RG.02.01.3000W
RG.02.01.3000W
    TAOGLASLIMITED
    RG.02.01.3000W
RG.02.01.3000W 数据手册
4G LTE Roadmarker Part No: RG.02.01.3000W Description: Roadmarker Low Profile 4G LTE Cellular Antenna with CAB.826 cable assembly Features: Low Profile 4G LTE Cellular Antenna UV and Vandal Resistant PP Enclosure IP67 Rated Diameter: 101.4mm Height: 17.6mm RoHS & Reach Compliant SPE-14-8-037-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 7 4. Radiation Patterns 9 5. Mechanical Drawing – Roadmarker 14 6. Mechanical Drawing – Cable Assembly 15 7. Packaging 16 Changelog 17 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-037-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Roadmarker RG.02 has been designed to be used inside standard raised non-reflective roadmarkers. These are designed for, and installed inside, the low profile “Bott’s dots” that can to be mounted directly on the pavement and therefore the roads. 1. The Roadmarker uses a high efficiency 4G LTE antenna that can also operate at 3G/2G and NB-IoT/Cat-M bands, if fallback is required. 1. Introduction Introduction These antennas exhibit relatively high efficiencies in such small packages and reside in a very low-profile enclosure. They are designed to be mounted directly on the road and pavement just like a standard roadmarker. Introduction Typical Applications Include: 1. :: Introduction Smart Metering :: Remote Monitoring :: Security These antennas have been potted with the epoxy that is traditionally used to secure the roadmarker itself to the ground. There are no air gaps whatsoever inside the new type approved roadmarker with antenna, in order to maintain the mechanical integrity. It is presumed that the standard black epoxy will also be used to install the roadmarker in its final resting place on the ground. The cable and connector are fully customizable, for further information please contact your regional Taoglas customer support team. SPE-14-8-037-E www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Specifications Electrical LTE 700 3. GSM 850 GSM 900 Antenna698~ Characteristics 803 824~ 894 880~ 960 DCS PCS UMTS1 Wi-Fi LTE 2600 2400~ 2480 2490~ 2690 Frequency (MHz) 1710~ 1880 1850~ 1990 1920~ 2170 Efficiency (%) 4. 57 56 44 38 28 27 37 34 -5.5 -5.7 -4.4 -4.6 1 2 2 10 10 18 16 1.92 1.92 1.29 1.38 Antenna Radiation Patterns3.Antenna Average Gain (dB) Characteristics2. -2.5 Specifications -2.5 -3.6 -4.2 Peak Gain (dBi) 3. 3.2 2.8 1.6 Antenna Characteristics2. 2.4 1.3 Specifications Return Loss (dB) 15 3. 11 Antenna Characteristics 1.92 4. 16 1.38 16 Average VSWR 1.78 1.38 Impedance 50Ω Antenna Radiation Patterns3.Antenna Radiation Pattern Omnidirectional Max. input power 10W Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-14-8-037-E Specifications www.taoglas.com 4 Mechanical Dimensions (mm) Height = 17.6 mm and Diameter = 101.4 mm Cable WY-100 Coaxial Cable Connector SMA(M)ST Casing UV Resistant PP Sealant Potting Environmental Protection IP67 Corrosion 5% NaCI for 96hrs Temperature Range -40°C to +85°C Thermal Shock 100 cycles -40°C to +85°C Humidity Non-condensing 65°C 95% RH Shock (Drop Test) 1m drop on concrete 6 axes Cable Pull 8 Kgf SPE-14-8-037-E www.taoglas.com 5 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 – 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 3550 to 3700 48 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 77 3300 to 4200 78 3300 to 3800 79 4400 to 5000 SPE-14-8-037-E Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓      ✓    www.taoglas.com 6 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Roadmarker - [Return Loss] 0 Characteristics -5 Roadmarker on granite Roadmarker in Free Space -10 4. Amplitude [dB] -15 Antenna Radiation Patterns -20 4. -25 Antenna Radiation Patterns3.Antenna -30 Characteristics -35 -40 4. 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 Antenna Radiation Patterns3. Antenna Freq. [MHz] 600 2200 2300 2400 2500 2600 2700 Characteristics 3.2 Efficiency 100 4. 90 Antenna Radiation Patterns Free Space On Granite 80 70 (%) 4. 60 Antenna Radiation Patterns 50 40 4. 30 Antenna Radiation Patterns 20 4. 10 Antenna Radiation Patterns3.Antenna 0 600 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 2300 2400 2500 2600 2700 (MHz) Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-037-E www.taoglas.com 7 3.3 Average Gain 0 -2 -4 -6 (dB) -8 -10 -12 -14 Free Space On Granite -16 -18 600 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 2300 2400 2500 2600 2700 3.4 (MHz) Peak Gain 5 4 3 2 1 0 -1 (dBi) -2 -3 -4 -5 -6 -7 -8 -9 Free Space On Granite -10 -11 600 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 2300 2400 2500 2600 2700 (MHz) SPE-14-8-037-E www.taoglas.com 8 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y 4. X Antenna Radiation Patterns 4. ZAntenna Radiation Patterns Mounted on Granite in the ETS-Lindgren's AMS-8500 anechoic chamber. SPE-14-8-037-E www.taoglas.com 9 4.2 2D Radiation Patterns XY Plane SPE-14-8-037-E www.taoglas.com 10 YZ Plane SPE-14-8-037-E www.taoglas.com 11 XZ Plane SPE-14-8-037-E www.taoglas.com 12 SPE-14-8-037-E www.taoglas.com 13 5. Mechanical Drawing – Roadmarker 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-037-E Mechanical Drawing www.taoglas.com 14 6. Mechanical Drawing – Cable Assembly 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-037-E www.taoglas.com 15 7. Packaging 6. 1pcs RG.02.01.3000W Packaging5. per carton Mechanical Drawing Dimensions - 350*340*47mm Weight - 92g 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. 24pcs RG.02.01.3000W per carton Dimensions - 589*296*135mm Weight – 2.4Kg Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. 135mm 589mm 296mm Mechanical Drawing 6. Packaging5. SPE-14-8-037-E Mechanical Drawing www.taoglas.com 16 Changelog for the datasheet SPE-14-8-037 – RG.02.01.3000W Revision: E (Current Version) Date: Changes: Changes Made by: 2020-01-23 Updated data to show 4G Jack Conroy Previous Revisions Revision: D Date: Changes: Changes Made by: 2017-01-08 Updated to remove reference to manhole covers as per request by KB. Also added disclaimer Andy Mahoney Revision: C Date: 2014-05-16 Changes: Changes Made by: Aine Doyle Revision: B Date: Changes: Changes Made by: 2014-04-23 Aine Doyle Revision: A (Original First Release) Date: Notes: 2014-08-17 Author: Aine Doyle SPE-14-8-037-E www.taoglas.com 17 www.taoglas.com SPE-14-8-037-E © Taoglas 18 www.taoglas.com
RG.02.01.3000W 价格&库存
很抱歉,暂时无法提供与“RG.02.01.3000W”相匹配的价格&库存,您可以联系我们找货
