SPECIFICATION
Part No.
TG.22.0112.HT
Product Name
Penta-Band Cellular Connector Mount Monopole Helical
GSM-DCS-PCS-UMTS-CDMA-GPRS-EDGE-HSPA
800MHz ~2200 MHz
Features
0dBi Gain
SMA(M) Fixed Right Angle plug, 50 Ohms
Dupont® Hytrel® High Temperature Resistant TPEE
Housing (up to 150°C)
ROHS Compliant
SPE-13-8-064/A/SS
Page 1 of 7
1. Introduction
The TG.22.0112.HT Penta-band GSM-DCS-PCS-UMTS-CDMA-GPRS-EDGE-HSPA 800MHz
to 2,170 MHz monopole helical antenna is a quality robust antenna with high gain in small
form factor. Antenna housing applies highly resistant Dupont® Hytrel® TPEE material
which is durable in high temperature application environments up to 150°C. This material
is often applied in automotive or industrial applications, where the antenna is placed near
the engine or heat generating components.
Connection is made via fixed right angle SMA(M) connector with a hardened TPEE casing,
this antenna is the ideal GSM antenna for telematics devices.
2. Antenna Performance
2.1 Electrical Specifications
No
Parameter
Specification
1
Frequency Range
800MHz to 2200MHz
2
Bands
3
VSWR
≤ 2.3
4
Power Handling
20W
5
Polarization
Linear
6
Impedance
50 Ohms
7
Connector
SMA(M)RA
2.2 Environmental & Mechanical Characteristics
No
Parameter
Specification
1
Temperature
-40°c to +150°c
2
Radome Colour
Black
3
Radome Material
4
Weight
6g
SPE-13-8-064/A/SS
Page 2 of 7
3. Performance Measurements
3.1 Return Loss (dB)
SPE-13-8-064/A/SS
Page 3 of 7
3.2 Efficiency (dB)
TG.22.0112
Frequency
Efficiency
824
6.27%
836
8.09%
849
10.76%
869
14.60%
880
16.19%
894
16.45%
900
17.70%
915
18.58%
925
18.62%
940
18.21%
960
16.00%
1575
21.75%
1710
29.50%
1750
29.13%
1785
29.94%
1805
30.52%
1840
31.18%
1850
32.10%
1880
32.01%
1910
33.35%
1920
34.33%
1930
34.01%
1950
35.90%
1960
35.87%
1980
36.71%
1990
37.07%
2110
41.34%
2140
43.44%
2170
42.88%
SPE-13-8-064/A/SS
Page 4 of 7
3.3 Radiation Pattern Data
A. Radiation Pattern, Azimuth Plane (XY)
SPE-13-8-064/A/SS
Page 5 of 7
B. Radiation Pattern, Aligned at the Connector
SPE-13-8-064/A/SS
Page 6 of 7
4. Mechanical Drawing
SPE-13-8-064/A/SS
Page 7 of 7
很抱歉,暂时无法提供与“TG.22.0112.HT”相匹配的价格&库存,您可以联系我们找货
