SPECIFICATION
Part No.
MA203.A.AB.035
Product Name
MA203 Stingray GPS/GALILEO/Cellular
Adhesive Antenna
Features
GPS/GALILEO - High gain LNA up to 32dB
Penta-band Cellular – 800MHz to 2200MHz
GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/HSPA
Height 10.8mm Diameter 55.1mm
RoHS Compliant
Top View
Underside View
(this side faces the sky)
(this side faces the passenger)
SPE-11-8-001/F/SS
Page 1 of 9
1. Introduction
This is a combination high performance GPS/GALILEO and Penta-band Cellular (GSM /
CDMA / PCS / DCS / UMTS / GPRS / EDGE / HSPA) antenna to simplify AVL or Fleet
management antenna systems worldwide. Its high quality low profile covert housing
can be attached onto the glass or even out of sight under the dashboard. This
combination of a high gain GPS/GALILEO antenna and a leading edge penta band
cellular antenna is ideal for those applications that require durability, small size and
covert installation, and reliable reception and transmission crossing through different
mobile networks.
The standard version has 3 metres RG174 cable and SMA(M) connector on both
GPS/GALILEO and Cellular. The cables and connectors are completely customizable
according to customer requrest.
1.1. Features
GPS/GALILEO
High LNA Gain up to 32 dB
Antenna Gain 30 ± 2 dB
Miniaturized to 55.15x12mm
Low Noise 1.5 dB max
Cellular
Advanced penta-band cellular antenna
(GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/ HSPA)
Other
Water Resistant IP 65 (IP 67 MA.203w version also available)
Quality textured covert design. Low profile
UV resistant ABS housing
Comes with high grade 3M double sided tape for quick and easy mounting
Customizable cables and connectors
SPE-11-8-001/F/SS
Page 2 of 9
2. Specification
CELLULAR ANTENNA
Frequency Range
Centre Frequency
800MHz to 2200MHz
850 MHz
900MHz
1800Mhz
1900MHz
Peak Gain
Horizontal (dBi) Peak
-16.30
-15.51
-9
-14.38
Vertical (dBi) Peak
-11.10
-7.85
-14.04
-16.99
Horiz. + Vert. (dBi) Peak
-10.99
-7.61
-8.76
-14.38
Average Gain
Horizontal (dB) Average
-20.60
-20.63
-13.95
-18.49
Vertical (dB) Average
-13.68
-11.23
-18.04
-20.86
Horiz. + Vert. (dB) Average
-12.88
-10.75
-12.52
-16.51
VSWR
很抱歉,暂时无法提供与“MA.203.A.AB.035”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+372.714501+48.44165
