Low Profile and High Efficiency 868 MHz ISM Band Loop Antenna
Part No:
ILA.02
Description:
Features:
Small size antenna, low profile, and high efficiency
868 MHz ISM Band
1 dBi Peak Gain
10 x 3.2 x 0.5 mm size
SMT Compatible
RoHS & REACH Compliant
SPE-12-8-080-G
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Patterns
8
5.
Mechanical Drawing – Antenna
10
6.
Mechanical Drawing – Evaluation Board
12
7.
Soldering Conditions
13
8.
Packaging
14
9.
Changelog
16
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-12-8-080-G
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
The ILA.02 is a 868 MHz ISM band antenna featuring an excellent efficiency of 60% across the band. This
antenna works the best when placed at the center of the board edge. The antenna, at 10 x 3.2 x 0.5 mm, is
low profile and would be suitable for devices with space constraints. The ILA.02 is delivered on tape and reel
and now allows M2M customers to use an omni-directional SMT antenna. The omni-directional radiation
characteristics allow for excellent performance regardless of device orientation. This is especially useful for
devices that are not fixed in one particular spot during use. When there is little PCB space available for
antenna placement, but high performance is required, the ILA.02 is the ideal choice.
Introduction
Introduction
This antenna can be mounted with no performance degradation in either orientation as long as the antenna
is soldered correctly via Surface mounting. Please see the integration instructions section for further detail
regarding the optimum way to integrate this antenna into your device.
Introduction
For further optimization to customer-specific device environments and for support to integrate and test this
antennas performance in your device, contact your regional Taoglas Customer Services Team.
Introduction
Applications:
Automated Meter Reading (AMR)
Radio Frequency Identification (RFID)
Remote Monitoring
Healthcare
Sensing
868 MHz Applications
SPE-12-8-080-G
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Specifications
Antenna
Frequency (MHz)
3.
868-870 MHz (ISM)
Efficiency (%)
80 x 40 mm Ground Plane
70 (typical)
Average Gain (dB)
4.
Antenna Radiation Patterns3.Antenna -1.5 dB
Characteristics2.
3.
3.
Peak Gain (dBi)
Specifications
1.5 dBi
Max Return Loss (dB)
-10 dB
Antenna
VSWR Characteristics2.
Specifications
2:1
Impedance (Ω)
50Ω
Polarization
Linear
Radiation Pattern
Antenna
Characteristics
Omni
Input Power(W)
5
Mechanical
4.
Dimensions (mm)
10 x 3.2 x 0.5
Antenna
Required Space (mm)
11 x 10.4
Characteristics
Material
Ceramic
EVB Connector
SMA(F)
Environmental
4.
4.
Temperature Range
Antenna
Radiation Patterns
-40°C to 85°C
Storage Temperature
-40°C to 105°C
Humidity
40% to 95%
3 (168 Hours)
Moisture Sensitivity Level
Characteristics
4.
Characteristics2.
SPE-12-8-080-G
Specifications
www.taoglas.com
4
3.
3.1
4.
Return Loss
Characteristics
4.
4.
Characteristics
3.2
4.
Efficiency
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-12-8-080-G
www.taoglas.com
5
3.3
Average Gain
3.4
Peak Gain
SPE-12-8-080-G
www.taoglas.com
6
3.5
VSWR
SPE-12-8-080-G
www.taoglas.com
7
4.
Radiation Patterns
4.1
Test Setup – Antenna on Evaluation Board
4.
4.
4.
4.
4.
4.
4.
X
Z
SPE-12-8-080-G
Y
www.taoglas.com
8
4.3
3D Radiation Pattern
868 MHz
5925MHz
SPE-12-8-080-G
www.taoglas.com
9
5.
5.1
Antenna Dimension and Drawing
6.
Packaging5.
6.
Packaging
7.
Unit:
mm
Application
Mechanical Drawing
Note6. Packaging5.
Mechanical
5.2
Antenna Footprint
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Application Note6. Packaging
7.
Application Note
7.
7.
Application Note6. Packaging5.
Mechanical
Drawing
*Taoglas is able to provide CAD drawing file to customers for evaluation.
6.
Packaging5.
SPE-12-8-080-G
Mechanical Drawing
www.taoglas.com
10
5.2
Matching Circuit
Like all antennas, surrounding components, enclosures, and changes to the GND plane dimensions
can alter performance. A pi-matching network like the one shown below is required in case
adjustments need to be made. The antenna EVB has a similar matching network. The components
on the EVB are a good starting point for a new design, but will need to be adjusted upon integration
for best performance. The zero ohm resistor is needed for the ability to solder down a coax pigtail to
make measurements with a vector network analyzer.
SPE-12-8-080-G
www.taoglas.com
11
6.
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-12-8-080-G
Mechanical Drawing
www.taoglas.com
12
7.
Typical Soldering profile for lead-free process:
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-12-8-080-G
Mechanical Drawing
www.taoglas.com
13
9.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-12-8-080-G
Mechanical Drawing
www.taoglas.com
14
SPE-12-8-080-G
www.taoglas.com
15
Changelog for the datasheet
SPE-12-8-080– ILA.02
Revision: G (Current Version)
Date:
Changes:
Changes Made by:
2021-10-28
Format Change, MSL
Erik Landi
Previous Revisions
Revision: F
Revision: A (Original First Release)
Date:
Changes:
Changes Made by:
2017-10-23
Packing drawing updated
Carol Faughnan
Date:
Notes:
Author:
2012-05-08
Initial Release
STAFF
Revision: E
Date:
2017-04-21
Changes:
Changes Made by:
STAFF
Revision: D
Date:
Changes:
Changes Made by:
2016-09-12
STAFF
Revision: C
Date:
Changes:
Changes Made by:
2014-08-19
EVB & Footprint
AINE DOYLE
Revision: B
Date:
2012-06-27
Changes:
Changes Made by:
SPE-12-8-080-G
STAFF
www.taoglas.com
16
www.taoglas.com
SPE-12-8-080-G
© Taoglas 17
www.taoglas.com
很抱歉,暂时无法提供与“ILA.02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 6000+15.436756000+2.00640
- 国内价格 香港价格
- 1+25.947831+3.37259
- 10+22.3753410+2.90825
- 25+21.1416725+2.74790
- 100+19.44070100+2.52682
- 250+18.41914250+2.39404
- 500+17.69781500+2.30029
- 1000+17.017801000+2.21190
- 2500+16.178742500+2.10284
