33-2920-00-1000
33-2920-00-1000
    TALLYSMANWIRELESS
    TW2920 是一款 Accutenna 技术天线,覆盖 GPS L1, GLONASS G1, BeiDou B1, Galileo E1, SBAS 和 L-Band 频段。它提供卓越的多路径信号...
33-2920-00-1000 数据手册
A Tallysman Accutenna® TW2920 Wideband GPS/GLONASS/BeiDou/Galileo + L-Band Antenna The TW2920 is an Accutenna technology antenna that covers GPS L1, GLONASS G1, BeiDou B1, Galileo E1, SBAS (WAAS, EGNOS, GAGAN, & MSAS) and the downlink L-Band (1525 – 1559MHz). The TW2920 provides superior multi-path signal rejection, a linear phase response, and tight Phase Centre Variation (PCV). This antenna is ideal for precision agriculture, autonomous vehicle tracking and guidance, and other applications where precision matters. Dimensions (mm) The TW2920 features a dual-feed wideband patch element, plus a low-loss pre-filter followed by a three stage Low Noise Amplifier (LNA) including an additional mid-section SAW. This configuration provides excellent axial ratio across the full frequency band and strong protection against high level sub-harmonic signals like LTE and near frequency signals such as WiFi. The TW2920 has a compact, robust, magnetic mount housing with a metal base and a UV resistant, tough wide temperature range plastic radome, and is available with a variety of connectors. The housing includes a screw down option, and is available with an adhesive attachment, without a magnet, Dimensions (mm) The TW2920 is also available with an “armoured” cable. option, with the cable encased in tough corrugated conduit having a temperature range of -40 to +120C, excellent chemical resistance, stable bending, high cold impact strength, and UL94HB flammability standard compliant. Applications • • • High Accuracy & Mission Critical GNSS Precision Agriculture, Mining & Construction Military & Security Features • • • • • • Low loss Great axial ratio: ≤ 1 typ., 2 dB max Low noise LNA: ≤2.5 dB (including pre-filter) High rejection SAW filter Wide voltage input range: 2.5 to 16 VDC IP67 weather proof housing Economical price Benefits • • • • • • Excellent multipath rejection Increased system accuracy Excellent signal to noise ratio Great out of band signal rejection Ideal for harsh environments RoHS and REACH compliant TW2920 Pre-filtered GPS/GLONASS/BeiDou/Galileo + L-Band Antenna Specifications Vcc = 3V, over full bandwidth, T=25°C Antenna Architecture 1 dB Bandwidth Antenna Zenith Gain (with 100mm ground plane) Axial Ratio Electrical Architecture Filtered LNA Frequency Bandwidth Polarization LNA Gain Gain flatness Out-of-Band Rejection 1700 MHz VSWR (at LNA output) Noise Figure Supply Voltage Range (over coaxial cable) Supply Current ESD Circuit Protection Mechanicals & Environmental Mechanical Size Cable Operating Temp. Range Enclosure Weight Attachment Method Environmental Shock Vibration Dual Feed Patch, Quadrature Feeds 85 MHz 4.25 dBic ≤1 dB typ, 2 dB max. Pre-filter ->LNA ->SAW filter-> 2 stage LNA 1510 to 1610 MHz RHCP 32 dB min., 1510 to 1610 MHz +/- 2 dB, 1510 to 1610 MHz >30 dB >55 dB
33-2920-00-1000 价格&库存
很抱歉,暂时无法提供与“33-2920-00-1000”相匹配的价格&库存,您可以联系我们找货
