ANT-2.4-WRT-MON-SMA
ANT-2.4-WRT-MON-SMA
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    ANT-2.4-WRT-MON-SMA
ANT-2.4-WRT-MON-SMA 数据手册
Datasheet ANT-2.4-WRT-MON-ccc 2.4 GHz WiFi External Panel-Mount Antenna The ANT-2.4-WRT-MON is a low-profile, panelmount monopole antenna designed for 2.4 GHz WiFi/WLAN and ISM applications including Bluetooth® and ZigBee®. The ANT-2.4-WRT-MON antenna’s compact size allows it to be mounted securely in enclosures requiring added security. The ANT-2.4-WRT-MON antenna’s compact profile and rugged dome reduces the likelihood of accidental damage versus a whip antenna. The antenna connects to the radio via SMA plug (male pin), RP-SMA plug (female socket) MHF1/ U.FL-type plug (female socket) or MHF4 plug (female socket) on 216 mm (8.5 in.) coaxial cable. ANT-2.4-WRT-MON-SMA Shown Features Applications • Performance at 2.4 GHz to 2.5 GHz ― VSWR: ≤ 1.7 ― Peak Gain: 2.7 dBi ― Efficiency: 82% • Low-profile ― Height: 27.0 mm (1.06 in) • Mounts permanently with pressure sensitive adhesive ring and provided hex nut • Single-band WiFi/WLAN ― 802.11b/g • 2.4 GHz ISM applications ― Bluetooth® ― ZigBee® ― IEEE 802.15.4 • Internet of Things (IoT) devices • Smart Home networking ― Sensing and remote monitoring ― Security Ordering Information Part Number Description ANT-2.4-WRT-MON-RPS Antenna with 216 mm (8.5 in) of RG-174 coaxial cable with an RP-SMA plug (female socket) connector ANT-2.4-WRT-MON-SMA Antenna with 216 mm (8.5 in) of RG-174 coaxial cable with an SMA plug (male pin) connector ANT-2.4-WRT-MON-UFL Antenna with 216 mm (8.5 in) of 1.32 mm coaxial cable with an MHF1/U.FL-type plug (female socket) connector ANT-2.4-WRT-MON-MHF4 Antenna with 216 mm (8.5 in) of 1.13 mm coaxial cable with an MHF4-type plug (female socket) connector Available from Linx Technologies and select distributors and representatives. WRT-MON Series ANT-2.4-WRT-MON-ccc Datasheet Table 1.   Electrical Specifications ANT-2.4-WRT-MON 2.4 GHz 2.4 GHz to 2.5 GHz Frequency Range VSWR (max) 1.7 Peak Gain (dBi) 2.7 Average Gain (dBi) -1.0 Efficiency (%) 82 Polarization Linear Radiation Impedance 50 Ω Max Power Omnidirectional Wavelength 1/4-wave 5W Monopole Electrical Type Electrical specifications and plots measured with a 102 mm x 102 mm (4.0 in x 4.0 in) reference ground plane. Table 2.   Mechanical Specifications Parameter Value -40 °C to +85 °C Operating Temp. Range -MHF4 = 13.8 g (0.49 oz), -RPS & -SMA = 18.9 g (0.66 oz), -UFL = 13.9 g (0.49 oz) Weight MHF4 plug (female socket) on 1.13 mm coaxial cable Adhesive RP-SMA plug (female Ring socket) on RG-174 coaxial cable Ø19.0 mm (0.75 in) SMA plug7/16-28 (male pin) on UNEFRG-174 coaxial cable MHF1/U.FL-type Hex plug Nut (female socket) on 1.32 mm coaxial cable Connection Coaxial Cable, minimum inside bend -SMA, -RPSradius RG-174: 10.2 mm (0.40 in), 1.13 mm: 5.0 mm (0.20 in), 1.32 mm: 6.0 mm (0.24 in) Height: 27.0 mm (1.06 in), Diameter: 19.0 mm (0.75 in) Dimensions -UFL 8.0 mm (0.31 in) -MHF4 Information Packaging 27.0 mm (1.06 in) 216.0 mm (8.5 in) The ANT-2.4-WRT-MON series antenna is individually sealed in a clear plastic bag. Individual packages are packed in a bag of 100 pcs. Distribution channels may offer alternative packaging options. DB1-WRT-MON Product Dimensions Figure 1 provides dimensions for the ANT-2.4-WRT-MON series antenna. Ø19.0 mm (0.75 in) Adhesive Ring 7/16-28 UNEF Hex Nut -SMA, -RPS -UFL 8.0 mm (0.31 in) -MHF4 216.0 mm (8.5 in) 27.0 mm (1.06 in) Figure 1.  