WLA.01
WLA.01
    TAOGLASLIMITED
    WLA.01
WLA.01 数据手册
Specification Part No. : WLA.01 Model : 2.4GHz High Efficiency Loop Antenna Description : 2.5dBi 2400MHz to 2500MHz WLAN/WIFI/Bluetooth/Zigbee Features : 3.2*1.6*0.5mm Low Profile Peak gain 2.5dBi 50 Ohm Impedance RoHS Compliant SPE-11-8-146/K/SS Page 1 of 18 1. Introduction The WLA.01 2.4GHz Loop antenna is a high efficiency, miniature SMD, edge mounted ceramic antenna for very small space requirements for Wi-Fi, WLAN, Zigbee, Bluetooth, and 802.11 applications. The WLA.01 uses the main PCB as its ground plane, thereby increasing Antenna Efficiency. It is tuned for different PCB sizes by simply changing the value of the matching circuit. At 3.2mm*1.6mm*0.5mm, the WLA.01 is one of the smallest antennas available worldwide. This antenna is delivered on tape and Reel. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. SPE-11-8-146/K/SS Page 2 of 18 1.1 Applications *Bluetooth earphone systems *Hand-held devices when Bluetooth/Wi-Fi functions are needed, e.g., Smart phone. *IEEE802.11 b/g *ZigBee *Wireless PCMCIA cards or USB dongle SPE-11-8-146/K/SS Page 3 of 18 2. Specifications The WLA.01 is designed to mount at the center of the edge of an evaluation board of 80 x 40mm.The antenna performance was measured with the WLA.01 mounted on the evaluation board with SMA(F) connector. No Parameter Specification* 1 Center Frequency 2400-2500MHz 2 Dimensions 3.2*1.6*0.5mm 3 VSWR 2 max 4 Polarization Linear 5 Bandwidth 100MHz min. 6 Gain Peak 2.5dBi typ. 7 Efficiency 84% typ. 8 Impedance 50  Mechanical 9 10 Dimensions 3.2*1.6*0.5mm Material Ceramic Environmental 11 Operating Temperature -40°C+85°C 12 Storage Temperature -40°C+105°C 13 Temperature Coefficient(τf) 0  20 ppm @-20ºC to +80ºC Recommended Reel Storage 5°C to 40°C Condition Relative Humidity 20% to 70% 14 * The data was measured by a CTIA Authorized Test Lab. ** Center frequency will be offset to working frequency according to the conditions of user’s Ground plane and radome. SPE-11-8-146/K/SS Page 4 of 18 3. Electrical Specification (80*40mm ground plane) 3.1 Return Loss(S11) SPE-11-8-146/K/SS Page 5 of 18 3.2 VSWR SPE-11-8-146/K/SS Page 6 of 18 4. Radiation Pattern (Customize Design) SPE-11-8-146/K/SS Page 7 of 18 4.1 Radiation Pattern (80mmX40mm ground plane) Z X Y 4.2 3D Gain pattern @2442MHz SPE-11-8-146/K/SS Page 8 of 18 SPE-11-8-146/K/SS Page 9 of 18 4.3 Efficiency Table 4.4 Efficiency vs Frequency SPE-11-8-146/K/SS Page 10 of 18 5. Layout Guide 5.1 Solder Land Pattern Land pattern for soldering (grey marking areas) is as shown below. A matching circuit similar to the one shown in section 5.3 is also required. SPE-11-8-146/K/SS Page 11 of 18 SPE-11-8-146/K/SS Page 12 of 18 5.2 Solder Land Pattern This antenna includes a fine tuning element (as shown in the land patterns above) that can be used to slightly shift antenna resonance. 5.3 Matching Circuit Like all antennas, surrounding components, enclosures, and changes to the GND plane dimensions can alter performance. A pi-matching network like the one shown below is required in case adjustments need to be made. The antenna EVB has a similar matching network. The components on the EVB are a good starting point for a new design, but will need to be adjusted upon integration for best performance. The zero ohm resistor is needed for the ability to solder down a coax pigtail to make measurements with a vector network analyzer. SPE-11-8-146/K/SS Page 13 of 18 6. Antenna Drawings 6.1 Antenna Main Body SPE-11-8-146/K/SS Page 14 of 18 6.2 Antenna with EVB 6.3 Footprint on EVB SPE-11-8-146/K/SS Page 15 of 18 7. Packaging SPE-11-8-146/K/SS Page 16 of 18 7.1 Tape Dimensions (unit: mm) Feature Specifications Tolerances W 12 ±0.30 P 8 ±0.10 E 1.75 ±0.10 F 5.5 ±0.10 P2 2 ±0.10 D 1.5 ±0.10 Po 4 ±0.10 10Po 40 ±0.20 7.2 Pocket Dimensions (unit: mm) Feature Specifications Tolerances Ao 1.9 ±0.10 Bo 3.5 ±0.10 Ko 0.8 ±0.10 t 0.3 ±0.05 SPE-11-8-146/K/SS Page 17 of 18 8. Recommended Reflow Temp Profile The WLA.01 Loop Antenna can be assembled following either Sn-Pb or Pb-Free assembly processes. The recommended soldering temperatures are as follows: SPE-11-8-146/K/SS Page 18 of 18
WLA.01 价格&库存
很抱歉,暂时无法提供与“WLA.01”相匹配的价格&库存,您可以联系我们找货
WLA.01
  • 2000+4.18349
库存:270
WLA.01
    WLA.01
      WLA.01
      • 5000+6.840535000+0.88609
      • 10000+6.7111410000+0.86933
      库存:23632
