
2400~2500
0.3
19.0±1.5dB
14.5 dB min.
1.3
4900~5850
0.6
13.0±2.0dB
13.5dB min.
1.8
72
COUPLER
Part Number
Frequency
(MHz)
Insertion Loss
(dB)
Coupling in BW
Directivity in BW
dB (min.)
Isolation in BW
dB (min.)
VSWR
2400~2500
0.40(25℃)
0.45(-40~+85℃)
21.5±1.5dB
15 dB min.
1.3
4900~5850
0.40(25℃)
0.45(-40~+85℃)
15.0±1.5dB
15 dB min.
1.3
2400~2500
0.20(25℃)
0.25(-40~+85℃)
19.3±0.7dB
15 dB min.
1.3
4900~5850
0.50(25℃)
0.55(-40~+85℃)
13.0±1.5dB
15 dB min.
1.3
2400~2500
0.22(25℃)
0.24(-40~+85℃)
21.5±1.0dB
14 dB min.
1.3
4900~5850
0.32(25℃)
0.35(-40~+85℃)
15.0±1.2dB
14 dB min.
1.3
2400~2500
0.40(25℃)
0.45(-40~+85℃)
21.5±1.5dB
15 dB min.
1.3
4900~5850
0.40(25℃)
0.45(-40~+85℃)
15.0±1.5dB
15 dB min.
1.3
RFCPL0605030L6T
RFCPL0605030L9T
RFCPL0605030LFT
RFCPL0605030LHT
Dimension
( mm³)
Structure
0.65x0.50x0.35
C
0.65x0.50x0.35
C
0.65x0.50x0.35
C
0.65x0.50x0.35
C
LTE BAND APPLICATION
Part Number
Frequency
(MHz)
Insertion Loss
(dB)
Coupling in BW
Directivity in
BW dB (min.)
Isolation in BW
dB (min.)
VSWR
Dimension
( mm³)
Structure
RFCPL1608070P08Q1C
698~2690
0.20(698~960MHz)
0.22(1427.9~2170MHz)
0.25(2300~2690MHz)
23.0~27.0(698~915MHz)
21.5~26.5(1427.9~2025MHz)
22.5~27.5(2300~2620MHz)
20.
1.5
1.60x1.80x0.60
A-2
RFCPL1608070P28Q1C
698~2690
0.20(698~960MHz)
0.25(2300~2690MHz)
1.60x1.80x0.60
A-2
RFCPL1608070P38Q1C
698~2690
0.20(698~960MHz)
0.22(1710~2170MHz)
0.25(2300~2690MHz)
21.5~26.5(1710~2025MHz)
1.60x1.80x0.60
A-3
700~2700
0.2(700~790MHz)
(Typ.0.07)
0.2(820~900MHz)
(Typ.0.07)
0.3(1701~2100MHz)
(Typ.0.15)
0.3(2300~2700MHz)
(Typ.0.15)
24~27(700~790MHz)
24~27(820~900MHz)
20~23(1701~2100MHz)
20~23(2300~2700MHz)
40(700~790MHz)
40(820~900MHz)
35(1701~2100MHz
35(2300~2700MHz
1.45
1.60x1.80x0.60
A-1
RFCPL1608070PM9T16
RFCPL1806B2450T
RFCPL1810B2450T
73
COUPLER
TFCPL0605B24508Q1C
FCPL0605030L28Q1C
TFCPL0605030L28Q1C
RFCPL0605030L58Q1C
RFCPL0605030L6T
74
COUPLER
RFCPL0605030L9T
RFCPL0605030LFT
RFCPL0605030LHT
RFCPL1608070P08Q1C
RFCPL1608070P28Q1C
75
COUPLER
RFCPL1608070P38Q1C
RFCPL1608070PHT
RFCPL1608070PKT
RFCPL1608070PM9T16
76
SAW Filter
SAW Filter
STRUCTURE A
STRUCTURE B
STRUCTURE B-2
STRUCTURE B-1
STRUCTURE C
STRUCTURE C-1
STRUCTURE C-2
Unit: mm
Structure\
Dimension
A
77
L
W
T
A
B
C
D
E
F
G
H
I
1.10±0.10
0.90±0.10
0.50max.