ANT-2.4-WRT-MON Antenna Dimensions 2.4-WRT-MON 2 WRT-MON Series -SMA, -RPS ANT-2.4-WRT-MON-ccc Datasheet -UFL Recommended Mounting The recommended enclosure mounting dimensions are shown in Figure 2. The ANT-2.4-WRT-MON -MHF4 series antenna is supplied with an integrated closed-cell pressure sensitive adhesive ring which helps seal enclosures against external elements. The adhesive ring has a protective plastic backing that must be Recommended Mounting removed prior to installation. A pull tab has been provided for easy removal of the protective backing. The antenna can be permanently mounted using the provided hex nut which should be tightened to 3.0 kgf/cm (5 in/lbs) max. The recommended maximum enclosure wall thickness is 3.18 mm (0.125 in). Ø10.8 mm (0.43 in) Figure 2.  ANT-2.4-WRT-MON Series Antenna Recommended Enclosure Mounting Dimensions Ground Plane 1/4-Wave monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The CAP will also affect the final performance. proximity of other circuit elements and packaging nearANTENNA the antenna 7/16-28 UNEF METALIC MOUNTING SHAFT For further discussion and guidance on the importance2.54 of the ground THREADED plane counterpoise, please refer to .100 Linx Application Note, AN-00501: Understanding Antenna Specifications and Operation. HEAT SHRINK GREY/BLACK Antenna Orientation COAX CABLE TYPE 19.00 .748 The ANT-2.4-WRT-MON antenna is characterized with the antenna at the center of a 102 mm x 102 mm 216.0±2.0 ground plane as shown in Figure 3. 27.00 1.063 8.00 .315 8.50±.08 UFL / MHF1 CONNECTOR MHF4 CONNECTOR Figure 3.  ANT-2.4-WRT-MON Test Orientation 3 WRT-MON Series ANT-2.4-WRT-MON-ccc Datasheet VSWR 2500 5 2400 Figure 4 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 10 1 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 Reflected Power (%) 40 0 2500 Figure 4.  ANT-2.4-WRT-MON VSWR Return Loss 2500 0 2400 Return loss (Figure 5), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. Return Loss (dB) -5 -10 -15 -20 -25 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 Figure 5.  ANT-2.4-WRT-MON Return Loss 4 2480 2490 2500 WRT-MON Series ANT-2.4-WRT-MON-ccc Datasheet Peak Gain 2500 5 2400 The peak gain across the antenna bandwidth is shown in Figure 6. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 0 -5 -10 -15 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 6.  ANT-2.4-WRT-MON Peak Gain Average Gain 2500 5 2400 Average gain (Figure 7), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. Average Gain (dBi) 0 -5 -10 -15 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 7.  ANT-2.4-WRT-MON Antenna Average Gain 5 WRT-MON Series ANT-2.4-WRT-MON-ccc Datasheet Radiation Efficiency 2500 100 2400 Radiation efficiency (Figure 8), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 Figure 8.  ANT-2.4-WRT-MON Antenna Radiation Efficiency 6 2490 2500 WRT-MON Series ANT-2.4-WRT-MON-ccc Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are shown in Figure 9 using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 2400 MHz to 2500 MHz (2450 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 XZ-Plane Gain 17 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 17 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 5 6 7 8 9 10 11 26 12 13 25 24 14 23 16 YZ-Plane Gain 15 22 21 20 19 18 17 16 2400 MHz 2450 MHz 2500 MHz XY-Plane Gain Figure 9.  ANT-2.4-WRT-MON Radiation Patterns 7 WRT-MON Series ANT-2.4-WRT-MON-ccc Datasheet Website: http://linxtechnologies.com Linx Offices: 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 (541) 471-6256 E-MAIL: info@linxtechnologies.com Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their respective owners. Copyright © 2022 Linx Technologies All Rights Reserved Doc# DS22013-201ANT Replaces (Dated release 2017)
ANT-2.4-WRT-MON-SMA 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-WRT-MON-SMA”相匹配的价格&库存,您可以联系我们找货
ANT-2.4-WRT-MON-SMA
  • 5+435.087305+56.57333
  • 50+412.9371450+53.69320
库存:100
