IS.05.B.301111
IS.05.B.301111
    TAOGLASLIMITED
    IS.05.B.301111
IS.05.B.301111 数据手册
SPECIFICATION Part No. : Product Name : IS.05.B.301111 915MHz Hercules ISM Band Antenna Screw-mount (Permanent mount) Features : Low Profile Height: 29mm, Diameter: 49mm Heavy Duty Screw Mount UV and Vandal Resistant PC Housing IP65 – Waterproof Standard cable is 3m RG174 with SMA(M)connector fully customizable ROHS & REACH Compliant SPE-13-8-019-E Page 1 of 17 1. INTRODUCTION The 915MHz Hercules ISM Antenna is a high performance steel thread-mount ISM antenna for external use on vehicles and outdoor assets worldwide. Omni-directional high gain across all bands ensures constant reception and transmission. Durable UV resistant PC housing is IP65 rated, resistant to vandalism and direct attack. At only 29 mm height it complies with the latest EU height restrictions directives for roof-mounted objects, with a diameter of 52 mm. Designed to not catch on tree-branches. The antenna can be mounted on metal structures. 2. SPECIFICATION ELECTRICAL Standard ISM Band (MHz) 915 Frequency (MHz) 902-928 Cable Length (m) 0.3 1.0 2.0 3.0 5.0 Return Loss (dB) -13.68 -13.86 -15.16 -14.61 -17.54 Efficiency (%) 27.49 44.13 38.36 27.09 21.10 Gain (dBi) 1.15 2.75 1.85 0.25 Polarization 3.14 Linear Impedance 50 ohms Max Input Power 10 watts VSWR
IS.05.B.301111 价格&库存
很抱歉,暂时无法提供与“IS.05.B.301111”相匹配的价格&库存,您可以联系我们找货
