SPECIFICATION
Part No.
TLS.01.305111
Description
Shockwave 698-960/1575.42/1710-2700MHz
Permanent Mount External Antenna
3M CFD-200 SMA(M)
Features
Applicable for 2G/3G/4G cellular bands and GPS
Over 45% efficiency and 2.2 dBi gain
Mechanically robust for indoor/outdoor applications
Height: 79.45mm(3.13") ; Diameter : 42mm(1.65")
IP67 and IP69K Waterproof
Low loss CFD-200 cable, 3 meters
SMA(M) connector
RoHS compliant
DSP-15-8-SPE-15-8-063/B/SS
Page 1 of 22
1. Introduction
The Shockwave TLS.01.305111 is a permanent mount, waterproof, external
2G/3G/4G cellular and GPS antenna operating at 698-960/1575.42/1710-2700MHz
with an N type male connector. It has been designed to be used on a Ground Plane. It
can be used in mobile and fixed applications for 4G LTE wireless such as :
Public safety
HD Video Streaming
Utilities and Smart Cities
Fleet Management
Agricultural
Industrial
This antenna has superior performance over wide-bands compared to traditional whip
antennas. Up to 77% efficiency and with a minimum 2.2dBi peak gain over all cellular
bands result when mounted on a 30x30 cm ground plane. Stable radiation patterns
over low angles provides consistent gain in the horizontal plane, meaning that it is
especially suitable for cellular applications.
A unique indent tab on the base of the antenna allows a wrench to be used to solidly
lock the antenna on top of its mounting location while tightening up the nut beneath
the metal panel. Waterproof O-rings around the bottom base prevent water from
leaking under the antenna.
The TLS.01 antenna is IP67 waterproof and IP69K resistant against high pressure
water jets in commercial cleaning environments, which makes the antenna ideal for
2G/3G/4G applications either in indoor or in harsh outdoor environments.
Page 2 of 22
2. Specification
ELECTRICAL
Operation Band
WCDMA
LTE
GSM850
GSM900
Operation Frequency
698~80
824~89
880~96
(MHz)
6
6
GPS
DCS
PCS
I
LTE
1710~1
1850~1
1920~2
2300~2
880
990
170
690
1575.42
On 30 x 30 cm ground plane
Efficiency (%)
30cm Cable Length
94.23
95.11
80.92
67.29
77.21
80.27
78.56
67.79
1m Cable Length
89.16
90.83
77.28
62.80
70.42
73.21
72.37
61.82
2m Cable Length
83.21
83.50
70.48
55.97
62.76
64.59
63.50
53.51
3m Cable Length
77.02
77.31
65.31
51.04
55.77
57.19
56.04
46.50
5m Cable Length
66.52
65.80
55.17
42.46
44.05
44.84
43.61
35.10
Peak Gain (dBi)
30cm Cable Length
3.22
3.32
3.15
2.08
3.90
3.82
3.73
4.64
1m Cable Length
3.02
3.12
2.95
1.78
3.50
3.42
3.33
4.24
2m Cable Length
2.72
2.82
2.55
1.28
3.00
2.92
2.73
3.64
3m Cable Length
2.42
2.42
2.25
0.88
2.50
2.32
2.23
3.02
5m Cable Length
1.72
1.72
1.55
0.08
1.50
1.32
1.13
1.82
Average Gain (dBi)
30cm Cable Length
-0.26
-0.22
-0.93
-1.72
-1.13
-0.96
-1.05
-1.71
1m Cable Length
-0.50
-0.42
-1.13
-2.02
-1.53
-1.36
-1.41
-2.11
2m Cable Length
-0.80
-0.79
-1.53
-2.52
-2.03
-1.90
-1.98
-2.74
3m Cable Length
-1.14
-1.12
-1.86
-2.92
-2.54
-2.43
-2.52
-3.35
5m Cable Length
-1.77
-1.82
-2.59
-3.72
-3.57
-3.49
-3.61
-4.58
Return Loss (dB)*
很抱歉,暂时无法提供与“TLS.01.305111”相匹配的价格&库存,您可以联系我们找货
