TG.35.8113W
TG.35.8113W
    TAOGLASLIMITED
    TG.35.8113W
TG.35.8113W 数据手册
SPECIFICATION Part No. : TG.35.8113W Product Name : Apex II – White Hinged TG.35 Ultra-Wideband 4G LTE Antenna Features : Highest efficiency for worldwide LTE and Wi-Fi LTE / HSPA / GSM / CDMA /DCS /PCS / WCDMA / UMTS / GPRS / EDGE /GPS /Wi-Fi Dims: 224*58mm 698MHz to 960MHz, 1575.42MHz 1710MHz to 2700Mhz 5150MHz to 5850MHz Dipole Swivel Terminal Antenna Hinged 90° termination with SMA(M) Connector Enhanced hinge structure for vibration environment Connector customizable RoHS Compliant Photo: SPE-14-8-083/E/PK Page 1 of 71 1. Introduction The hinged Apex II TG.35 Ultra-Wideband Dipole Antenna has been designed to cover all Cellular, ISM and Wi-Fi working frequencies in the 700-6000MHz spectrum. Evolved from the already highly successful Apex TG.30, this second generation has the highest wide-band efficiency in its range of any terminal antenna on the market today. The Apex II has been primarily designed for use with 4G LTE modules and devices that require the highest possible efficiency and peak gain to deliver best in class throughput on all major cellular (2G/3G/4G) bands worldwide for access points, terminals and routers. High efficiency is vital for applications such as high speed video and real-time streaming, or high capacity MIMO networks on public transportation. This attractive slim-line antenna is ground plane independent, meaning it does not need to be connected to the ground-plane of a device to radiate efficiently, on the other hand neither is it seriously detuned by connecting to a ground-plane, thus avoiding a problem notorious to smaller antennas. It comes with an SMA(M) connector and swivel mechanism that allows the antenna part to be rotated to fit in tight environments. The 90° hinge structure has been improved and strengthened so that the antenna in a 90° position would not fall down to 180° in vibration environment. The Apex II is backward compatible with 3G and 2G cellular applications such as HSPA, GSM, GPRS, UMTS, Wi-Fi and even has GPS included for Assisted GPS and/or E911 applications. In summary the Apex II is the ideal solution for any device requiring high, reliable performance. It will meet most type approval or carrier certification requirements from an efficiency standpoint. The antenna also makes an excellent reference antenna for test purposes. It has been designed as an omni-directional antenna and the radiation patterns prove this, being stable across all bands. Connector type is customizable. Housing is also available in black. Contact Taoglas regional sales office for more information. SPE-14-8-083/E/PK Page 2 of 71 2. Specification ELECTRICAL LTE/GSM/CDMA GPS/GLONAS Standard Frequency (MHz) 700/850/900 S 698~960 1565~1612 LTE/GSM/HSPA/CD MA 1700/1800/1900 1710~1990 UMTS/HSPA Wi-Fi LTE Wi-Fi 2100 2400 2600 5800 2500~2700 4800~6000 1920~2170 2400~2500 Efficiency (%) In free space On 150*90mm ground plane edge On 30*30cm ground plane center On 30*30cm ground plane edge straight 53.92 55.66 64.44 62.55 49.61 53.14 56.35 bent 56.51 55.19 68.87 68.72 53.41 54.11 55.84 straight 84.72 66.85 71.00 71.43 56.21 52.22 51.59 bent 80.92 71.38 71.62 71.14 52.81 53.28 51.82 straight 59.06 51.56 62.34 61.21 67.43 53.51 51.25 bent 57.15 36.67 52.88 57.70 60.70 58.10 56.74 straight 59.62 48.19 65.51 64.78 63.28 56.84 56.30 bent 53.18 41.91 63.43 62.24 62.99 46.66 47.09 Average Gain(dBi) In free space On 150*90mm ground plane edge On 30*30cm ground plane center On 30*30cm ground plane center straight -2.71 -2.55 -1.91 -2.05 -3.05 -2.76 -2.59 bent 90° -2.50 -2.61 -1.63 -1.64 -2.72 -2.67 -2.63 straight -0.74 -1.75 -1.50 -1.46 -2.50 -2.82 -2.92 bent 90° -0.96 -1.46 -1.45 -1.48 -2.77 -2.74 -2.89 straight -2.31 -2.88 -2.06 -2.13 -1.74 -2.72 -2.94 bent 90° -2.44 -4.36 -2.78 -2.40 -2.18 -2.37 -2.52 straight -2.26 -3.17 -1.85 -1.89 -2.01 -2.45 -2.58 bent 90° -2.81 -3.78 -1.99 -2.08 -2.02 -3.32 -3.37 straight 4.42 1.59 3.15 2.70 4.93 4.43 2.55 Peak Gain(dBi) In free space bent 3.16 1.64 3.37 3.34 3.28 3.06 2.09 On the 150*90mm ground plane edge straight 3.28 3.70 4.79 5.02 2.50 2.36 2.67 bent 2.77 3.24 4.07 4.35 4.47 3.80 2.68 On the 30*30cm ground plane center straight 6.37 0.75 3.34 3.39 6.44 6.92 5.29 bent 6.47 5.12 6.27 6.44 5.78 8.14 6.05 On the 30*30cm ground plane center straight 4.87 1.70 3.62 4.01 4.63 6.02 4.87 bent 4.78 4.07 5.95 5.45 5.87 3.89 4.59 straight 4.42 1.59 3.15 2.70 4.93 4.43 2.55 bent 3.16 1.64 3.37 3.34 3.28 3.06 2.09 In free space Impedance 50Ω