PA.711.A
PA.711.A
    TAOGLASLIMITED
    PA.711.A
PA.711.A 数据手册
Warrior II LTE/Cellular SMD Part No: PA.711.A Description: Pairs with the PA.710.A Warrior for 4G MIMO applications 698MHz to 960MHz, 1710MHz to 2690MHz, 5000 to 5850MHz Features: Supplied as one part of a MIMO pair with PA.710.A on MIMO applications High isolation and ECC when used with PA.710.A on specific board layouts High Efficiency Antenna Patent Pending Surface Mount Technology Dimensions: 40x6x5mm RoHS and REACH Compliant SPE-14-8-063-F 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 26 6. Antenna Integration Guide 27 7. Packaging 36 Changelog 37 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-063-F www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Taoglas PA.711.A is the culmination of a multi-year research effort into LTE MIMO SMD antennas. It has been designed specifically to be used as the second antenna in a 2*2 or higher MIMO setup in conjunction with our standard PA.710.A LTE antenna. The PA.711.A has all the same attributes of the PA.710.A, a high efficiency SMD Ceramic antenna, operating at 698MHz to 960MHz and 1710MHz to 2690MHz. Introduction Due to subtle variation of radiation pattern it delivers high isolation and ECC
PA.711.A
物料型号:PA.711.A 器件简介:PA.711.A是Taoglas公司生产的LTE/Cellular SMD天线,设计为与PA.710.A搭配使用,支持4G MIMO应用。
它是一款高效率的SMD陶瓷天线,工作频段包括698MHz至960MHz和1710MHz至2690MHz。
引脚分配:PA.711.A具有4个引脚,其中1号引脚为RF馈电,2号引脚为地线,3号和4号引脚用于机械强度,不连接电路。
参数特性: - 工作频段:698MHz至960MHz,1710MHz至2690MHz - 峰值增益:1.0dBi至2.9dBi - 平均增益:-2.8dB至-2.6dB - 效率:52%至70% - 驻波比:小于3.0:1 - 阻抗:50欧姆 - 极化方式:线性 - 辐射特性:全向 - 最大输入功率:5W 功能详解:PA.711.A天线通过微妙的辐射模式变化,在与PA.710.A配合使用时,可以提供高隔离度和小于0.3的ECC,从而减少LTE MIMO应用所需的占用空间。
应用信息:该天线适用于需要LTE MIMO应用的场合,如智能手机、平板电脑、移动宽带设备等。
封装信息:尺寸为40x6x5mm,材料为陶瓷,表面贴装技术,符合RoHS和REACH标准。
PA.711.A 价格&库存
很抱歉,暂时无法提供与“PA.711.A”相匹配的价格&库存,您可以联系我们找货
