OMB.242.08F21
OMB.242.08F21
    TAOGLASLIMITED
    OMB.242.08F21
OMB.242.08F21 数据手册
Wi-Fi Barracuda Part No: OMB.242.08F21 Description: 8dBi Omni-Directional Outdoor Antenna For Wi-Fi/Bluetooth/Zigbee 2.4-2.5dBi Features: Omni-Directional Radiation Pattern Collinear 8dBi Peak Gain Robust Design for all Weather Operation Length: 553mm Diameter: 24mm Weight: 380g IP65 Waterproof N Type Female Connector Wall/Pole Mount Bracket Included RoHS & Reach Compliant SPE-12-8-008-G 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 11 6. Installation 12 7. Packaging 14 Changelog 15 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-008-G www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. The Barracuda OMB.242.08F21 has been designed to provide long distance coverage at the 2.4-2.5GHz Wi-Fi band. The OMB.242 is a fiberglass robust outdoor antenna for use where an omnidirectional radiation pattern is required. The base is aluminum - meaning it is resistant to rusting. The fiberglass enclosure is UV coated making this antenna suitable for the harshest outdoor environments. The Barracuda is IP65 rated and can be mounted in areas where installation may be difficult. Introduction The peak gain of 8dBi ensures constant reception and transmission between the device and its network. The omnidirectional antenna collinear dipole design means it uniformly in the azimuth with a high gain, providing coverage over long distances, thus minimizing the number of cells or nodes needed in a network. Introduction Typical Applications Include: - Public Safety - Wireless Video Systems - Agriculture Introduction This antenna is provided with a wall/pole mount bracket, for more information please contact your regional Taoglas customer support team. SPE-12-8-008-G www.taoglas.com 3 2. Specifications 3. MIMO Antenna Characteristics2. Wi-FiSpecifications Frequency (MHz) 2400~2500 Efficiency (%) 3. Free Space Characteristics Antenna 97 Average Gain (dB) Free Space 4. Antenna Radiation Patterns3. Antenna Peak Gain (dBi) Free Space Characteristics2. 3. 3. -0.12 Specifications 8.0 Impedance 50 Ohms Polarization Vertical Antenna Characteristics2. Specifications Radiation Pattern Omni Max. input power 50W Antenna VSWR Characteristics Vertical Beamwidth 4.  1.3 57° Horizontal Beamwidth Antenna Radiation Patterns3.Antenna 360° Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-008-G Specifications www.taoglas.com 4 Mechanical Connector N Type Female Connector Location Bottom Dimensions Length 553mm, Diameter 24mm Radome Diameter 24mm Weight (& Mounting Bracket max) 380g Internal Material Copper Radome Material White Fiberglass Base Material Aluminium Waterproof IP65 Mounting Style Pole Mount/Wall Mount Mounting 32-45mm Stainless Steel U-Type Screw Environmental Wind Survival >150mph(>241km/h) Operating Temperature -40°C to +60°C Storage Temperature -40°C to +80°C Operating Humidity 10%~90% non-condensing Storage Humidity 5%~90% non-condensing SPE-12-8-008-G www.taoglas.com 5 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -5 -10 Antenna Radiation Patterns -15 Return Loss [dB] 4. 4. -20 -25 Antenna Radiation Patterns3.Antenna -30 Characteristics -35 -40 4. -45 Antenna Radiation Patterns3.Antenna 2000 2100 2200 2300 4. 2500 2600 2700 2800 2900 3000 2700 2800 2900 3000 Frequency [MHz] Characteristics 3.2 2400 VSWR 10.0 Antenna Radiation Patterns 9.0 8.0 4. Antenna Radiation Patterns 7.0 VSWR 4. 6.0 5.0 Antenna Radiation Patterns 4.0 3.0 4. Antenna Radiation Patterns3.Antenna 2.0 1.0 Characteristics 2000 2100 2200 2300 2400 2500 2600 Frequency [MHz] 4. Antenna Radiation Patterns3.Antenna SPE-12-8-008-G www.taoglas.com 6 3.3 Efficiency 100 90 80 Efficiency [%] 70 60 50 40 30 20 10 0 2000 2100 2200 2300 2400 2500 2600 2700 2800 2900 3000 2700 2800 2900 3000 Frequency [MHz] 3.4 Average Gain 0 Aver Gain [dB] -1 -2 -3 -4 -5 2000 2100 2200 2300 2400 2500 2600 Frequency [MHz] SPE-12-8-008-G www.taoglas.com 7 3.5 Peak Gain Gains 10 9 Gain [dBi] 8 7 6 5 4 3 2000 2100 2200 2300 2400 2500 2600 2700 2800 2900 3000 Frequency [MHz] SPE-12-8-008-G www.taoglas.com 8 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y Z X 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Free space SPE-12-8-008-G www.taoglas.com 9 4.2 3D & 2D Radiation Patterns XY Plane SPE-12-8-008-G XZ Plane YZ Plane www.taoglas.com 10 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-008-G Mechanical Drawing www.taoglas.com 11 6. Installation Instructions 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-12-8-008-G www.taoglas.com 12 SPE-12-8-008-G www.taoglas.com 13 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-008-G Mechanical Drawing www.taoglas.com 14 Changelog for the datasheet SPE-12-8-008 - OMB.242.08F21 Revision: G (Current Version) Date: Changes: Changes Made by: 2022-08-23 Updated data and ME drawing. Gary West Previous Revisions Revision: F Revision: A (Original First Release) Date: Changes: Changes Made by: 2019-10-31 Installation Guide Amended Jack Conroy Date: Notes: 2011-01-20 Author: Aine Doyle Revision: E Date: Changes: Changes Made by: 2018-03-27 Installation Guide Amended Jack Conroy Revision: D Date: Changes: Changes Made by: 2018-03-16 Installation Guide Detail Added Jack Conroy Revision: C Date: Changes: Changes Made by: 2017-03-08 Removed Section Aine Doyle Revision: B Date: Changes: Changes Made by: SPE-12-8-008-G 2012-11-20 Packaging Details Updated Aine Doyle www.taoglas.com 15 www.taoglas.com SPE-12-8-008-G © Taoglas 16 www.taoglas.com
OMB.242.08F21 价格&库存
很抱歉,暂时无法提供与“OMB.242.08F21”相匹配的价格&库存,您可以联系我们找货
OMB.242.08F21
  • 1+683.523101+88.83740
OMB.242.08F21
    • 2+505.02908
    • 6+480.99216
    • 23+459.14372
    • 57+439.12102
    • 170+420.83943
    库存:35