0.40
0.40
0.25
0.20
0.05
0.075
0.25
1.40±0.13
1.10±0.13
0.65max.
0.50
0.50
0.325
0.25
0.075
0.10
0.25
B
1.80±0.10
1.40±0.10
0.65max.
0.65
0.30
0.50
0.25
0.35
0.25
C
1.50±0.10
1.10±0.10
0.60max.
0.18
0.18
0.39
0.49
0.075
0.21
0.07
0.21
0.15
SAW Filter
Application
GPS/Wifi
FDD LTE
FDD LTE
TDD LTE
TDD LTE
TDD LTE
Type
Part Number
Band
Frequency(MHz)
Package (mm)
STRUCTURE
GPS SAW 3 Mode
SF11091582GC2T
GPS+G+C
1559.05~1605.89
1.1 x 0.9
A
GPS SAW 3 Mode
SF14111582GC01T
GPS+G+C
1559.05~1605.66
1.4 x 1.1
A
SAW
SF11092450A04T
WLAN
2400~2500
1.1 x 0.9
A
SAW
SF14112450A03T
WLAN
2400~2500
1.4 x 1.1
A
SAW
SF14112442A01T
WLAN
2400~2484
1.4 x 1.1
A
SAW
SF14112442A03T
WLAN
2401~2483
1.4 x 1.1
A
SAW Duplexer
DF18141950B104T
B1
1920~1980/2110~2170
1.8 x 1.4
B-1
SAW Duplexer
DF18140836B511T
B5
824~849/869~894
1.8 x 1.4
B-1
SAW Duplexer
DF18141880B203T
B2
1850.48~1909.52/1930.48~1989.52
1.8 x 1.4
B-1
SAW Duplexer
DF18141747B303T
B3
1712.5~1782.5/1807.5~1877.5
1.8 x 1.4
B-1
SAW Duplexer
DF18142535B705T
B7
2500~2570/2620~2690
1.8 x 1.4
B-1
SAW Duplexer
DB18142140B102T
B1
1920~1980/2110~2170
1.8 x 1.4
B-2
SAW Duplexer
DB18140881B507T
B5
824~849/869~894
1.8 x 1.4
B-2
SAW Duplexer
DB18140942B801T
B8
880~915/925~960
1.8 x 1.4
B-2
RX SAW
SF11092140B102T
B1
2110~2170
1.1 x 0.9
A
RX SAW
SF11091960B201T
B2
1930~1990
1.1 x 0.9
A
RX SAW
SF11091842B305T
B3
1805~1880
1.1 x 0.9
A
RX SAW
SF11090881B506T
B5
869~894
1.1 x 0.9
A
RX SAW
SF11092655B702T
B7
2620~2690
1.1 x 0.9
A
RX SAW
SF11090942B805T
B8
925~960
1.1 x 0.9
A
Rx Dual SAW
BF1511B394101AT
B39/B41
1880~1920/2550~2655
1.5 x 1.1
C-2
Rx Dual SAW
BF1511B394101BT
B39/B41
1880~1920/2550~2655
1.5 x 1.1
C-1
TRx SAW
SF14112595B3803T
B38
2570~2620
1.4 x 1.1
A
TRx SAW
SF14112350B4001T
B40
2300~2400
1.4 x 1.1
A
TRx SAW
SF14112605B41S4T
B41
2550~2655
1.4 x 1.1
A
TRx SAW
SF14112593B4102T
B41
2496~2690
1.4 x 1.1
A
TRx SAW
SF14112017B3402T
B34
2010~2025
1.4 x 1.1
A
TRx SAW
SF14111900B3906T
B39
1880~1920
1.4 x 1.1
A
TRx SAW
SF11092595B3804T
B38
2570~2620
1.1 x 0.9
A
TRx SAW
