GNSS Hercules
Part No:
A.40.A.301111
Description:
GPS/GLONASS/Galileo Hercules Heavy Duty Permanent Mount Antenna
Features:
Bands Covered:
GPS L1
GLONASS G1
Galileo E1
Heavy duty Permanent mount
Dimensions: Ø48*29mm
Cable: 3m RG-174
IP65 Rated Enclosure
Connector: SMA(M) Straight
RoHS & Reach Compliant
SPE-13-8-053-L
1.
Introduction
3
2.
Specifications
4
3.
Passive Antenna Characteristics
6
4.
Active Antenna Characteristics
8
5.
Radiation Patterns
12
6.
Mechanical Drawing
15
7.
Installation Guide
16
8.
Packaging
17
Changelog
18
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-13-8-053-L
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
Introduction
The A.40 Hercules is an active high-performance permanent mount GPS/GLONASS/Galileo antenna designed
for external use on vehicles and outdoor assets. Durable UV resistant PC housing is IP65 rated, resistant to
vandalism and direct attack. At only 29mm high it complies with the latest EU directives for height
restrictions, whilst also enabling covert operation with a diameter of only 49mm.
Introduction
Typical Applications Include:
- Remote Asset Tracking
- Navigation
- Telematics Devices
Introduction
The cable and connector is fully customizable, for further information, please contact your regional Taoglas
customer support team.
1.
Introduction
SPE-13-8-053-L
www.taoglas.com
3
2.
Specifications
3.
GNSS Frequency Bands Covered
AntennaL1 Characteristics2.
Specifications
L2
L5
L6
GPS/QZSS
1575.42MHz
1227.6MHz
1176.45MHz
1278.75MHz
L5R
L3PT
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
E5a
1176.45MHz
E5b
1201.5MHz
E4
1215MHz
E3
1256MHz
E6
1278.75MHz
E2
1561MHz
E1
1575.42MHz
3. GLONASS
Antenna
Characteristics
1176.45MHz
1201.5MHz
Galileo
4.
Antenna□ Radiation
Patterns3.
Antenna
B1
BeiDou
Characteristics2.
1561MHz
Compass
3.
B3
Specifications
1268.52MHz
E5B(B2)/ E6(B3)
1268.56MHz
E2(B1)
1561MHz
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
Antenna□ Characteristics2.
SBAS
3.
B2
1207.14MHz
Specifications
GNSS Electrical
4.
Frequency (MHz)
Antenna
Radiation Patterns3.Antenna
VSWR (max.)
2.0:1
Impedance (Ohm)
Characteristics
4.
4.
50Ω
Polarization
RHCP
Input Voltage(V)
Typ. 2.5~5.5V
Antenna
Radiation
Patterns
Total Gain @
Zenith
27dB typical at 3.0V
Current consumption(mA)
10mA typical at 3.0V
Noise figure
2.9dB typical
Antenna
GPS/GALILEO Gain@ Zenith
-1.4dB Passive Gain @ Zenith
GLONASS Patch Gain@ Zenith
Characteristics
-1.3dBi Gain @ Zenith
fo = 1575.42MHz
fo ± 30 MHz 5dB Min.
fo ± 50 MHz 20dB Min.
fo ± 100 MHz 25dB Min.
Out Band Rejection
4.
1574 ~ 1606
Antenna Radiation Patterns3.Antenna
Characteristics2.
SPE-13-8-053-L
Specifications
www.taoglas.com
4
Mechanical
Dimensions
Ø49mm Height 28.5mm
Cable type
RG-174
Cable length
3000mm
Casing
UV Resistant PC
Connector
SMA Male Straight
Recommended Mounting
Torque
5-7Nm
Environmental
Operation Temperature
Range
-40°C to 85°C
Storage Temperature Range
-40°C to 85°C
Waterproof
IP65
Thermal Shock
100 cycles -40°C to +85°C
Shock (drop test)
1m drop on concrete 6 axes
SPE-13-8-053-L
www.taoglas.com
5
3.
3.1
4.
Return Loss
1
Characteristics
Free Space
Ground Plane
0.75
4.
Return Loss [dB]
4.
0.5
0.25
Characteristics
4.
1350
1400
1450
1500
1550
1600
Antenna
Frequency
[MHz]
1650
1700
1750
1800
Characteristics
3.2
Efficiency
100
Free Space
4.
90
Ground Plane
80
4.
4.
Efficiency [%]
70
60
50
40
30
4.
1350
1400 Patterns3.
1450
1500Antenna
1550
1600
Antenna
Radiation
1650
1700
1750
1800
Frequency [MHz]
Characteristics
4.
SPE-13-8-053-L
www.taoglas.com
6
3.3
Peak Gain
5
Free Space
3
Ground Plane
1
Gain [dBi]
-1
-3
-5
-7
-9
-11
-13
-15
1300
1350
1400
1450
1500
1550
1600
1650
1700
1750
1800
Frequency [MHz]
3.4
Average Gain
Free Space
-2
Ground Plane
-4
Aver Gain [dB]
-6
-8
-10
-12
-14
-16
-18
-20
1300
1350
1400
1450
1500
1550
1600
1650
1700
1750
1800
Frequency [MHz]
SPE-13-8-053-L
www.taoglas.com
7
4.
