G30.B.108111.WM
G30.B.108111.WM
    TAOGLASLIMITED
    G30.B.108111.WM
G30.B.108111.WM 数据手册
SPECIFICATION Part No. : G30.B.108111.wm Product Name : Olympian Direct Mount Ultra Wide-Band LTE / Cellular / CDMA Antenna For 4G/3G/2G Applications Features : LTE / GSM / CDMA / DCS / PCS / WCDMA / UMTS / HSDPA / GPRS / EDGE / IMT 698 to 960MHz and 1710 to 2700MHz Heavy duty screw mount UV and vandal resistant ABS housing and thread. L-Shaped bracket IP67 compliant Standard is 1M RG-316 SMA(M) Cables and Connectors Customizable RoHS Compliant SPE-14-8-102/E/AW Page 1 of 22 1. Introduction This G30.wm, wall mounted G30 Olympian antenna is a high performance screw mount wide-band cellular antenna with stainless steel L-bracket to allow it to be mounted on a wall or panel. Omni-directional high gain and high efficiency across all bands ensures constant reception and transmission. This is vital for today's high data bandwidth applications in video and mobile broadband. Durable UV resistant ABS housing is resistant to vandalism and direct attack. At only 48mm in height it is small enough to mount unobtrusively in most locations. This antenna is mounted on metal and plastic structures and is locked from the inside of the structure by a nut. Adhesive foam at the base provides a watertight seal to the mounting structure. High quality waterproof and corrosion resistant Teflon jacket RG316 is used for the cable. Two of these G30 separated at distance from each other are ideal for the latest LTE MIMO spatial diversity applications. Customized cable length and connectors are available. Taoglas recommend a minimum cable length of 70mm when used on a ground plane to achieve an efficiency of greater than 40% in the 900MHz band and greater than 60% in the 1800MHz band. For longer cable lengths and if 700MHz band is required, it is necessary to use the MA740 Pantheon for 4G/3G/2G or the MA741 4G/3G/2G MIMO Pantheon. SPE-14-8-102/E/AW Page 2 of 22 2. Specification ELECTRICAL STANDARD 4G/3G/2G Operation Frequency(MHz) 698~960MHz Peak Gain(dB) 1710~2170MHz 2500~2800MHz On 30*30cm metal with 1 meter cable length 1.2 3.2 2.5 On L-shaped bracket with 1 meter cable length 0.77 2.32 -0.01 On L-shaped bracket with 3 meter cable length -1.08 -1.23 -2.71 On L-shaped bracket with 5 meter cable length -3.04 -4.06 -6.82 Average Gain(dB) On 30*30cm metal with 1 meter cable length -4.5 -2.5 -4.5 On L-shaped bracket with 1 meter cable length -3.29 -2.95 -4.58 On L-shaped bracket with 3 meter cable length -5.26 -5.88 -8.30 On L-shaped bracket with 5 meter cable length -7.35 -8.17 -11.16 Efficiency (%) On 30*30cm metal with 1 meter cable length 40 55 40 On L-shaped bracket with 1 meter cable length 47.40 51.32 34.96 On L-shaped bracket with 3 meter cable length 31.27 26.04 14.91 On L-shaped bracket with 5 meter cable length 18.82 15.35 7.67 VSWR
G30.B.108111.WM 价格&库存
很抱歉,暂时无法提供与“G30.B.108111.WM”相匹配的价格&库存,您可以联系我们找货
G30.B.108111.WM
  • 3+302.52897
  • 8+296.93084
  • 15+291.34479
  • 30+285.74666
  • 50+280.14853
库存:84
