TI.16.5F11
TI.16.5F11
    TAOGLASLIMITED
    TI.16.5F11
TI.16.5F11 数据手册
SPECIFICATION Part No. : TI.16.5F11 Product Name : 915MHz 5dBi Outdoors Omni-Directional Rigid Whip Antenna Feature : Stable performance at 902 MHz to 928MHz Omni-directional pattern in the azimuth Robust Weatherproof Brass Whip and Casing High Efficiency N-type Male Connector RoHS compliant SPE-12-8-027/C/JC/PK Page 1 of 13 I. Introduction TI.16 is a 5dBi 915MHz ISM band (902MHz to 928MHz) Dipole Omni-directional antenna. This robust whip is suitable for outdoors applications where wide coverage is required especially in the azimuth plane, including metering, remote monitoring. As standard low frequency monopole antenna, its radiation property improves with mounting on metal plate. Connector can be customized on request. II. Specification Table ISM 915MHz 900 915 925 Free Space Ground (30x30cm) Ground (50x50cm) -2.3 -1.7 -1.27 -1.1 -0.3 0.2 3.9 4.6 4.9 Free Space Ground (30x30cm) Ground (50x50cm) Free Space Ground (30x30cm) Ground (50x50cm) -7.2 -6.8 -6.4 -6.0 -5.2 -4.6 -3.1 -2.2 -1.7 19% 21% 22% 25% 30% 35% 49% 60% 68% Frequency (MHz) Peak Gain (dBi) Average Gain (dBi) Efficiency Impedance 50Ω Polarization Linear Radiation Pattern Omni Input Power 50 W MECHANICAL Dimensions 620mm Base Diameter 25mm Whip Diameter 19mm at widest Whip Material Coated Brass Connector N Male Straight ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-12-8-027/C/JC/PK Page 2 of 13 III. Antenna Characteristics III.1. Return Loss III.2. Antenna Efficiency SPE-12-8-027/C/JC/PK Page 3 of 13 III.3. Peak Gain SPE-12-8-027/C/JC/PK Page 4 of 13 III.4. Average Gain SPE-12-8-027/C/JC/PK Page 5 of 13 IV. Radiation Patterns IV.1. Antenna setup (Free Space) y z x Radiation Pattern XY plane SPE-12-8-027/C/JC/PK Page 6 of 13 XZ plane SPE-12-8-027/C/JC/PK Page 7 of 13 IV.2. Antenna setup (with 300x300mm ground plane) y z x Radiation Pattern XY plane SPE-12-8-027/C/JC/PK Page 8 of 13 XZ plane SPE-12-8-027/C/JC/PK Page 9 of 13 IV.3. Antenna setup (with 500x500mm ground plane) y z x Radiation Pattern XY plane SPE-12-8-027/C/JC/PK Page 10 of 13 XZ plane SPE-12-8-027/C/JC/PK Page 11 of 13 V. Drawing Name P/N Material Finish QTY Top Cap 000612C000002A Brass Black 1 Spring Antenna 000812C000002A Brass Black 1 Axis 000612C010002A Brass Ni Plated 1 NTYPE(M) Housing 000612C030002A POM Black 1 NTYP(M)Thread 000612C020002A Brass Ni Plated 1 SPE-12-8-027/C/JC/PK Page 12 of 13 VI. Packaging SPE-12-8-027/C/JC/PK Page 13 of 13
TI.16.5F11
1. 物料型号:TI.16.5F11 2. 器件简介:915MHz 5dBi 室外全向刚性鞭状天线,适合在902 MHz到928 MHz的ISM频段内使用。这款天线具有稳定的性能,全向辐射模式,适用于室外需要广泛覆盖的场景,例如计量、远程监控等。 3. 引脚分配:文档中没有提供引脚分配信息,因为这是一个天线,不是带有引脚的电子元件。 4. 参数特性: - 频率范围:902 MHz至928 MHz - 峰值增益(dBi):在不同条件下有所不同,例如自由空间下为-2.3 dBi至-1.27 dBi,地面上为3.9 dBi至4.9 dBi - 平均增益(dBi):自由空间下-7.2 dBi至-6.4 dBi,地面上-3.1 dBi至-1.7 dBi - 效率:自由空间下19%至22%,地面上25%至68% - 阻抗:50欧姆 - 极化:线性 - 辐射模式:全向 - 输入功率:50瓦 5. 功能详解:天线具有稳定的辐射特性,其辐射性能随着安装在金属板上而提高。连接器可根据要求定制。 6. 应用信息:适用于室外需要广泛覆盖的场景,如计量、远程监控等。 7. 封装信息:尺寸为620mm长,基座直径25mm,鞭状部分最宽处直径19mm,材料为涂层黄铜。连接器为N型公头直插,符合RoHS标准。
TI.16.5F11 价格&库存
很抱歉,暂时无法提供与“TI.16.5F11”相匹配的价格&库存,您可以联系我们找货
TI.16.5F11
    TI.16.5F11
      • 100+108.29911
      库存:4
