SPECIFICATION
Part No.
MA760.A.ABIC.003
Product Name
Pantheon Antenna 4in1 MA760
Screw-Mount (Permanent Mount)
2G/3G/4G MIMO LTE, GPS/GLONASS Wi-Fi 2.4/5GHz
Feature
2 x Cellular (2G/3G/4G) MIMO Antennas
(698~960MHz, 1710~2170MHz,2300~2700MHz,
2900-3500MHz)
1 x GPS/GLONASS 1575.42~1602MHz Active Antenna
1 x Wi-Fi 2.4GHZ/ 5GHz Antennas
IP67 Waterproof
High Efficiency / Peak Gain Outdoor Antenna
RoHS Compliant
SPE-13-8-001/G/PK
Page 1 of 24
1. Introduction
The MA760 4in1 antenna is an omnidirectional heavy-duty, fully IP67 waterproof
external M2M antenna for use in telematics, transportation and remote monitoring
applications. It is the first antenna on the market to combine 4in1 that includes two
LTE MIMO elements, one 2.4GHz/5GHz antenna and GPS/GLONASS in the highest
efficiency and peak gain possible. This unique antenna delivers powerful MIMO
antenna technology for LTE while also fully compatible with legacy 2G and 3G
networks worldwide, plus GPS/GLONASS for next generation high bandwidth
telematics systems.
New fleet management and mobile and fixed video technology allows for real-time
video uplink and downlink. High efficiency, high gain MIMO antennas are necessary to
achieve the high signal to noise ratio and throughput required to solve these
challenges. The Pantheon MA760 consists of two Cellular 2G/3G/4G MIMO elements
working at 698-960MHz, 1710-2170MHz, 2300~2700MHz, 2900-3500MHz which
means it can work worldwide, one high gain GPS/GLONASS antenna at 1575.42 MHz
and one dual-band Wi-Fi 2.4GHz/5GHz antenna.
The 4 high efficiency and gain antennas are mounted in an extremely robust IP67
direct mount antenna package with excellent isolation (20dB+). The antenna has its
own ground-plane and can radiate on any mounting environment like metal or plastic
without affecting performance.
The GPS/GLONASS antenna has a front end SAW filter configuration. The front-end
SAW increases protection against out of band LNA burn out.
The Dual-band Wi-Fi antenna has stable efficiency and peak gain on both bands even
at 3 meters cable length where other antennas would have marked reduced
performance.
The connectors and cable lengths are customizable. The housing is also available in
White. Recommended maximum cable length is 3 meters.
SPE-13-8-001/G/PK
Page 2 of 24
2. Specification Table
Frequency (Mhz)
698~960
1710~2170
VSWR
Polarization
Impedance
2300~2700
2900-3500
3 Max
Vertical
50 Ω
2.4GHz / 5GHz ANTENNA
2.4 ~ 2.5
4.7 ~ 5.0
5.0 ~ 5.4
2.1
2.9
3.8
-2.3
-3.6
-3.3
60%
44%
46%
很抱歉,暂时无法提供与“MA760.A.ABIC.003”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2682.496001+348.59720
- 10+2377.6501310+308.98170
- 25+2272.3984025+295.30397
- 国内价格 香港价格
- 1+3217.328161+418.10000
