SPECIFICATION
Part No.
WS.02.B.205111
Product Name
4dBi 2.4GHz Omni-Directional
Heavy Duty Screw Mount Antenna
Features
Wi-Fi/ISM Bands/ZigBee/WLAN/ Bluetooth
UV and Vandal Resistant ABS Housing
Cable length and connector customizable
IP67 & IP69K Waterproof Rating
2M CFD-200 SMA(M) – Standard
RoHS Compliant
SPE-14-8-055/C/YL
Page 1 of 21
1 Introduction
WS.02 Hercules is a high efficiency, high gain thread mount 2.4GHz wireless antenna for
external use on vehicles and outdoor assets worldwide. Omni-directional gain across the
frequency bands ensures constant reception and transmission making the WS.02 an ideal
solution for a Zigbee Wireless Mesh for remote applications e.g. – remote metering.
It has been designed for heavy duty work with extra thick threads; with durable UV-resistant PC
housing, it is resistant to vandalism and direct attack. At only 29 mm high it complies with the
latest EU height restrictions directives for roof-mounted objects, whilst also enabling covert
operation with a diameter of 49mm.
Many module manufacturers specify peak gain limits for any antennas that are to be connected
to that module. Those peak gain limits are based on free-space conditions. In practice, the peak
gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a
device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the
module specification to compensate for this effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate layout,
integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be
below the peak gain limits. Taoglas can then issue a specification and/or report for the selected
antenna in your device that will clearly show it complying with the peak gain limits, so you can
be assured you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have less than 2dBi peak
gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi
in free-space. This will give you a less optimized solution. It is better to go for a slightly higher
free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your
device, performance will degrade below this 2dBi peak gain due to the effects of GND plane,
surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas
and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by
SPE-14-8-055/C/YL
Page 2 of 21
the module manufacturer and enlisting our help will ensure you are getting the best performance
possible without exceeding the peak gain limits.
The antenna housing is completely waterproof to IP67, and also to IP69K, which means it is
waterproof against high pressure water jets used in industrial environments for cleaning. Low
loss industrial coax cable is used to achieve high gain and efficiency over long cable length.
SPE-14-8-055/C/YL
Page 3 of 21
2 Specification
ELECTRICAL
Frequency (GHz)
2.4
2.45
2.5
VSWR
1.38
1.80
1.89
Return Loss (dB)
-15.86
-10.87
-10.23
Peak Gain(dB)
4.42
4.16
4.75
Avg Gain (dB)
-2.48
-2.69
-1.98
Efficiency (%)
56.5
53.9
63.4
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
Cable/Connectors
Recommended Mounting
Torque
Maximum Mounting Torque
2M CFD-200 SMA(M)
24.5N·m
29.4N·m
MECHANICAL
Dimensions
Height 28.5mm x Diameter 47.8mm
Casing
UV resistant PC
Base and thread
Nickel plated Steel/Zinc
Thread diameter
18mm
Weather proof gasket
CR4305 foam with 3M9448B double-side adhesive
Antenna Weight
0.13kg
ENVIRONMENTAL
Waterproof
Corrosion
IP67 & IP69K
5% NaCl for 48hrs - Nickel plated steel base and
thread
Temperature Range
-40°C to +85°C
Thermal Shock
100 cycles -40°C to +80°C
Humidity
Non-condensing 65°C 95% RH
Shock (drop test)
1m drop on concrete 6 axes
Cable pull
8 KGf
* Value above is for standard 2 meter CFD 200 cable tested in free space. The WS.02.B.205111 antenna performance
was measured with CFD 200 coaxial cable at 300 mm, 1 meter, 2 meter, 3 meter and 5 meter length with and without
a 30x30 cm ground plane.
SPE-14-8-055/C/YL
Page 4 of 21
3 Antenna Characteristics
3.1
Test set-up
Figure 1. Return loss measurements.
