33-3600-01-11
33-3600-01-11
    TALLYSMANWIRELESS
    TW3600 是一款的被动右旋圆极化天线,适用于 1616 至 1626.5 MHz 频段,专为提高铱星语音和数据调制解调器的性能而设计。
33-3600-01-11 数据手册
A Tallysman Accutenna® TW3600 Permanent Mount Iridium® Antenna The TW3600 employs Tallysman’s unique Accutenna technology in a permanent mount, passive right hand circularly polarised antenna for the 1616 to 1626.5 MHz frequency band, specially designed to maximise the performance of Iridium™ voice and data modems. The TW3600 features a high performance dualfeed patch element that provides great axial ratio (3dB max) over the entire Iridium™ frequency band, thus signals at the band edges remain truly circular, unlike the response of single feed antennas. TW3600 Dimensions (mm) The TW3600 is housed in a permanent mount industrial-grade weather-proof enclosure and comes with a TNC Jack (female) connector, allowing for the Iridium™ modem to be mounted out of the elements and reach, and still providing excellent Iridium™ signal coverage. Applications       Iridium® Voice and Data Applications Sea & Land Container Tracking Military & Security Fleet Management & Asset Tracking Marine & Avionics Systems Law Enforcement & Public Safety Features Benefits             Custom high gain, 4.25 dBic dual-feed patch Great axial ratio, 3 dB over full bandwidth 15 KV ESD circuit protection IP67 weather proof housing Robust Industrial grade enclosure Surface, bracket or mast mount Excellent circular polarized signal transmission Industrial temperature range Rugged Design Ideal for harsh environments RoHS and REACH compliant Remote antenna TW3600 Permanent Mount Iridium® Antenna Specifications Vcc = 3V, over full bandwidth, T=25°C Antenna Architecture Antenna Gain (100mm ground plane) Axial Ratio (over full bandwidth) Radiated Bandwidth (-0.5 dB) Dual, quadrature feeds 4.25 dBic ≤3 dB 1605 MHz to 1635 MHz Electrical Architecture Frequency Bandwidth Polarization Gain flatness VSWR (at antenna) Return Loss (-10 dB bandwidth) ESD Circuit protection Hybrid 90° phase signal splitter 1616 to 1626.5 MHz RHCP ≤0.5 dB, from 1616 to 1626.5 MHz 20 MHz 15 KV air discharge Mechanicals & Environmental Mechanical Size Cable (Option) Operating Temp. Range Enclosure Weight Attachment Method Environmental Shock Vibration Warranty Salt Spray 66.5 mm dia. x 21 mm H Custom cable assembly available. -40 to +85 °C Radome: EXL9330, Base: Zamak White Metal 150 g Permanent ¾” (19mm) through hole mount IP67 and RoHS compliant Vertical axis: 50 G, other axes: 30 G 3 axis, sweep = 15 min, 10 to 200 Hz sweep: 3 G One year, parts and labour MIL-STD-810F Section 509.4 Ordering Information TW3600 – Iridium® antenna 33-3600-xx-yy-zzzz Where xx = connector type, yy = shape and colour of radome and zzzz = cable length in mm (where applicable) Please refer to the Ordering Guide (http://www.tallysman.com/orderingguide.php) for the current and complete list of available radomes and connectors. Tallysman Wireless Inc 36 Steacie Drive Ottawa ON K2K 2A9 Canada Canada Tel 613 591 3131 Fax 613 591 3121 sales@tallysman.com The information provided herein is intended as a guide only and is subject to change without notice. This document is not to be regarded as a guarantee of performance. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind. © 2010 Tallysman Wireless Inc. All rights reserved. Rev 3.2
33-3600-01-11
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种嵌入式应用。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种外设和接口,适用于工业控制、消费电子等领域。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考引脚图。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM,支持多种通信接口如USART、SPI、I2C等。
5. 功能详解:详细介绍了各外设模块的功能和使用方法,如ADC、定时器、DMA等。
6. 应用信息:适用于需要高性能处理和丰富外设接口的应用场景,如电机控制、工业自动化等。
7. 封装信息:采用LQFP48封装,尺寸7x7mm,适用于贴片焊接。
33-3600-01-11 价格&库存
很抱歉,暂时无法提供与“33-3600-01-11”相匹配的价格&库存,您可以联系我们找货
