FW.91.TNC.M
FW.91.TNC.M
    TAOGLASLIMITED
    FW.91.TNC.M
FW.91.TNC.M 数据手册
SPECIFICATION Part No. : FW.91.TNC.M Product Name : Penta-band cellular 2G/3G GSM/CDMA/UMTS Flexible Whip Monopole Antenna 850/900/1800/1900/2100 MHz Feature : IP67 Robust Inner Steel Core TNC Male Connector RoHS Compliant SPE-11-8-143/D/SS Page 1 of 13 1. Specification CELLULAR Frequency (MHz) 824~896 880~960 1710~1880 1850~1990 1710~2170 Free Space With Ground plane(30x30cm) -0.7 -0.9 1.7 2.5 2.2 2.5 3.0 4.5 4.5 3.5 L - Bracket 3.0 3.0 3.5 4.5 2.5 Free Space With Ground plane(30x30cm) -5.7 -5.3 -2.3 -1.7 -3.9 -2.2 -2.6 -2.3 -1.7 -2.2 L - Bracket -3.0 -2.6 -2.3 -1.7 -3.0 Free Space With Ground plane(30x30cm) 27% 30% 59% 68% 40% 60% 55% 59% 68% 60% L - Bracket 50% 55% 59% 68% 50% Peak Gain (dBi) Average Gain (dBi) Efficiency Impedance 50Ω Polarization Linear Radiation Pattern Omni Input Power 50 W MECHANICAL Dimensions Height 255 ± 5 mm Base Diameter 16.05 ± 0.2 mm Whip Diameter 4 ± 0.2 mm Casing ABS Connector TNC Male ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-11-8-143/D/SS Page 2 of 13 2. Antenna Characteristics 2.1. Return Loss 0 -5 -10 -15 -20 stand alone with gnd plane((30x30 cm) -25 L bracket -30 500 1000 1500 MHz) 2000 2500 ( SPE-11-8-143/D/SS Page 3 of 13 2.2. Antenna Efficiency Efficiency 100 90 80 70 60 50 40 30 20 Free Space L-Bracket 10 Ground plane (30x30cm)) 0 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 Freq(MHz) 2.3. Peak Gain Peak Gain 6.0 5.0 4.0 3.0 2.0 1.0 0.0 -1.0 Free space L-Bracket -2.0 Ground plane (30x30cm) -3.0 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 Freq(MHz) SPE-11-8-143/D/SS Page 4 of 13 3. Antenna Radiation Pattern 3.1. Antenna Stand Alone y z x SPE-11-8-143/D/SS Page 5 of 13 XY-plane 0 0 -5 315 -10 824MHz 960MHz 1700MHz 1800MHz 1880MHz 1980MHz 45 -15 -20 -25 -30 -35 270 -40 90 225 135 180 XZ-plane 0 5 0 315 824MHz 960MHz 1700MHz 1800MHz 1880MHz 1980MHz 45 -5 -10 -15 -20 -25 270 90 225 135 180 SPE-11-8-143/D/SS Page 6 of 13 3.2. Antenna with Ground plane (30X30cm) y z x SPE-11-8-143/D/SS Page 7 of 13 XY-plane 0 5 0 -5 315 824MHz 960MHz 1700MHz 1800MHz 1880MHz 1980MHz 45 -10 -15 -20 -25 -30 -35 270 -40 90 225 135 180 XZ-plane 0 5 0 315 825MHz 960MHz 1700MHz 1800MHz 1880MHz 1980MHz 45 -5 -10 -15 -20 -25 270 90 225 135 180 SPE-11-8-143/D/SS Page 8 of 13 3.3. Antenna with L-Bracket y x z SPE-11-8-143/D/SS Page 9 of 13 XY-plane 0 315 270 5 0 -5 -10 -15 -20 -25 -30 -35 -40 824MHz 960MHz 1700MHz 1800MHz 1880MHz 1980MHz 45 90 225 135 180 XZ-plane 0 5 0 315 825MHz 960MHz 1700MHz 1800MHz 1880MHz 1980MHz 45 -5 -10 -15 -20 -25 270 90 225 135 180 SPE-11-8-143/D/SS Page 10 of 13 4. Antenna Drawing Unit : mm Material Name Finish QTY 1 Housing ABS Black 1 2 Internal Steel Cable Steel+PE Jacket Black 1 3 CAP ABS Black 1 4 Outer Body TNC (M) Brass Black 1 SPE-11-8-143/D/SS Page 11 of 13 5. Packaging SPE-11-8-143/D/SS Page 12 of 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-143/D/SS Page 13 of 13
FW.91.TNC.M 价格&库存
很抱歉,暂时无法提供与“FW.91.TNC.M”相匹配的价格&库存,您可以联系我们找货
