ANT-2.4-OC-LG-RPS
ANT-2.4-OC-LG-RPS
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    ANT-2.4-OC-LG-RPS
ANT-2.4-OC-LG-RPS 数据手册
™ ANT-2.4-OC-LG-xxx DATA SHEET Product Dimensions Description The OC series ½-wave dipole antennas provide higher gain than a standard whip antenna for increased range and reliability of wireless links. Using loaded coil technology, the OC series antennas minimize the length that would typically be required to achieve omni-directional gain. The articulating base allows the antenna to tilt 90 degrees and rotate 360 degrees. The antenna’s internal counterpoise eliminates external ground plane dependence and maximizes performance. OC series antennas attach via a standard SMA or Part 15 Compliant RP-SMA connector. 0.21” (5.3) Features 0.34” (8.5) 6.76” (171.8) 7.62” (193.5) • • • • • • • • Low cost Compact size Tilts and rotates Internal counterpoise Omni-directional pattern Increased gain versus standard whip antennas Standard SMA or Part 15 compliant RP-SMA connector Custom colors and terminations for volume OEMs Electrical Specifications • • • • • • Center Freq. Recmd. Freq. Range Wavelength VSWR Impedance Connector 2.45GHz 2.39-2.55GHz 1/2-wave
ANT-2.4-OC-LG-RPS 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-OC-LG-RPS”相匹配的价格&库存,您可以联系我们找货
