GSA.8827R.A.101111
GSA.8827R.A.101111
    TAOGLASLIMITED
    GSA.8827R.A.101111
GSA.8827R.A.101111 数据手册
Specification Part No. : GSA.8827R.A.101111 Product Name : Phoenix 4G/3G/2G Ultra-wideband I–bar Antenna for First-Tier Automotive Application Feature : LTE / GSM / CDMA /DCS /PCS / WCDMA / UMTS / HSDPA / GPRS / EDGE / GPS / Wi-Fi 698MHz to 960MHz, 1575.42MHz, 1710MHz to 2700Mhz 1M RG.174 cable with SMA(M) connector AntD© Antenna Diagnostic Compatible Low profile for easy installation Fully customizable cable length and connector 105mm*30mm*7.7mm RoHS compliant SPE-14-8-059/E/WY Page 1 of 11 1. Introduction The GSA.8827R Phoenix Ultra-Wideband I-Bar antenna is a robust high efficiency cellular antenna for use with all 4G/3G/2G cellular modules worldwide. Its slim-line design allows for covert and convenient installation in automotive vehicles, its omni-directional gain across all bands ensures constant reception and transmission. GSA.8827R is manufactured and tested in a TS16949 first tier automotive approved facility, and it has gone through full PPAP design, reliability and quality audits. The Phoenix finds its application particularly in first-tier automotive application, aftermarket and telematics. With its unique ultra-wide band dipole design, the Phoenix has exceptional industry performance characteristics considering its very low profile at 7.7mm and has a compact size of only 105mm*30mm. This antenna is designed to be mounted on glass or plastic (not on metal). It comes with strong 3M double-sided adhesive for a permanent and secure fix to your vehicle interior. The antenna is UV Resistant. Cable lengths and connectors are fully customizable. GSA.8827R features Taoglas’ AntD© antenna diagnostic technology. AntD© allows connected radio products using the latest cellular modules and recommended circuits from Telit and uBlox to perform diagnostics on the antenna. This includes detection that the proper antenna is connected and that the connection isn’t shorted or broken. Contact Taoglas engineering for examples on how to implement AntD© antenna diagnostics in your product. SPE-14-8-059/E/WY Page 2 of 11 2. Specification ELECTRICAL Frequency (MHz) 698~803 824~894 880~960 1575.42 1710 ~1880 1850 ~1990 1920 ~2170 2305 ~2360 2490 ~2690 3400 ~3600 Free Space Peak Gain (dBi) Cable length 1 (meter) 3.42 2.38 1.47 1.28 2.16 1.86 1.86 1.74 -2.56 -4.36 55.50 37.03 Free Space Average Gain (dBi) Cable length 1 (meter) -4.34 -3.72 -3.71 -1.75 -2.47 -2.43 Free Space Efficiency (%) Cable length 1 (meter) 37.38 42.47 42.54 66.83 56.71 57.14 Impedance 50Ω Polarization Linear Radiation Pattern Omni Input Power 50 W Integrate Resistor Shunt 15K Ohm to Ground MECHANICAL Casing UV Resistant PC/ABS Connector SMA Male (customizable) ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-14-8-059/E/WY Page 3 of 11 LTE BANDS Band Number LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 (LTE only) 18 UL: 815 to 830 DL: 860 to 875 (LET only) 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 (LTE only) 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 (LTE only) 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 (LTE only) 28 UL: 703 to 748 DL: 758 to 803 (LTE only) 29 UL: - DL: 717 to 728 (LTE only) 30 UL: 2305 to 2315 DL: 2350 to 2360 (LTE only) 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 (LTE only) 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓   *Covered bands represent an efficiency greater than 20% SPE-14-8-059/E/WY Page 4 of 11 3. Antenna Characteristics 3.1. Return Loss (in free space) 3.2. Peak Gain (in free space) SPE-14-8-059/E/WY Page 5 of 11 3.3. Average Gain (in free space) 3.4.1 Efficiency (in free space) SPE-14-8-059/E/WY Page 6 of 11 4. Antenna Radiation Patterns 4.1. Antenna setup (Free Space with 1 Meter Cable Length) Y X Z SPE-14-8-059/E/WY Page 7 of 11 4.2. Radiation patterns XY Plane X X Y Y X X Y Y SPE-14-8-059/E/WY Page 8 of 11 XZ Plane Z Z X Z X Z X X SPE-14-8-059/E/WY Page 9 of 11 5. Drawing SPE-14-8-059/E/WY Page 10 of 11 6. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-14-8-059/E/WY Page 11 of 11
GSA.8827R.A.101111 价格&库存
很抱歉,暂时无法提供与“GSA.8827R.A.101111”相匹配的价格&库存,您可以联系我们找货
