Specification
Part Number:
IMA.01.105111
Product Name:
External Iridium™ Marine Antenna
Features:
1616MHz ~1626.5MHz Iridium antenna
Antenna Efficiency > 65% with 1.0 meter standard cable
IP67 waterproof
Standard 1M CFD-200 coaxial cable
Bracket Mount Available
Custom cables and connectors available
Dims: 108mm Ø90mm
RoHS Complaint
SPE-14-8-114/C/WY
Page 1 of 13
Introduction
The IMA.01 Iridium Marine antenna is a high performance, durable, bracket
mount antenna which is designed for applications using the Iridium® Satellite
Communication system.
The durable IP67 rated housing makes the IMA.01 the ideal solution for
permanent marine installations. The antenna exhibits excellent efficiency,
greater than 65% with the standard 1.0 meter CFD-200 coaxial cable.
Iridium® has certified the IMA.01 antenna for commercial use in connection
with the Iridium Communications System. Iridium Satellite LLC is the owner
of Iridium® and all other Iridium trademarks, service marks, and logos
contained herein.
The IMA.01 antenna is designed for free air operation, thus no ground plane
is required.
SPE-14-8-114/C/WY
Page 2 of 13
Specification
ELECTRICAL
Band
Iridium
Center Frequency
(MHz)
Range of Receiving
Frequency (MHz)
Impedance (Ohms)
Polarization
VSWR
0.5
1.0
Cable
length
2.0
(meter)
3.0
5.0
Efficiency (%)
0.5
1.0
Cable
length
2.0
(meter)
3.0
5.0
Return Loss (dB)
0.5
1.0
Cable
length
2.0
(meter)
3.0
5.0
1621.5±5.25MHz
1621~1626.5
50 Ohms
Right Hand Circular
2.0
1.8
1.7
1.6
1.5
79.3
75.6
67.4
45.1
38.3
-8.9
-10.5
-11.5
-12.7
-13.7
Peak Gain (dBi)
Cable
length
(meter)
0.5
1.0
2.0
3.0
5.0
4.0
3.9
3.7
2.2
1.3
MECHANICAL
Dimensions
Ø90x108mm
Cable
CFD-200 Coaxial , 1 meter length
Connector
SMA (M) 50 Ohms
Termination
Ag (Environmentally-Friendly PB Free)
Protection
IP67
Weight
108 grams
ENVIRONMENTAL
Temperature
Range
Storage
Temperature
-40°C to +85°C
-40°C to +85°C
Relative Humidity
40% to 95%
Shock (Drop
Test)
1m drop on concrete 6 axes
SPE-14-8-114/C/WY
Page 3 of 13
Test Setup
Figure 1. Impedance (left hand),
Efficiency, peak gain, and radiation pattern measurements (right hand).
Antenna Parameters
4.1. Return Loss
Figure 2. Return Loss of the IMA.01 antenna.
SPE-14-8-114/C/WY
Page 4 of 13
4.2. VSWR
Figure 3. VSWR of the IMA.01 antenna.
4.3 Efficiency
Figure 4. Efficiency of the IMA.01 antenna.
SPE-14-8-114/C/WY
Page 5 of 13
4.4 Peak Gain
Figure 5. Peak Gain of the IMA.01 antenna.
4.5. 3D Radiation Pattern
Figure 6. Radiation pattern of the antenna IMA.01 at 1616 MHz with 1 meter cable
length.
SPE-14-8-114/C/WY
Page 6 of 13
Figure 7. Radiation pattern of the antenna IMA.01 at 1621 MHz with 1 meter cable
length.
Figure 8. Radiation pattern of the antenna IMA.01 at 1626 MHz with 1 meter cable
length.
SPE-14-8-114/C/WY
Page 7 of 13
4.6. 2D Radiation Pattern
Figure 9. XY Plane Radiation Pattern of the antenna IMA.01 with 1 meter cable length.
Figure 10. YZ Plane Radiation Pattern of the antenna IMA.01 with 1 meter cable
length.
SPE-14-8-114/C/WY
Page 8 of 13
Mechanical Drawing (Unit: mm)
SPE-14-8-114/C/WY
Page 9 of 13
5.1 Bracket
* See P/N - IMA.01.105111.wm if bracket is needed for further implement.
SPE-14-8-114/C/WY
Page 10 of 13
5.2 U-Bolt
SPE-14-8-114/C/WY
Page 11 of 13
Packaging
SPE-14-8-114/C/WY
Page 12 of 13
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-114/C/WY
Page 13 of 13
很抱歉,暂时无法提供与“IMA.01.105111”相匹配的价格&库存,您可以联系我们找货