SF11092350B4004T
B40
2300~2400
1.1 x 0.9
A
TRx SAW
SF11092595B4108T
B41
2535~2655
1.1 x 0.9
A
TRx SAW
SF11092017B3403T
B34
2010~2025
1.1 x 0.9
A
TRx SAW
SF11091900B3907T
B39
1880~1920
1.1 x 0.9
A
Rx SAW
SF11092595B3805T
B38
2570~2620
1.1 x 0.9
A
Rx SAW
SF11092350B4005T
B40
2300~2400
1.1 x 0.9
A
Rx SAW
SF11092602B41W9T
B41
2550~2655
1.1 x 0.9
A
SF11091582GC2T
78
SAW Filter
SF14111582GC01T
SF11092450A04T
SF14112450A03T
SF14112442A01T
SF14112442A03T
79
SAW Filter
DF18141950B104T
DF18140836B511T
DF18141880B203T
DF18141747B303T
DF18142535B705T
80
SAW Filter
DB18142140B102T
DB18140881B507T
DB18140942B801T
SF11092140B102T
SF11091960B201T
81
SAW Filter
SF11091842B305T
SF11090881B506T
SF11092655B702T
SF11090942B805T
SF14112595B3803T
82
SAW Filter
SF14112350B4001T
SF14112605B41S4T
SF14112593B4102T
SF14112017B3402T
SF14111900B3906T
83
SAW Filter
SF11092595B3804T
SF11092350B4004T
SF11092595B4108T
SF11092017B3403T
SF11091900B3907T
84
SAW Filter
SF11092595B3805T
SF11092350B4005T
SF11092602B41W9T
85
ANTENNA SWITCH
ANTENNA SWITCH
Application Circuit (GPIO)
RFASWA630PTF06
RFASWA697ATF09
RFASWAM3489ATF09
SPDT
SPDT
SPDT
RFC
1
C1
5
C1
RF1
1
5
C
RF
3
RF1
RFC
3
C
RF
RFASWMT2628PTF09
RFASWMT2628BTF09
RFASWMH6373ATF09
SP3T
SP3T
SP3T
RFC
C
C1
C3
C1
C
1
11
7
RF3
RF1
1
RF3
3
RF
7
5
RF1
3
RF
5
1
C3
C
C1
RFASWKH4414PTF06
RFASWK626ATF09
RFASWHH1416PTF06
SP4T
SP4T
SP6T
C
C1
N/C
C3
N/C
13
N/C
1
11
RF3
2
10
RF1
3
1
N/C
7
N/C
N/C
13
RF5
1
11
RF
RF3
2
10
RF
RF1
3
N/C
5
C
C1
C
3
7
5
N/C
5
C
7
C1
C
C
C3
C3
C
RF
RF
C1
C3
RF
C3
C1
C
C1
RFASWDH2418PTF06
SP8T
RF
RF7
13
RF5
1
11
RF3
2
10
RF1
3
RF
RF
RF
N/C
5
C
7
C1
C
C3
C3
C
C1
86
ANTENNA SWITCH
ANTENNA SWITCH
RFASWB643ATF09
RFASWB646BTF09
RFASWB438ATF09
DPDT
DPDT
DPDT
RF1
RF3
C1
11
1
10
3
3
12
3
VDD
13
23
C
83
1
11
RF3
VC 2
GND
3
Vc1
3
6
1
3
3
5
C1
RF
RF1
73
4
3
C2
Ant 2
1
6
2
5
3
4
Ant 1
RF4
93
5
RX
7
C2
VC 1
TX
C1
RF2
RF
RFASWB022ATF09
RFASWCM0624ATF09
DPDT
DP4T
3_N
C
3_P
1
1_N
7
3
1_P
5
C1
_N
_P
Part Number
Description
RFASWA630PTF06
RFASWA697ATF09
SPDT
Frequency
(GHz )Max.
