SPECIFICATION
IS.04 868MHz Hercules ISM Band Antenna
Part No.
IS.04.B.301111
Product Name
Screw-mount (Permanent mount)
Features
Low profile-Height 29mm and diameter 49mm
Heavy duty screw mount
UV and Vandal resistant PC housing
IP67 & IP69K
Standard cable is 3m RG174 with SMA(M)connector fully customizable
ROHS Compliant
SPE-13-8-020/D/EZ
Page 1 of 17
1. INTRODUCTION
The 868MHz Hercules ISM antenna is a high performance steel thread-mount ISM
antenna for external use on vehicles and outdoor assets worldwide. Omni-directional
high gain across all bands ensures constant reception and transmission. Durable UV
resistant PC housing is resistant to vandalism and direct attack. At only 29 mm height it
complies with the latest EU height restrictions directives for roof-mounted objects, with a
diameter of 52 mm. Designed to not catch on tree-branches. The antenna can be
mounted on metal structures.
2. SPECIFICATION
ELECTRICAL
Standard
ISM
Band (MHz)
868
Frequency (MHz)
868-870
Cable Length (m)
0.3
1.0
2.0
3.0
5.0
Return Loss (dB)
-13.95
-14.09
-13.84
-13.07
-21.93
Efficiency (%)
26.88
43.12
38.52
33.75
20.45
Gain (dBi)
1.17
2.09
1.98
1.03
Polarization
1.98
Linear
Impedance
50 ohms
Max Input Power
10 watts
VSWR
很抱歉,暂时无法提供与“IS.04.B.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+329.966701+42.88002
