FXP14.11.0100B
FXP14.11.0100B
    TAOGLASLIMITED
    CELLULAR HEPTA-BAND PCB GSC
FXP14.11.0100B 数据手册
FXP14.11.0100B Specification Part No. FXP14.11.0100B Product Name FXP14 Hexa-Band Cellular Antenna 850/900/1700/1800/1900/2100MHz Feature Murata GSC Connector 100 mm 0.81 Coaxial Cable 70*20*0.1 mm RoHS Compliant SPE-11-8-046/B | page 1 of 8 1. Introduction The Taoglas FXP14 Hexa Band Cellular Antenna covers all world-wide bands (850 / 900 / 1700 / 1800 / 1900 / 2100 MHz). These cellular bands are used for different technologies in different countries such as GSM / CDMA / DCS / PCS / WCDMA / UMTS/ HSPA / GPRS / EDGE / 3G. The antenna has been designed in a flexible material with a rectangular form-factor and cable connection for an easy installation. The antenna works on different plastic materials and thickness. We have selected a piece of ABS with 2mm of thickness as a baseline for testing. 2. Specifications Parameter Hexa Band Cellular Antenna Cellular Band (MHz) Return Loss (dB) 850 -7 900 -12 1700 -8 1800 -9 1900 -9 2100 -8 Efficiency (%) 52 55 60 60 62 65 Gain (dBi) 2 1.5 3 2.5 2 2.5 Impedance 50 Ohms VSWR ≤2.5:1 Polarization Linear Power Handled 5W Operation Temperature -40 ºC ~ +85 ºC Storage Temperature -40 ºC ~ +85 ºC Dimensions 70 X 20 X 0.1 mm Weight 1.5 g Connector Murata GSC Cable Standard Mini-Coax 0.81 mm Cable Length and color 100 mm, Black RoHS Compliant Yes Adhesive 3M 467 SPE-11-8-046/B | page 2 of 8 3. Test Set Up A Satimo SG24 3D Scan System with Anechoic Chamber   Y X Z Figure 1. Satimo System.   Agilent 5071C Vector Network Analyzer Figure 2. Network Analyzer.   SPE-11-8-046/B | page 3 of 8 4. Antenna Parameters The next antenna parameter graphs like Return Loss were measured in the Agilent 5071C Vector Network Analyzer. The Gain, Efficiency and Radiation Patterns were measured in the reliable Satimo 3D Scan System. 4.1 Return Loss Data Return Loss (dB) 0 -2 -4 -6 -8 -10 -12 -14 -16 -18 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200   MHz Figure 3. Return Loss for the FXP14 Antenna. 4.2 Gain Data Gain (dBi) 4 3 2 1 0 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200   MHz Figure 4. Gain for the FXP14 Antenna. SPE-11-8-046/B | page 4 of 8 4.3 Efficiency Data Efficiency (%) 70% 60% 50% 40% 30% 20% 10% 0% 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 MHz   Figure 5. Efficiency for the FXP14 Antenna. 4.4 Radiation Pattern Data 5 dB 0 dB 5 dB -10 dB -15 dB -20 dB -25 dB -30 dB _____ 849 MHz _____ 925 MHz _____ 1750 MHz _____ 1805 MHz _____ 1920 MHz _____ 2110 MHz Figure 6. Radiation pattern XZ Plane, Figure 1 as reference (dB) SPE-11-8-046/B | page 5 of 8 5 dB 0 dB 5 dB -10 dB -15 dB -20 dB -25 dB -30 dB _____ 849 MHz _____ 925 MHz _____ 1750 MHz _____ 1805 MHz _____ 1920 MHz _____ 2110 MHz Figure 7. Radiation pattern YZ Plane, Figure 1 as reference (dB) 5 dB 0 dB 5 dB -10 dB -15 dB -20 dB -25 dB -30 dB _____ 849 MHz _____ 925 MHz _____ 1750 MHz _____ 1805 MHz _____ 1920 MHz _____ 2110 MHz Figure 8. Radiation pattern XY plane, Figure 1 as reference (dB) SPE-11-8-046/B | page 6 of 8 5. Drawing Figure 9. Mechanical Drawing for the FXP14 Antenna Name Material Finish QTY 1 FXP14 PCB FPCB 0.1t Black 1 2 Ø0.81 Coaxial Cable FEP White 1 3 GSC Plug(M) Brass Silver 1 4 Double-Sided Adhesive 3M 467 Brown Liner 1 SPE-11-8-046/B | page 7 of 8 6. Packaging 100pcs antenna per small PE bag taoglas FXP14 850/900/1700/1800/1900/2100MHz FXP14R with?AntDc Hexa Band Cellular Antenna 0912 Small PE Bag Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-046/B | page 8 of 8
FXP14.11.0100B 价格&库存
很抱歉,暂时无法提供与“FXP14.11.0100B”相匹配的价格&库存,您可以联系我们找货
