AGGP.25F.07.0060A
AGGP.25F.07.0060A
    TAOGLASLIMITED
    AGGP.25F.07.0060A
AGGP.25F.07.0060A 数据手册
25mm 2 Stage GNSS Active Patch Part No: AGGP.25F.07.0060A Description: 25mm Two Stage GPS-GLONASS-GALILEO GNSS Active Patch Antenna Module with Front-End Saw Filter Features: Industry leading GPS-GLONASS-GALILEO antenna performance 25.1*25.1*7.4mm (Ground Plane) Connector: IPEX MHFI (U.FL) Cable: 60mm of Ø1.13mm coax 28dB LNA Wide Input Voltage 1.8V to 5.5V Low Power Consumption RoHS & Reach Compliant SPE-12-8-015-C 1. Introduction 3 2. Specifications 4 3. LNA Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing 10 6. Usage Precautions 11 7. Packaging 12 Changelog 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-015-C www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The AGGP.25F GPS/GLONASS/GALILEO GNSS active patch antenna (along with the AGGP.35 model) is the best choice to use as an embedded antenna with the latest generation of GPS/GLONASS/GALILEO GNSS receivers. It utilizes a 25.1*25.1*4mm advanced wide-band ceramic patch antenna with optimized gain, radiation pattern and axial ratio at GPS, GLONASS and GALILEO centre frequencies. Introduction The AGGP.25F also includes a two stage LNA and a front-end SAW filter to reduce out of band noise such as from nearby cellular transceiver, and improve probability of the wireless device passing radiated spurious emissions certification. Produced in TS16949 automotive quality approved facility and 100% tested for gain (S21), return loss (S11) to ensure total consistency of performance. Introduction Cable type, length and connectors can be customized and samples offered according to requirement, subject to minimum order quantities in production. Taoglas also offers custom tuning service based on minimum order quantities, contact your local regional sales office for details. Introduction The AGGP.25F consists of 2 functional blocks – the LNA and also the patch antenna. SPE-12-8-015-C www.taoglas.com 3 2. Specifications 3. GNSS Frequency Bands Covered Antenna L1Characteristics2. Specifications L2 L5 L6 GPS/QZSS 3. 1227.6MHz 1176.45MHz 1278.75MHz ■ □ □ □ L5R L3PT L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ □ □ ■ ■ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz L1 1575.42MHz □ □ ■ Antenna Characteristics 1176.45MHz 1201.5MHz GLONASS Galileo 4. 1575.42MHz Antenna □Radiation□Patterns3. Antenna □ □ B1 BeiDou Characteristics2. 1561MHz Compass 3. □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ Antenna □Characteristics2. □ SBAS 3. B2 B3 Specifications 1207.14MHz 1268.52MHz Specifications ■ Antenna □Characteristics GNSS Electrical Frequency (MHz) 4. 1575.42 1602 Antenna Radiation Patterns3.Antenna Gain at zenith (dBic) 1.5 Gain at 90° (dBic) Characteristics Axial Ratio at zenith (dB) 0 26.5 28
AGGP.25F.07.0060A 价格&库存
很抱歉,暂时无法提供与“AGGP.25F.07.0060A”相匹配的价格&库存,您可以联系我们找货
AGGP.25F.07.0060A
  • 100+89.14696
库存:8
