33-3040-01-01
33-3040-01-01
    TALLYSMANWIRELESS
33-3040-01-01 数据手册
TW3040/ TW3042 Permanent Mount GPS L1 Antenna The TW3040/TW3042 is a professional grade, permanent mount GPS L1 antenna, specially designed for professional precision timing applications. The TW3040/TW3042 features a custom high performance, wide band patch element, a 40dB gain LNA stage and a high rejection out-of-band SAW filter. The TW3042 is equipped with a sharp SAW pre-filter to provide strong protection from out-of-band signals. It provides ±10MHz bandwidth centred on 1575.42 MHz and covers the GPS L1, Galileo E1 and SBAS (WAAS/EGNOS/MSAS) signals, and it provides great axial ratio, excellent circular polarized signal reception, great multipath rejection and great out-of-band signal rejection. The TW3040/TW3042 is housed in a permanent mount industrial-grade weather-proof enclosure and two options for pole mounting are available an Lbracket (P/N#23-0040-0) or a pipe mount (P/N#230065-0). TW3040/TW3042 Dimensions (mm) Flat Radome shown. Conical Radome also available Applications • • • • • • Mission Critical GPS Tracking & Timing Precision Agriculture, Mining & Construction Military & Security Avionics Law Enforcement & Public Safety Fleet Management & Asset Tracking Features Benefits • • • • • • • • • • • • • • Great axial ratio Low noise LNA: 1 dB High rejection SAW filter High gain: 40 dB typ. Low current: 15 mA typ. ESD circuit protection: 15 KV Wide voltage input range: +2.5 to 16 VDC Weather proof housing: IP67 Excellent multipath rejection Increase system accuracy Excellent signal to noise ratio Great out of band signal rejection Ideal for harsh environments RoHS and REACH compliant TW3040/TW3042 Permanent Mount GPS L1 Antenna Specifications Vcc = 3V, over full bandwidth, T=25°C Antenna Antenna Architecture Antenna Element Gain (100mm ground plane) Axial Ratio (over full bandwidth) Electrical Architecture Frequency Bandwidth Polarization Gain Out-of-Band Rejection 1600 MHz >1620 MHz VSWR (at LNA input) Noise Figure Supply Voltage Range Supply Current ESD Circuit Protection Mechanicals & Environmental Mechanical Size Operating Temp. Range Enclosure Weight Environmental Shock Vibration Salt Spray Single-feed RHCP ceramic patch 4 dBic at 90° 4 dB at 90° 3 stage LNA circuit + a mid section SAW filter. (Pre-filter option available) 1575 MHz ± 10 MHz RHCP TW3040: 40 dB min. TW3042: 39 dB min TW3040 TW3042 >42 dB >50 dB >31 dB >50 dB >45 dB >70 dB
33-3040-01-01 价格&库存
很抱歉,暂时无法提供与“33-3040-01-01”相匹配的价格&库存,您可以联系我们找货