Insertion loss
Isolation
(dB)
(dB)
0.1
6
0.25~1.1dB
0.4
6
0.35~1.00dB
VSWR
Package (mm)
14~35
1.20
1.1 x 0.7
15~32
1.50
1.0 x 1.0
RFASWAM3489ATF09
0.7
2.7
0.38~0.50dB
21~33
1.25
1.1 x 0.7
RFASWMT2628PTF09
0.5
2.7
0.30~0.60dB
20~35
1.43
1.0 x 1.0
0.8
2.7
0.30~0.70dB
14~26
1.50
1.0 x 1.0
RFASWMT2628BTF09
SP3T
RFASWMH6373ATF09
0.5
6
0.32~0.80dB
15~32
1.40
2.0 x 2.0
RFASWKH4414PTF06
0.1
2.7
0.45~0.65dB
24~38
1.22
2.0 x 2.0
RFASWK626ATF09
SP4T
0.7
2.7
0.30~0.50dB
27~38
1.60
1.1 x 1.1
RFASWHH1416PTF06
SP6T
0.1
2.7
0.4~0.65dB
24~38
1.22
2.0 x 2.0
RFASWDH2418PTF06
SP8T
0.1
2.7
0.30~0.80dB
18~35
1.50
2.0 x 2.0
RFASWB643ATF09
0.7
2.7
0.40~0.55dB
22~30
1.28
2.0 x 2.0
RFASWB646BTF09
0.7
3.8
0.40~0.70dB
25~33
1.20
1.83 x 1.83
0.1
6
0.50~1.20dB
13~28
1.43
1.5 x 1.5
1.1 x 1.5
RFASWB438ATF09
DPDT
RFASWB022ATF09
RFASWCM0624ATF09
87
Frequency
(GHz )Min.
DP4T
0.6
6
0.40~1.05dB
16~33
1.30
0.824
0.96
0.25dB
28~38
1.50
1.71
2.17
0.35dB
23~30
1.50
0.698
0.792
0.25dB
28~38
1.50
2.3
2.69
0.40dB
20~24
1.50
1.1 x 1.5
ANTENNA SWITCH
Application Circuit (MIPI)
RFASWH656FTF03
RFASWD658FTF03
SP6T
SP6T
SP8T
3
RFASWH526BTF03
N/C
N/C
C1
13
13
5
C
1
11
1
1
11
3
5
3
1
3
5
7
N/C
5
7
7
RMASME494ATF03
RFASWE660DTF03
RFASWF662DTF03
SP10T
SP10T
SP12T
7
17
1
7
15
5
13
11
3
13
1
15
7
1
7
5
5
15
3
3
3
17
3
1
5
7
11
N/C
N/C
3
5
13
11
5
17
1
NC
7
1
C1
C1
C1
C
C
C
11
RMASMF496ATF03
RMASMP491ATF03
RMASMNT1492ATF03
SP12T
SP14T
SP16T
1
1
1
17
7
7
15
7
17
3
3
3
5
13
1
5
5
11
11
13
1
5
3
7
15
3
7
11
5
3
13
C
C1
C
11
15
1
7
11
C1
17
5
13
C1
C
RMASMU532ATF03
RMASMU890ATF03
RMASMS535ATF03
DP14T (SP8T+SP6T)
DP14T (SP7T+SP7T)
DP21T (SP12T+SP9T)
88
ANTENNA SWITCH
Part Number
RFASWH526BTF03
RFASWH656FTF03
RFASWD658FTF03
RMASME494ATF03
RFASWE660DTF03
RFASWF662DTF03
RMASMF496ATF03
Description
SP6T
SP8T
SP10T
SP12T
Frequency
(GHz)
Min.
Frequency
(GHz)
Max.
