Part No:
GSA.8841.A.105111
Description:
Wideband 4G LTE I-Bar Antenna 698MHZ to 6000MHz
Features:
5G/4G/ Wi-Fi Adhesive Mount Antenna
Dimension 176mm * 59mm *11.6mm
698MHz to 6000MHz
With 1M TGC-200 and SMA(M) Connector
RoHS & Reach Compliant
SPE-14-8-062-D
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
7
4.
2D Radiation Patterns
14
5.
Mechanical Drawing
21
6.
Packaging
22
7.
Application Note
23
Changelog
30
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-062-D
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The GSA.8841 LTE Wideband I-Bar Antenna is an external adhesive mount solution on glass and plastic for
automotive and telematics applications. It covers not only LTE, but all Cellular, ISM and Wi-Fi working
frequencies in the 700-6000 MHz spectrum. It has the highest wide-band efficiency in its range of any
antenna in its category today.
Introduction
The GSA.8841 has been primarily designed for use with 4G LTE modules and devices that require the highest
possible efficiency and peak gain to deliver best in class throughput on all major cellular 4G bands worldwide
for telematics applications.
Introduction
High speed HD video
Real-time streaming
High capacity MIMO networks on public transportation
Introduction
It comes with 1 meter of coaxial cable and SMA (M) connector, in a low profile compact format for mounting
via high quality first tier automotive approved 3M adhesive foam. Stable radiation is observed on both glass
and plastic.
The GSA.8841 is backward compatible with 3G and 2G cellular applications such as HSPA, as well as covering
WI-FI bands, and even has GPS included for E911 applications.
It is an ideal solution for any device requiring high, reliable performance. It will meet nearly all carrier
certification requirements from an efficiency standpoint. The antenna also makes an excellent reference
antenna for test purposes. It has been designed as an omni-directional antenna and the radiation patterns
show this and are stable across all bands.
SPE-14-8-062-D
www.taoglas.com
3
2.
Specifications
Electrical
3.
Antenna
Characteristics2.
LTE/GSM/
LTE/GSM/
CDMA
700/800/
850/900
Standard
Frequency
(MHz)
3.
698~960
GNSS
1565
~1612
HSPA/CD
MA
1700/180
0/ 1900
UMTS/
HSPA
2100
1710
~1990
1920
~2170
Specifications
LTE
2300
2305
~2360
Wi-Fi
2400
LTE
2600
LTE
3500
2400 ~2500 2500 ~2700 3400 ~3600
Wi-Fi
5800
4800~6000
Efficiency (%)
In free
space
4.
0.3M
1M
2M
71.88
68.64
63.75
62.03
56.57
51.59
67.62
61.77
55.33
67.81
62.39
56.02
68.79
62.74
54.64
71.08
64.83
55.89
48.73
43.43
36.76
59.34 Radiation
45.98
48.75
49.59
3M
Antenna
Patterns3.
Antenna47.06
47.47
30.75
36.10
69.68
63.55
55.35
47.67
36.57
64.27
58.62
51.05
43.97
33.73
36.30
73.11
66.67
57.49
48.82
37.33
69.10
63.02
54.33
46.14
35.28
22.34
49.39
44.02
37.25
31.16
22.63
55.18
49.18
41.44
34.81
24.97
-1.71
-2.07
-1.63
-2.03
-1.49
-1.89
-3.22
-3.72
-2.54
-2.63
-2.53
-4.45
5M
0.3M
1M
On 2mm
2M
ABS Base 3M
5M
0.3M
1M
On Glass
2M
Base
3M
5M
50.54
74.99
71.62
66.53
61.93
52.78
74.73
71.86
67.23
64.50
55.06
36.53
64.23
58.58
53.42
47.61
37.82
73.00
66.58
60.72
54.12
42.99
37.87
70.69
64.58
57.85
50.97
39.60
80.37
73.41
65.79
57.94
45.03
39.04
70.33
64.68
58.07
51.41
40.45
77.79
71.51
64.21
56.81
44.67
0.3M
1M
-1.46
-1.66
-2.08
-2.48
-1.72
-2.12
Characteristics2.
3.
Specifications
Antenna Characteristics2.
Specifications
Average Gain(dBi)
In free Antenna
3.
