GGBLA.01.A
GGBLA.01.A
    TAOGLASLIMITED
    GGBLA.01.A
GGBLA.01.A 数据手册
SPECIFICATION Part No. : GGBLA.01.A Product Name : Unifier GPS/GLONASS/GALILEO/BEIDOU Ceramic SMD Antenna Feature : 3.2*1.6*0.5mm Low profile Ceramic Loop antenna Omnidirectional RoHS Compliant SPE-13-8-092/F/PK Page 1 of 19 1. Introduction Taoglas have developed a unique ceramic miniature loop antenna series for GPS-GLONASS-GALILEO-BEIDOU applications. At 3.2*1.6*0.5mm, the Unifier GGBLA.01.A Loop antenna is a miniature edge mounted SMD antenna, designed for small space requirements. Typical applications are small sized automotive navigation or position tracking systems and hand-held devices when GNSS function is needed. The radiation pattern is more omnidirectional than traditional patch antennas. The Unifier antenna series wide bandwidth allows high efficiency, stable reception on all three GPS, GLONASS and BeiDou bands from 1555MHz to 1602MHz Efficiencies of 64% to 85% are achievable. Peak gain of 3.3dBi places this antenna gain performance within the range of a much larger 15mm to 18mm patch antennas. Based on the loop effect this antenna works best when placed on the centre of the edge of the board, but can still work better than traditional linear polarized chip antennas even when placed at corners as substitute. The Unifier GGBLA.01.A is delivered on tape and reel and now allows M2M customers to use an omnidirectional antenna in devices where orientation of the product is unknown. Like all small antennas, care must be taken to ensure the device ground-plane layout and antenna matching has been done correctly, Taoglas offers professional gerber review, transmission line design, general integration support and final matching service of the GGBLA.01.A on your device board at our regional labs worldwide. Contact your regional Taoglas sales office for immediate support. SPE-13-8-092/F/PK Page 2 of 19 2. Specification Measured on a 80*40mm ground plane ELECTRICAL GPS/GALILEO BAND Working Frequency* 1575.42MHz VSWR 2.0 : 1 max Polarization Linear Gain Peak gain: 3.2 Typ. Impedance 50  ELECTRICAL GLONASS BAND Working Frequency* 1598~1608MHz VSWR 2.0 : 1 max Polarization Linear Gain Peak gain: 2.6 Typ. Impedance 50  ELECTRICAL COMPASS-BEIDOU BAND Working Frequency* 1561 MHz VSWR 2.0 : 1 max Polarization Linear Gain Peak gain: 2.8 Typ. Impedance 50  MECHANICAL Dimensions 3.2 x 1.6 x 0.5 mm Material Ceramic ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity 20% to 70% SPE-13-8-092/F/PK Page 3 of 19 3. Antenna Characteristics 3.1. Return Loss 3.2. VSWR SPE-13-8-092/F/PK Page 4 of 19 3.3. Efficiency 3.4. Efficiency and Gain table SPE-13-8-092/F/PK Page 5 of 19 4. 3D Antenna Radiation Pattern 4.1. BeiDou 1560MHz (80*40mm Ground Plane) SPE-13-8-092/F/PK Page 6 of 19 SPE-13-8-092/F/PK Page 7 of 19 4.2. GPS/GALILEO 1575MHz (80*40mm Ground Plane) SPE-13-8-092/F/PK Page 8 of 19 SPE-13-8-092/F/PK Page 9 of 19 4.3. GLONASS 1602MHz (80*40mm Ground Plane) SPE-13-8-092/F/PK Page 10 of 19 SPE-13-8-092/F/PK Page 11 of 19 5. Mechanical Drawing (Unit: mm) 5.1. Drawing EVB SPE-13-8-092/F/PK Page 12 of 19 5.2. Antenna Drawings SPE-13-8-092/F/PK Page 13 of 19 6. Layout Guide SPE-13-8-092/F/PK Page 14 of 19 7. Frequency tuning 7.1. Antenna tuning 7.2. Matching Circuit (center frequency 1575.42Mhz @ 80*40mm Ground) System Matching Circuit Component Location Description 1 0.8 pF 2 2.7 pF 3 N/A - - 22 pF DARFON (0402) ±0.1pF 0.5 pF DARFON (0402) ±0.1pF Fine Tuning Element 4 Fine Tuning Element 5 Vendor DARFON (0402) DARFON (0402) SPE-13-8-092/F/PK Tolerance ±0.1pF ±0.1pF Page 15 of 19 7.3. Fine tuning element vs. Center Frequency SPE-13-8-092/F/PK Page 16 of 19 8. Recommended Reflow Profile SPE-13-8-092/F/PK Page 17 of 19 9. Packaging SPE-13-8-092/F/PK Page 18 of 19 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-13-8-092/F/PK Page 19 of 19
GGBLA.01.A 价格&库存
很抱歉,暂时无法提供与“GGBLA.01.A”相匹配的价格&库存,您可以联系我们找货
GGBLA.01.A
    GGBLA.01.A
    • 6000+6.491656000+0.83987
    • 12000+6.3732912000+0.82456
    库存:18271
    GGBLA.01.A
    • 6000+5.549406000+0.71797
    • 12000+5.4169912000+0.70084
    库存:36000
    GGBLA.01.A
      GGBLA.01.A
      • 1+13.501671+1.74681
      • 10+9.8588910+1.27551
      • 25+8.9395025+1.15657
      • 100+7.93589100+1.02672
      • 250+7.45630250+0.96467
      • 500+7.16731500+0.92729
      • 1000+7.022381000+0.90854
      库存:18271