Insertion loss
(dB)
TRXx ports
Isolation
(TRXx to any off
TRXx port)
[non-adjacent ports]
Isolation
(TRXx to any off
TRXx port)
[adjacent ports]
VSWR
Package
(mm)
0.4
2.7
0.40~0.76dB(400~2690MHz)
20~30
17~26
2
2.0 x 2.0
0.4
2.7
0.40~0.76dB(704~2690MHz)
20~30
17~26
2
2.0 x 2.0
0.4
2.7
20~30
17~26
2
2.0 x 2.0
0.4
2.7
0.60~0.85dB(824~2690MHz)
23~30
20~26
2
2.5 x 2.5
2.4 x 2.4
0.7
2.7
0.45~0.75dB(700~2700MHz)
18~26
18~26
2
0.4
2.7
0.50~0.72dB(700~2690MHz)
20~30
16~23
2
2.5 x 2.5
0.4
2.7
23~30
20~26
2
2.5 x 2.5
RMASMP491ATF03
SP14T
0.4
2.7
0.70~1.15dB(700~2690MHz)
20~30
16~20
2
2.5 x 2.9
RMASMNT1492ATF03
SP16T
0.4
2.7
0.60~1.00dB(824~2690MHz)
20~30
16~20
2
2.5 x 3.3
RMASMU532ATF03
DP14T
(SP8T+SP6T)
0.4
2.7
0.65~1.15dB(704~2690MHz)
17~23
14~21
1.5
2.8 x 2.8
RMASMU890ATF03
DP14T
(SP7T+SP7T)
0.4
2.7
0.60~0.85dB(600~2690MHz)
18~25
15~23
1.5
3.2 x 2.8
RMASMS535ATF03
DP21T
(SP12T+SP9T)
0.7
3.0
0.65~1.10dB(824~2690MHz)
15~23
14~21
2
3.6 x 2.8
89
ANTENNA SWITCH
Application Circuit (LTE Antenna Tuner-GPIO)
RFASWA141ATF09
RFASWK119ATF09
SPDT
SP4T
RFC
RF1
1
RFC
RF
7
RF1
1
RF3
11
RF
RF
3
3
5
5
C
EN
C1
EN
C3
7
C
C1
1
C3
C
RFASWK694BTF09
RFASWK014ATF09
SP4T
SP4T
Part Number
Description
Frequency
(GHz) Min.
Frequency
(GHz) Max.
Insertion loss
(dB)
Isolation
VSWR
Package (mm)
RFASWA141ATF09
SPDT
0.4
3.0
0.20~0.35dB(700~2700MHz)
11~21
1.22
1.67 x 1.47
RFASWK119ATF09
SP4T
0.4
3.0
0.40~0.75dB(1000~2700MHz)
14~24
1.78
1.6 x 1.6
RFASWK694BTF09
SP4T
0.5
2.7
0.30~0.67dB(615~2700MHz)
16~22
1.58
1.1 x 1.5
RFASWK014ATF09
SP4T
0.1
2.7
0.25~1.05 dB (700~2700MHz)
16~25
1.28
1.1 x 1.5
90
ANTENNA SWITCH
Application Circuit (Network-GPIO)
RFASWA351ATF06
RFASWA370ATF06
SPDT
SPDT
C4
C2
VC1
1
6
ANT
2
5
VC2
3
4
RF1
C1
RF2
C3
C5
RFASWM617BTF06
SP3T
91
Part Number
Description
Frequency
(GHz) Min.
Frequency
(GHz) Max.
Insertion loss
(dB)
Isolation
VSWR
Package
(mm)
RFASWA351ATF06
SPDT
0.5
6.0
0.35~0.70dB(500~6000MHz)
15~25
2
1.0 x 1.0
RFASWA370ATF06
SPDT
0.5
6.0
0.50~0.90dB(500~5850MHz)
23~28.5
1.67
1.5 x 1.5
RFASWM617BTF06
SP3T
0.5
6.0
0.35~0.65dB(500~6000MHz)
15~30
1.92
1.5 x 1.5
DIPOLE ANTENNA (N/SMA)
Series
8709
1313
1513
1713
3913
1310
1413
Size(mm)
L
Ø
87
9.95
137.5
157.5
172.5
392
135.7
148.5
12.5
10
13
1913
196.6
13
2520
4358
220
25
43.1
Return Loss
2.4~2.5 GHz
2dBi
