SPECIFICATION
Part No.
MA220.LB.001
Product Name
Optimus MA220 2in1 GPS-GLONASS / LTE
External Adhesive Antenna for Glass and Plastic
Mount
Features
GPS-GLONASS - High gain LNA up to 32dB
4G LTE band – 698 MHz to 2700MHz
Covers legacy worldwide 2G and 3G bands
LTE/GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/HSPA
IP67
Height 12mm Diameter 62.8mm
RoHS Compliant
SPE-14-8-016/C/WY
Page 1 of 39
MA220.LB.A.L301111.B301111
1. Introduction
The Optimus MA220 is a combination high performance GPS-GLONASS and
2G/3G/4G LTE (plus GSM /CDMA/PCS/DCS/UMTS/GPRS/EDGE/HSPA) antenna to
simplify Automotive Telematic and Fleet management systems worldwide. Its high
quality low profile covert housing can be attached onto the glass or even out of
sight under the dashboard. This combination of a high gain GPS/Glonass antenna
and a LTE antenna is ideal for those applications that require durability, small size
and covert installation, and reliable reception and transmission crossing through
different mobile networks.
The LTE cellular antenna function covers all main LTE and 2G/3G cellular bands
worldwide. It has been designed to work equally well when mounted on glass or on
plastic. It is not suitable for mounting on metal.
The GPS/Glonass function means increased accuracy and reliability of location. A
front-end SAW protects the LNA from burnout by nearby out of band cellular
transmissions and also significantly reduces any compression and consequent
reduction of sensitivity.
The standard version has 3 metres RG174 cable and SMA(M) connector on both
GPS/Glonass and LTE. For even higher gain and efficiency we recommend if you can
to use shorter cable lengths, as shown in the charts below. The cable lengths and
connector types are completely customizable according to customer request,
subject to a minimum order quantity.
The slim housing is fully IP67 waterproof. A separate automotive approved 3M
adhesive pad is provided, allowing the antenna to be mounted correctly facing
through glass, or directly onto a plastic surface like the dashboard of a vehicle.
Note if US LTE network certification is required contact Taoglas for advice on correct
antenna choice.
SPE-14-8-016/C/WY
Page 2 of 39
Features
GPS-GLONASS
• High LNA Gain up to 32 dB
• Antenna Gain 30 ± 2 dB
• Low Noise 1.5 dB max
LTE
• Advanced 4G LTE antenna with 2G/3G application bands included
LTE/GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/ HSPA
Other
• Ultrasonically Welded - Water Resistant IP 67
• UV Resistant
• Quality textured covert design. Low profile
• Comes with automotive approved high grade 3M double sided tape for quick and
easy mounting
• Customizable cables and connectors
SPE-14-8-016/C/WY
Page 3 of 39
2. Specification
2G/3G Antenna
Frequency (MHz)
LTE
LTE Band
GSM850
GSM900
DCS
PCS
698~798
791~862
824~894
880~960
1710~1880
1850~1990
WCDMA I /
UMTS
WiFi
1920~2170 2400~2500
LTE
2570~2690
Free Space
Peak Gain (dBi) *
-1.54
-0.53
-0.53
-1.07
-0.10
0.72
0.89
-2.40
-1.59
Average Gain (dBi) *
-7.21
-6.02
-5.71
-8.20
-6.46
-6.10
-5.99
-7.39
-7.40
Efficiency (%)*
19.12
25.29
27.38
16.20
22.62
24.62
25.22
18.27
18.21
On 2mm Thickness ABS
Peak Gain (dBi) *
-1.13
-0.05
-0.05
-1.91
2.21
1.68
1.63
-3.36
-0.63
-6.72
-4.78
-5.01
-7.96
-6.01
-4.99
-5.73
-9.07
-7.64
Efficiency (%)*
21.66
33.32
31.52
16.59
25.37
31.75
28.06
12.36
17.21
On Glass
Peak Gain (dBi) *
-0.71
-0.35
-0.35
-2.03
1.76
1.71
1.48
-2.94
-1.31
-6.44
-4.99
-5.36
-8.37
-5.76
-5.29
-6.18
-9.21
-8.04
Efficiency (%)*
23.01
31.79
29.03
14.93
26.78
29.61
25.07
11.97
15.70
Return loss (dB) *
< -5
Polarization
Linear
Impedance
50Ω
Cable
3m RG174 standard, fully customizable
Connector
SMA(M), standard, fully customizable
Maximum Input
Power
5W
SPE-14-8-016/C/WY
Page 4 of 39
Center Frequency
Gain
GPS-GLONASS
GPS:1575.42±3 MHz
GLONASS:1602±0.5 MHz
3 ±1 dBic typ.
VSWR
1.92:1 Max
Impedance
50Ω
Antenna Patch Size
25x25x4mm
Cable
Connector
Center Frequency fc
Impedance
VSWR
Return Loss
LNA Electrical Properties
GPS:1575.42±3 MHz
50 Ω Nominal
< 1.92:1
10 dB Min.