-1.98 Characteristics
-2.88
-2.59
2M
space
3M
-2.29
-3.38
-3.14
-3.07
-3.28
-3.24
-5.22
5M
-2.99
-4.38
-4.23
-4.11
-4.43
-4.41
-6.62
0.3M
-1.29
-1.93
-1.52
-1.55
-1.57
-1.37
-3.13
-1.49 Radiation
-2.33
-1.92
-1.91
1M
4.
Antenna
Patterns3.
Antenna-1.97
On 2mm
ABS Base
2M
-1.81
-2.12
3M
Characteristics
On the
Glass
Base
4.
-3.63
-2.39
-2.38
-2.57
-2.41
-4.37
-3.23
-2.94
-2.91
-3.22
-3.12
-5.13
5M
-2.82
-4.23
-4.04
-3.95
-4.37
-4.28
-6.53
0.3M
-1.33
-1.37
-0.96
-1.11
-1.92
-1.62
-2.62
1M
-1.50
-1.77
-1.35
-1.47
-2.32
-2.02
-3.12
-1.80
-2.17
-1.83
-1.94
-2.92
-2.66
-3.87
-3.57
-3.37
-4.62
-4.72
-4.53
-6.07
2M
Antenna
Radiation
Patterns
-2.02
-2.67
-2.38
-2.47
3M
5M
4.
-1.77
-2.73
-2.72
-3.67
-3.47
-3.51
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-14-8-062-D
Specifications
www.taoglas.com
4
Peak Gain(dBi)
1.56
1565
~1612
1.38
LTE/GSM/
HSPA/CD
MA
1700/180
0/ 1900
1710
~1990
3.79
1920
~2170
3.06
1.36
1.04
0.73
0.03
1.65
1.45
1.13
0.81
0.11
1.52
1.32
0.99
0.68
-0.02
0.98
0.58
0.08
-0.92
1.74
1.34
0.94
0.44
-0.56
3.20
2.80
2.40
1.90
0.90
3.40
2.92
2.37
1.28
3.85
3.46
2.99
2.44
1.34
4.76
4.37
3.89
3.34
2.25
2.69
2.23
1.70
0.66
3.13
2.76
2.30
1.77
0.73
4.12
3.76
3.29
2.76
1.72
Standard
LTE/GSM/
CDMA
700/800/
850/900
Frequency (MHz)
698~960
In free
space
On
2mm
ABS
Base
On
Glass
Base
0.3M
1M
2M
3M
5M
0.3M
1M
2M
3M
5M
0.3M
1M
2M
3M
5M
GNSS
UMTS/
HSPA
2100
LTE
2300
Wi-Fi
2400
LTE
2600
LTE
3500
Wi-Fi
5800
2305
~2360
2400
~2500
4.25
2500
~2700
4.70
3400
~3600
4800~6
000
2.56
3.85
3.25
2.60
1.45
5.00
4.60
4.00
3.35
2.20
5.75
5.35
4.75
4.10
2.95
4.30
3.66
2.95
1.79
5.27
4.87
4.23
3.52
2.35
5.35
4.95
4.31
3.60
2.44
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
Input Power
5W
2.06
1.33
0.56
-0.84
2.08
1.58
0.84
0.08
-1.32
4.14
3.64
2.89
2.14
0.69
Mechanical
Casing
Coaxial Cable
Cable Length
Connector
Adhesive
Weight
ABS
TGC-200 Low Loss Cable
1 Meter Standard, Fully Customizable
SMA Male Standard, Fully Customizable
3M9448+CR4305 Double Sided Adhesive
127g
Environmental
Operation Temperature Range
-40°C to 85°C
Storage Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-14-8-062-D
www.taoglas.com
5
LTE BANDS
Band Number
LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LET only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
Covered
*Covered bands represent an efficiency greater than 20%
SPE-14-8-062-D
www.taoglas.com
6
3.
4.
3.1
Testing setup
Characteristics
4.
4.
Characteristics
4.
Characteristics
In free space
On 2mm ABS Base
4.
4.
4.
4.
On Glass Base
Characteristics
4.