Polarization Linear Radiation Pattern Omni Input Power 5W SPE-14-8-083/E/PK Page 3 of 71 MECHANICAL Casing UV Resistant PC/ABS Connector SMA Male Hinged 90° Weight 75g Recommended Torque for Mounting 0.9 N∙m Max torque for Mounting 1.176 N∙m ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-14-8-083/E/PK Page 4 of 71 3. Antenna Characteristics 3.1 Testing setup In free space Antenna straight Antenna bent 90° On 150*90mm ground plane edge Antenna straight Antenna bent 90° SPE-14-8-083/E/PK Page 5 of 71 On 30*30cm ground plane center Antenna straight Antenna bent 90° On 30*30cm ground plane edge Antenna straight Antenna bent 90° SPE-14-8-083/E/PK Page 6 of 71 3.2 Return Loss In free space On 150*90mm ground plane edge SPE-14-8-083/E/PK Page 7 of 71 On 30*30cm ground plane center On 30*30cm ground plane edge SPE-14-8-083/E/PK Page 8 of 71 3.3 Peak Gain SPE-14-8-083/E/PK Page 9 of 71 3.4 Efficiency SPE-14-8-083/E/PK Page 10 of 71 3.5 Average Gain SPE-14-8-083/E/PK Page 11 of 71 4. Antenna Radiation Patterns 4.1 Antenna setup Y X Z Antenna straight in the free space SPE-14-8-083/E/PK Page 12 of 71 4.2 Antenna radiation patterns 4.2.1 Antenna straight in free space XY plane Y 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 XZ plane X 704MHz 751MHz 824MHz 880MHz 960MHz 150 180 (dBi) Z X SPE-14-8-083/E/PK Page 13 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 704MHz 751MHz 824MHz 880MHz 960MHz 150 180 (dBi) XY plane Y 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 (dBi) X 1710MHz 1800MHz 1990MHz 2170MHz SPE-14-8-083/E/PK Page 14 of 71 XZ plane Z X YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 150 180 (dBi) 1710MHz 1880MHz 1990MHz 2170MHz SPE-14-8-083/E/PK Page 15 of 71 XY plane Y 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 (dBi) XZ plane Z X SPE-14-8-083/E/PK Page 16 of 71 YZ plane Z Y XY plane Y 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 (dBi) X 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz SPE-14-8-083/E/PK Page 17 of 71 XZ plane Z X YZ plane Z Y SPE-14-8-083/E/PK Page 18 of 71 4.3 Antenna setup Y X Z Antenna bent 90° in free space SPE-14-8-083/E/PK Page 19 of 71 4.4 Antenna radiation patterns 4.4.1 Antenna bent 90° in free space XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 20 of 71 Z YZ plane 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 704MHz 751MHz 824MHz 880MHz 960MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 21 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 (dBi) YZ plane Z Y SPE-14-8-083/E/PK Page 22 of 71 XY plane Y X XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 X 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 23 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 24 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz 150 (dBi) 180 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 (dBi) Y 4900M Hz 5150M Hz SPE-14-8-083/E/PK Page 25 of 71 4.5 Antenna setup Y X Z Antenna bent 90° with 90*150mm ground plane SPE-14-8-083/E/PK Page 26 of 71 4.6 Antenna radiation patterns 4.6.1 Antenna bent 90° with 90*150mm ground plane XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 27 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 704MHz 751MHz 824MHz 880MHz 150 180 XY plane Y (dBi) Y X SPE-14-8-083/E/PK Page 28 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 (dBi) YZ plane Z Y SPE-14-8-083/E/PK Page 29 of 71 XY plane Y X XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 150 180 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 30 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 XY plane Y (dBi) Y X SPE-14-8-083/E/PK Page 31 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 YZ plane X 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz (dBi) Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 Y 4900M Hz 5150M Hz (dBi) SPE-14-8-083/E/PK Page 32 of 71 4.7 Antenna setup Y X Z Antenna bent 90° with 90*150mm ground plane SPE-14-8-083/E/PK Page 33 of 71 4.8 Antenna radiation patterns 4.8.1 Antenna bent 90° with 90*150mm ground plane XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 34 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 704MHz 751MHz 824MHz 880MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 35 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 YZ plane X (dBi) Z Y SPE-14-8-083/E/PK Page 36 of 71 XY plane Y X XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 150 180 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 37 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 38 