Gain
31 dB Min. @3.3V
DC Power Input
3.3V
Noise Figure @3.3V
1.5dB
Power Consumption
12mA
MECHANICAL
Antenna Dimensions
62.8mm x 68mm x 12mm
Casing
ABS
Waterproof
IP67
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 90°C
Humidity
Non-condensing 65°C 95% RH
*note: includes 3 metre RG174 cable loss
SPE-14-8-016/C/WY
Page 5 of 39
2.1 LTE Bands with 3M Cable
LTE BANDS
LTE/LTE- Advanced /WCDMA/HSPA.HSPA+
Band Number
Uplink
Downlink
Covered
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LET only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
SPE-14-8-016/C/WY
Page 6 of 39
2.2 LTE Bands with 300mm Cable
LTE BANDS
Band Number
Uplink
Downlink
Covered
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
11
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
18
UL: 815 to 830
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
24
UL:1625.5 to 1660.5
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
28
UL: 703 to 748
29
UL: -
30
UL: 2305 to 2315
31
UL: 452.5 to 457.5
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
SPE-14-8-016/C/WY
Page 7 of 39
3. LTE Antenna Characteristics
3.1
Return Loss
Free Space with RG174 Coaxial Cable
On 2mm thickness ABS Base with RG174 Coaxial Cable
SPE-14-8-016/C/WY
Page 8 of 39
On Glass Base with RG174 Coaxial Cable
SPE-14-8-016/C/WY
Page 9 of 39
3.2
Efficiency
SPE-14-8-016/C/WY
Page 10 of 39
SPE-14-8-016/C/WY
Page 11 of 39
3.3
Peak Gain
SPE-14-8-016/C/WY
Page 12 of 39
SPE-14-8-016/C/WY
Page 13 of 39
3.4
Average Gain
SPE-14-8-016/C/WY
Page 14 of 39
SPE-14-8-016/C/WY
Page 15 of 39
3.5
Free Space Radiation Pattern-3meter length cable
Y
Z
XY-Plane
X
X
Y
SPE-14-8-016/C/WY
Page 16 of 39
X
Y
X
Y
SPE-14-8-016/C/WY
Page 17 of 39
XZ-Plane
Z
X
SPE-14-8-016/C/WY
Page 18 of 39
Z
X
Z
X
SPE-14-8-016/C/WY
Page 19 of 39
YZ-Plane
Z
Y
Z
Y
SPE-14-8-016/C/WY
Page 20 of 39
Z
Y
SPE-14-8-016/C/WY
Page 21 of 39
3.6 On 2mm thickness ABS Base Radiation Pattern3meter length cable
Y
Z
X
XY-Plane
X
Y
SPE-14-8-016/C/WY
Page 22 of 39
X
Y
X
Y
SPE-14-8-016/C/WY
Page 23 of 39
XZ-Plane
Z
X
Z
X
SPE-14-8-016/C/WY
Page 24 of 39
Z
X
YZ-Plane
Z
Y
SPE-14-8-016/C/WY
Page 25 of 39
Z
Y
Z
Y
SPE-14-8-016/C/WY
Page 26 of 39
3.7
On Glass Base Radiation Pattern-3meter length cable
Y
Z
X
XY-Plane
X
Y
SPE-14-8-016/C/WY
Page 27 of 39
X
Y
X
Y
SPE-14-8-016/C/WY
Page 28 of 39
XZ-Plane
Z
X
Z
X
SPE-14-8-016/C/WY
Page 29 of 39
Z
X
YZ-Plane
Z
Y
SPE-14-8-016/C/WY
Page 30 of 39
Z
Y
Z
Y
SPE-14-8-016/C/WY
Page 31 of 39
4. GPS-GLONASS Antenna Characteristics
4.1. Antenna Characteristics
Return Loss
Smith Chart
SPE-14-8-016/C/WY
Page 32 of 39
Experiment Results
Antenna Radiation Pattern
270°
270°
H-Plane
E-Plane
SPE-14-8-016/C/WY
Page 33 of 39
1575.42 MHz
1602 MHz
SPE-14-8-016/C/WY
Page 34 of 39
4.2. LNA Characteristics
S11
S12
SPE-14-8-016/C/WY
Page 35 of 39
Noise Figure
SPE-14-8-016/C/WY
Page 36 of 39
5. Drawing
Top View
Side View
5. Packaging
SPE-14-8-016/C/WY
Page 37 of 39
Bottom View
Double sided 3M adhesive foam
SPE-14-8-016/C/WY
Page 38 of 39
6. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice. Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-016/C/WY
Page 39 of 39
很抱歉,暂时无法提供与“MA220.LB.001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+563.42520
- 200+224.81280
- 500+217.30680
- 1000+213.59160
- 国内价格 香港价格
- 1+333.666901+43.14395