SPE-14-8-062-D
www.taoglas.com
7
3.2
Return loss
Figure2. Return loss of GSA.8841 with 1 meter cable length in free space
Figure3. Return loss of GSA.8841 with 1 meter cable length on the 2mm ABS base
SPE-14-8-062-D
www.taoglas.com
8
Figure4. Return loss of GSA.8841 with 1 meter cable length on the glass base
3.3
Efficiency
Figure5. Efficiency of GSA.8841 with 1 meter cable length in free space
SPE-14-8-062-D
www.taoglas.com
9
Figure6. Efficiency of GSA.8841 with 1 meter cable length on the 2mm ABS base
Figure7. Efficiency of GSA.8841 with 1 meter cable length on the glass base
SPE-14-8-062-D
www.taoglas.com
10
3.4
Peak gain
Figure8. Peak gain of GSA.8841 with 1 meter cable length in free space
Figure9. Peak gain of GSA.8841 with 1 meter cable length on the 2mm ABS base
SPE-14-8-062-D
www.taoglas.com
11
Figure10. Peak gain of GSA.8841 with 1 meter cable length on the glass base
3.5
Average gain
Figure11. Average gain of GSA.8841 with 1 meter cable length in free space
SPE-14-8-062-D
www.taoglas.com
12
Figure12. Average gain of GSA.8841 with 1 meter cable length on the 2mm ABS base
Figure13. Average gain of GSA.8841 with 1 meter cable length on the glass base
SPE-14-8-062-D
www.taoglas.com
13
4.
4.
4.
Y
4.
Y
X
X
Z
4.
4.
Z
In free space
On 2mm ABS base
4.
4.
Y
X
4.
Z
3) On the glass base
Figure.14 The measurement setup; a) In free space, b) On the 2mm ABS base, c) On the glass base
SPE-14-8-062-D
www.taoglas.com
14
4.1
Antenna with 1 meter cable length in free space
XY Plane
SPE-14-8-062-D
XZ Plane
YZ Plane
www.taoglas.com
15
XY Plane
SPE-14-8-062-D
XZ Plane
YZ Plane
www.taoglas.com
16
4.2
Antenna with 1 meter cable length on 2mm ABS
XY Plane
SPE-14-8-062-D
XZ Plane
YZ Plane
www.taoglas.com
17
XY Plane
SPE-14-8-062-D
XZ Plane
YZ Plane
www.taoglas.com
18
4.3
Antenna with 1 meter cable length on Glass Base
XY Plane
SPE-14-8-062-D
XZ Plane
YZ Plane
www.taoglas.com
19
XY Plane
SPE-14-8-062-D
XZ Plane
YZ Plane
www.taoglas.com
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-062-D
Mechanical Drawing
www.taoglas.com
21
8.
6.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-062-D
Mechanical Drawing
www.taoglas.com
22
8.
7.
Packaging Note
Application
The GSA.8841 antenna measurement with difference cable length and difference environments, the
performance is shown as below,
7.1
6.
Return Loss – Free Space
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-062-D
Mechanical Drawing
www.taoglas.com
23
7.2
Efficiency – Free Space
7.3
Average gain – Free Space
SPE-14-8-062-D
www.taoglas.com
24
7.4
Peak gain – Free space
7.5
Return loss – 2mm ABS
SPE-14-8-062-D
www.taoglas.com
25
7.6
Efficiency – 2mm ABS
7.7
Average gain – 2mm ABS
SPE-14-8-062-D
www.taoglas.com
26
7.8
Peak gain – 2mm ABS
7.9
Return loss – Glass
SPE-14-8-062-D
www.taoglas.com
27
7.10
Efficiency – Glass
7.11
Average gain – Glass
SPE-14-8-062-D
www.taoglas.com
28
7.12
Peak gain – Glass
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
SPE-14-8-062-D
www.taoglas.com
29
Changelog for the datasheet
SPE-14-8-062 – GSA.8841.A.105111
Revision: D (Current Version)
Date:
Changes:
Changes Made by:
2022-06-08
Updated Image and Drawing
Cesar Sousa
Previous Revisions
Revision: C
Date:
Changes:
Changes Made by:
2021-10-26
Removed IP Rating
Gary West
Revision: B
Date:
Changes:
Changes Made by:
2017-04-04
Added LTE Band Table
Peter Monahan
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-14-8-062-D
2014-06-20
David Connolly
www.taoglas.com
30
www.taoglas.com
SPE-14-8-062-D
www.taoglas.com
31
很抱歉,暂时无法提供与“GSA.8841.A.105111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+405.549771+52.46869
- 国内价格
- 3+210.15371
- 11+206.23623
- 21+202.31874
- 国内价格 香港价格
- 1+324.915101+42.03644
- 11+240.3099011+31.09050
- 21+235.7650421+30.50250