SPE-14-8-055/C/YL
Page 5 of 21
Y
Y
Z
X
Z
X
Figure 2. Peak gain, efficiency and radiation pattern measurements
SPE-14-8-055/C/YL
Page 6 of 21
3.2
Return Loss (in Free Space)
Figure 3. Return Loss of the Hercules WS.02 antenna with different length CFD200 cable in free space
3.3
Return Loss (on 30 x 30 cm Ground Plane)
Figure 4. Return Loss of the Hercules WS.02 antenna with different length CFD200 cable on 30 x 30cm
ground plane
SPE-14-8-055/C/YL
Page 7 of 21
3.4
VSWR (in Free Space)
Figure 5. VSWR of the Hercules WS.02 antenna with different length CFD200 cable in free space
3.5
VSWR (on 30 x 30cm Ground Plane)
Figure 6. VSWR of the Hercules WS.02 antenna with different length CFD200 cable on 30 x 30cm ground
plane
SPE-14-8-055/C/YL
Page 8 of 21
3.6
Efficiency (in Free Space)
Figure 7. Efficiency of the Hercules WS.02 antenna with different length CFD200 cable in free space
3.7
Efficiency (on 30 x 30 cm Ground Plane)
Figure 8. Efficiency of the Hercules WS.02 antenna with different length CFD200 cable on 30 x 30 cm
ground plane
SPE-14-8-055/C/YL
Page 9 of 21
3.8
Peak Gain (in Free Space)
Figure 9. Peak Gain of the Hercules WS.02 antenna with different length CFD200 cable in free space
3.9
Peak Gain (on 30 x 30 cm Ground Plane)
Figure 10. Peak Gain of the Hercules WS.02 antenna with different length CFD200 cable on 30 x 30 cm
ground plane
SPE-14-8-055/C/YL
Page 10 of 21
3.10
Average Gain (in Free Space)
Figure 11. Average Gain of the Hercules WS.02 antenna with different length CFD200 cable in free space
3.11
Average Gain (on 30 x 30 cm Ground Plane)
Figure 12. Average Gain of the Hercules WS.02 with different length CFD200 cable on 30 x 30 cm ground
plane
SPE-14-8-055/C/YL
Page 11 of 21
3.12
Results Table (Free Space)
FREQUENCY [MHz]
EFFICIENCY [%]
300 MM
1 METER
2 METER
3 METER
5 METER
2200
58.4
55.5
45.9
55.6
32.4
2225
55.3
56.9
54.4
46.9
32.1
2250
55.1
54.5
54.4
50.8
34.2
2275
57.1
53.0
61.6
51.8
35.6
2300
57.1
59.0
48.4
51.4
35.0
2325
59.7
58.8
57.9
52.0
35.8
2350
61.1
56.0
56.3
53.1
35.6
2375
65.5
57.4
59.4
55.4
35.3
2400
62.9
60.0
56.5
53.
33.4
2425
64.2
59.6
54.7
53.4
31.7
2442
68.0
63.8
54.6
51.7
35.8
2450
69.5
65.4
53.9
52.7
34.1
2475
76.8
69.3
55.7
54.4
34.0
2484
83.3
69.7
57.7
53.1
36.7
2500
79.0
66.4
63.4
58.2
31.3
2515
78.8
69.6
56.1
50.7
38.2
2535
70.4
73.8
58.4
57.3
38.1
2555
64.7
66.1
57.7
42.1
33.6
2570
65.8
61.2
53.7
50.3
27.7
2595
73.2
59.3
52.6
41.1
28.3
2600
72.5
60.2
57.6
43.8
30.8
2650
69.1
53.5
42.7
40.4
30.4
2700
57.9
52.1
32.4
37.2
27.2
SPE-14-8-055/C/YL
Page 12 of 21
3.13
Results Table (on 30 x 30 cm Ground Plane)
FREQUENCY [MHz]
2200
2225
2250
2275
2300
2325
2350
2375
2400
2425
2442
2450
2475
2484
2500
2515
2535
2555
2570
2595
2600
2650
2700
EFFICIENCY [%]
300 mm
1 meter
2 meter
3 meter
5 meter
81.2
76.1
75.7
76.2
76.8
78.8
79.6
82.2
81.1
80.8
83.2
83.8
87.3
88.0
84.5
85.0
79.9
77.5
78.0
84.5
83.2
76.1
68.5
74.3
72.8
71.0
68.2
73.7
75.5
73.3
74.7
75.1
73.6
75.6
76.3
78.3
79.5
80.7
81.6
77.6
68.1
68.2
75.5
75.4
64.8
66.1
66.2
66.4
70.1
70.0
69.5
68.8
69.5
70.4
71.7
70.5
69.8
68.4
67.6
67.1
67.0
67.4
67.5
67.1
67.5
68.9
68.0
67.3
65.8
59.2
51.7
57.6
56.0
54.3
55.2
51.8
53.1
53.5
52.3
51.0
53.8
53.4
57.6
56.8
55.9
62.7
52.6
57.2
50.3
51.3
43.3
41.2
42.7
40.6
41.7
41.6
40.5
41.3
41.2
42.9
41.6
39.8
43.0
42.3
41.6
44.0
38.1
44.0
42.6
37.7
31.4
34.0
36.6
36.9
31.4
SPE-14-8-055/C/YL
Page 13 of 21
3.14
3D Radiation Patterns (2 meter Standard cable, Free Space)
Figure 13. 3D Radiation Pattern at 2450 MHz of the WS.02 Antenna with standard 2 meter cable
SPE-14-8-055/C/YL
Page 14 of 21
3.15
2D Radiation Patterns (2 meter Standard cable, Free Space)
XY Plane
SPE-14-8-055/C/YL
Page 15 of 21
XZ Plane
SPE-14-8-055/C/YL
Page 16 of 21
YZ Plane
Figure 14. 2D Radiation Pattern of the WS.02 Antenna with standard 2 meter cable
SPE-14-8-055/C/YL
Page 17 of 21
4 Technical Drawing
Figure 15. Technical Drawing
SPE-14-8-055/C/YL
Page 18 of 21
5 Installation
Figure 16. Installation
SPE-14-8-055/C/YL
Page 19 of 21
6 Packaging
1pc per PE Bag (Weight 0.13Kg)
40 PE Bags per Carton
Figure 17. Packaging
SPE-14-8-055/C/YL
Page 20 of 21
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves
the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all
rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-055/C/YL
Page 21 of 21
很抱歉,暂时无法提供与“WS.02.B.205111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+216.76749
- 11+212.76537
- 21+208.76325
- 41+204.74904