4.
4.1
LNA Block Diagram
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-13-8-053-L
www.taoglas.com
8
4.2
Axial Ratio
60
50
Axial Ratio
40
30
1400
1450
1500
1550
1600
1650
1700
1750
1800
1650
1700
1750
1800
Frequency [MHz]
4.3
Group Delay
50
Group Delay [ns]
35
-10
-25
-40
1400
1450
1500
1550
1600
Frequency [MHz]
SPE-13-8-053-L
www.taoglas.com
9
4.4
Out of Band Attenuation
50
40
30
S12(dB)
10
-20
-30
-40
-50
800
1200 1600 2000
2400
2800 3200
3600
4000 4400
4800
5200 5600
6000
Frequency [MHz]
4.5
LNA Gain
50
40
30
S12(dB)
10
-20
-30
-40
-50
1400
1425
1450
1475
1500
1525
1550
1575
1600
1625
1650
1675
1700
Frequency [MHz]
SPE-13-8-053-L
www.taoglas.com
10
4.6
Noise Figure
5.00
4.00
S12(dB)
3.00
2.00
1.00
0.00
1570
1575
1580
1585
1590
1595
1600
1605
1610
Frequency [MHz]
SPE-13-8-053-L
www.taoglas.com
11
5.
4.
Radiation Patterns
5.1
Test Setup
4.
4.
4.
4.
4.
4.
Antenna Radiation PatternsChamber Setup
SPE-13-8-053-L
www.taoglas.com
12
5.2
1575.42MHz 3D and 2D Radiation Patterns
XY Plane
SPE-13-8-053-L
XZ Plane
YZ Plane
www.taoglas.com
13
1602MHz
XY Plane
SPE-13-8-053-L
XZ Plane
YZ Plane
www.taoglas.com
14
6.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-053-L
Mechanical Drawing
www.taoglas.com
15
7.
Installation
4.
Characteristics
4.
4.
Characteristics
4.
Antenna Radiation
Patterns3.Antenna
Recommended torque for mounting: 5-7Nm
(Torque value obtained with antenna mounted on 1mm thick SUS-316 bracket)
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-13-8-053-L
www.taoglas.com
16
8.
Packaging
1pc A.40.A.301111 per PE Bag
100*300mm
6. Dimensions:
Packaging5.
Weight: 151g
Mechanical Drawing
300mm
6.
Packaging
100mm
7.
10 pcs A.40.A.301111 per Large PE Bag
Dimensions: 280*450mm
Weight: 1.524Kg
Mechanical
Drawing
450mm
6.
Packaging5.
Mechanical Drawing
280mm
6.
7.
60pcs A.40.A.301111 per carton
Dimensions - 320*250*230mm
Weight – 9.8Kg
Packaging
Application Note6. Packaging 230mm
320mm
7.
Application Note
250mm
Pallet Dimensions:
1200*1000*1650mm
60 Cartons per Pallet
12 Cartons per Layer, 5 Layers
7.
1650mm
7.
Drawing
6.
Packaging5.
SPE-13-8-053-L
Mechanical
1200mm
Mechanical Drawing
1000mm
www.taoglas.com
17
Changelog for the datasheet
SPE-13-8-053 – A.40.A.301111
Revision: L (Current Version)
Date:
Changes:
Changes Made by:
2022-10-13
Added LNA Block diagram
Cesar Sousa
Previous Revisions
Revision: F
Revision: K
Date:
Changes:
Changes Made by:
2022-02-23
Updated data
Gary West
Revision: J
Date:
Changes:
Changes Made by:
2019-01-22
Amended Drawing
Jack Conroy
Revision: E
Date:
Changes:
Changes Made by:
2021-02-09
Updated IP rating
Erik Landi
Revision: I
Date:
Changes:
Changes Made by:
2018-12-12
Amended Heatshrink Drawing
Jack Conroy
Revision: D
Date:
Changes:
Changes Made by:
2021-02-09
Updated waterproof rating
Jack Conroy
Revision: H
Date:
Changes:
Changes Made by:
Changes Made by:
SPE-13-8-053-L
Changes Made by:
2016-06-01
Amended Packaging and Info
Aine Doyle
Revision: C
2020-03-27
Updated Packaging and Template
Jack Conroy
Revision: G
Date:
Changes:
Date:
Changes:
Date:
Changes:
Changes Made by:
2014-08-26
Removed Saw info
Aine Doyle
Revision: B
2019-11-07
Amended Drawing
Jack Conroy
Date:
Changes:
Changes Made by:
2014-08-11
Updated Torque Info
Aine Doyle
www.taoglas.com
18
Revision: A (Original First Release)
Date:
2013-07-26
Notes:
Author:
SPE-13-8-053-L
Wayne Yang
www.taoglas.com
19
www.taoglas.com
SPE-13-8-053-L
© Taoglas 20
www.taoglas.com
很抱歉,暂时无法提供与“A.40.A.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+534.617821+69.16709
- 10+440.8429810+57.03481
- 30+413.4452730+53.49019
- 100+391.69748100+50.67653