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz 150 180 YZ plane (dBi) Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 Y 4900M Hz 5150M Hz (dBi) SPE-14-8-083/E/PK Page 39 of 71 4.9 Antenna setup Y X Z Antenna straight with 30*30cm ground plane center SPE-14-8-083/E/PK Page 40 of 71 4.10 Antenna radiation patterns 4.10.1 Antenna straight with 30*30cm ground plane center XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 41 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 704MHz 751MHz 824MHz 880MHz 150 180 XY plane Y (dBi) Y X SPE-14-8-083/E/PK Page 42 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 YZ plane X (dBi) Z Y SPE-14-8-083/E/PK Page 43 of 71 XY plane Y X XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 150 180 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 44 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 45 of 71 XZ plane Z 330 300 270 0 5 0 -5 -10 -15 -20 -25 -30 -35 -40 30 60 90 240 120 210 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz 150 180 X (dBi) YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 Y 4900M Hz 5150M Hz (dBi) SPE-14-8-083/E/PK Page 46 of 71 4.11 Antenna setup Y X Z Antenna bent 90° with 30*30cm ground plane center SPE-14-8-083/E/PK Page 47 of 71 4.12 Antenna radiation patterns 4.12.1 Antenna bent 90° with 30*30cm ground plane center XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 48 of 71 YZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 704MHz 751MHz 824MHz 880MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 49 of 71 XZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 (dBi) YZ plane Z Y SPE-14-8-083/E/PK Page 50 of 71 XY plane Y X XZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 150 180 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 51 of 71 YZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 52 of 71 XZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 X 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz (dBi) YZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 Y 4900M Hz 5150M Hz (dBi) SPE-14-8-083/E/PK Page 53 of 71 4.13 Antenna setup Y X Z Antenna straight with 30*30cm ground plane edge SPE-14-8-083/E/PK Page 54 of 71 4.14 Antenna radiation patterns 4.14.1 Antenna straight with 30*30cm ground plane edge XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 55 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 704MHz 751MHz 824MHz 880MHz 960MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 56 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 YZ plane X (dBi) Z Y SPE-14-8-083/E/PK Page 57 of 71 XY plane Y X XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 X 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 58 of 71 Z YZ plane 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 Y 2300MHz 2500MHz 2570MHz 2700MHz (dBi) XY plane Y X SPE-14-8-083/E/PK Page 59 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 (dBi) 180 YZ plane X 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 (dBi) Y 4900M Hz 5150M Hz SPE-14-8-083/E/PK Page 60 of 71 4.15 Antenna setup Y X Z Antenna bent 90° with 30*30cm ground plane edge SPE-14-8-083/E/PK Page 61 of 71 4.16 Antenna radiation patterns 4.16.1 Antenna bent 90° with 30*30cm ground plane edge XY plane Y X XZ plane Z X SPE-14-8-083/E/PK Page 62 of 71 YZ plane Z 330 300 270 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 704MHz 751MHz 824MHz 880MHz 960MHz 150 180 XY plane Y (dBi) Y X SPE-14-8-083/E/PK Page 63 of 71 XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 X 120 210 1710MHz 1880MHz 1990MHz 2170MHz 150 180 (dBi) YZ plane Z Y SPE-14-8-083/E/PK Page 64 of 71 XY plane Y X XZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 X 2300MHz 2500MHz 2570MHz 2700MHz (dBi) SPE-14-8-083/E/PK Page 65 of 71 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 Y 120 210 2300MHz 2500MHz 2570MHz 2700MHz 150 180 (dBi) XY plane Y X SPE-14-8-083/E/PK Page 66 of 71 XZ plane Z 330 300 270 0 5 0 -5 -10 -15 -20 -25 -30 -35 -40 30 60 90 X 240 120 210 4900MHz 5150MHz 5350MHz 5650MHz 5850MHz 150 (dBi) 180 YZ plane Z 330 300 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 0 30 60 90 240 120 210 150 180 (dBi) Y 4900M Hz 5150M Hz SPE-14-8-083/E/PK Page 67 of 71 5. Installation SPE-14-8-083/E/PK Page 68 of 71 6. DRAWING SPE-14-8-083/E/PK Page 69 of 71 7. Packaging SPE-14-8-083/E/PK Page 70 of 71 SPE-14-8-083/E/PK Page 71 of 71
TG.35.8113W 价格&库存
很抱歉,暂时无法提供与“TG.35.8113W”相匹配的价格&库存,您可以联系我们找货
TG.35.8113W
    • 1+499.50000
    • 200+199.30320
    • 500+192.65040
    • 1000+189.35640
