Specification
Part No.
AA.170.301111
Product Name
Magma IP67 GPS/GLONASS/GALILEO/BeiDou
External Automotive Antenna 3M RG-174 SMA(M)
Feature
Magnetic Mount
3M RG-174
SMA(M) Connector
Front-end SAW
Cable and connector customizable
Automotive TS16949 Quality
Dimensions: 53mm*50mm*17mm
RoHS & REACH Compliant
SPE-15-8-001-D Page 1 of 23
1. Introduction
The AA.170 Magma magnetic mount external antenna is ideal for robust, covert
installations where durability and small size is paramount. This low profile
antenna is tuned for stable operation over GPS-GLONASS-GALILEO-BeiDou
frequency bands and is used in the following typical applications
- Advanced telematics and M2M applications
- Fleet management
Axial ratio is 3 at the main GPS band, indicating good right hand circular
polarization, which increases location accuracy and speed of lock in the GNSS
system. Standard cable and connector version is 3 meter RG174 and SMA(M).
A front-end SAW reduces out-band interference from any nearby wireless
transmitters, helping prevent LNA compression and burnout. The Magma
antenna is manufactured in first tier TS16949 automotive approved facility,
with full PPAP and IMDS documentation available.
Cable length and connector type are customizable upon request. Adhesive
mounting version is also available upon request. Contact your regional Taoglas
customer support team for more information.
SPE-15-8-001-D Page 2 of 23
2. Specification Table
Center Frequency
Antenna Gain
Axial Ratio
Polarization
Frequency
Impedance
ELECTRICAL
1561.098±2.046M
1575.42±1.023
Hz
MHz
+5.55 dBi(typ.)
+4.38 dBi(typ.)
@zenith XZ-Plane
@zenith XZ-Plane
+5.73 dBi(typ.)
+4.46 dBi(typ.)
@zenith YZ-Plane
@zenith YZ-Plane
9.24 dB(typ)
3.01 dB(typ)
@zenith
@zenith
RHCP
1602±8 MHz
+5.98 dBi(typ.)
@zenith XZ-Plane
+5.89 dBi(typ.)
@zenith YZ-Plane
5.94 dB(typ)
@zenith
LNA Electrical Properties
GPS/GALILEO: 1575.42±1.023 MHz
GLONASS: 1602±8 MHz for GLONASS
BeiDou: 1561.098±2.046 MHz
50 Ω
VSWR
2.0 Max.
DC input
1.8V (min.)
3.0V (typ.)
5.5V (max.)
LNA Gain
26dB
30dB
32dB
Noise Figure
2.5dB
2.1dB
2.9dB
Power Consumption
3.2mA
7.2mA
15.6mA
MECHANICAL
Embedded Ceramic Patch
Antenna Dimensions
Housing Dimensions
35 x 35 x 6mm
Housing Material
ABS
Cable
3M RG174 (fully customizable)
Connector
SMA(M) (fully customizable)
Waterproof
IP67
Weight
90g
Magnetic Pull Force
Pull horizontal max pull force(kgf) : 0.52
Pull vertical max pull force(kgf) : 0.48
53*50*17mm
ENVIRONMENTAL
Operation Temperature
-40°C ~ +85°C
Storage Temperature
-40°C ~ +90°C
SPE-15-8-001-D Page 3 of 23
3. Antenna Block Diagram
SPE-15-8-001-D Page 4 of 23
4. Antenna Characteristics
4.1 Return Loss
Frequency (MHz)
Return Loss
1561 MHz
-18.04
1575 MHz
-22.02
1602 MHz
-30.81
SPE-15-8-001-D Page 5 of 23
4.2 VSWR
Frequency (MHz)
VSWR
1561 MHz
1.28
1575 MHz
1.16
1602 MHz
1.05
SPE-15-8-001-D Page 6 of 23
4.3 Impedance
Frequency (MHz)
Impedance
1561 MHz
51.68 + j12.56
1575 MHz
42.61 + j0.43
1602 MHz
47.35 - j0.61
SPE-15-8-001-D Page 7 of 23
4.4 Radiation Pattern
SPE-15-8-001-D Page 8 of 23
4.4.1 1561MHz
XZ-Plane
Z
X
1561MHZ
Peak Gain
Zenith Gain
V+H
5.55 dBi
5.55 dBi
SPE-15-8-001-D Page 9 of 23
YZ-Plane
Z
Y
1561MHZ
Peak Gain
Zenith Gain
V+H
5.75 dBi
5.73 dBi
SPE-15-8-001-D Page 10 of 23
4.4.2 1575.42MHz
XZ-Plane
Z
X
1575MHZ
Peak Gain
Zenith Gain
V+H
4.38 dBi
4.38 dBi
SPE-15-8-001-D Page 11 of 23
YZ-Plane
Z
Y
1575MHZ
Peak Gain
Zenith Gain
V+H
4.46 dBi
4.46 dBi
SPE-15-8-001-D Page 12 of 23
4.4.3 1602MHz
XZ-Plane
Z
X
1602MHZ
Peak Gain
Zenith Gain
V+H
5.98 dBi
5.98 dBi
SPE-15-8-001-D Page 13 of 23
YZ-Plane
Z
Y
1602MHZ
Peak Gain
Zenith Gain
V+H
5.89 dBi
5.89 dBi
SPE-15-8-001-D Page 14 of 23
4.5 Axial Ratio Pattern (Spin Dipole Method)
4.5.1 1561MHz
Angle
Axial Ratio
90°
6.81
75°
5.99
60°
6.36
45°
7.10
30°
8.32
15°
9.43
0°
9.24
345°
8.76
330°
7.06
315°
5.27
300°
4.43
285°
4.45
270°
6.24
SPE-15-8-001-D Page 15 of 23
4.5.2 1575.42MHz
Angle
Axial Ratio
90°
2.39
75°
1.89
60°
1.35
45°
2.09
30°
3.02
15°
3.98
0°
3.01
345°
4.38
330°
3.47
315°
2.24
300°
0.86
285°
1.08
270°
1.60
SPE-15-8-001-D Page 16 of 23
4.5.3 1602MHz
Angle
Axial Ratio
90°
13.33
75°
14.09
60°
13.20
45°
10.69
30°
8.50
15°
6.90
0°
5.94
345°
6.76
330°
8.21
315°
10.25
300°
13.66
285°
15.16
270°
15.45
SPE-15-8-001-D Page 17 of 23
5. GPS/GLONASS/Beidou LNA
5.1 LNA Gain and Output VSWR@3.0V
5.2 LNA Noise@3.0V
SPE-15-8-001-D Page 18 of 23
6. Magnetic Pull Force (kilogram – force (kgf)
Horizontal Pull Force Breakdown Limit: 0.52kgf
SPE-15-8-001-D Page 19 of 23
Vertical Pull Force Breakdown Limit: 1.23 kgf
SPE-15-8-001-D Page 20 of 23
7. Mechanical Drawing
SPE-15-8-001-D Page 21 of 23
8. Packaging
SPE-15-8-001-D Page 22 of 23
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
© Taoglas
SPE-15-8-001-D Page 23 of 23
很抱歉,暂时无法提供与“AA.170.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+392.76710
- 5+346.25630
- 10+299.73363
- 50+288.45002
- 100+277.15454
