OMB.8912.03F21
OMB.8912.03F21
    TAOGLASLIMITED
    OMB.8912.03F21
OMB.8912.03F21 数据手册
SPECIFICATION Part No. : OMB.8912.03F21 Description : Barracuda - 3 dBi Penta-band Cellular Indoor/Outdoor Omni-Directional Antenna Feature : GSM850/ GSM900/ DCS/ PCS/ WCDMA I 850/ 900/ 1800/ 1900/ 2100 MHz Omni-Directional Radiation Pattern Collinear 4.89 dBi Peak Gain Robust Design for all Weather operation IP65 Waterproof Length: 298mm, Weight: 350g Connector: N-type Female Wall/Pole Mount Bracket Included RoHS compliant SPE-12-8-128/D/PK Page 1 of 12 1. Introduction The Penta-band cellular Barracuda Outdoor antenna is designed to a have long distance coverage. Omni-directional high gain across all bands ensures constant reception and transmission. The UV resistant coating with fiberglass housing makes this antenna suitable to be mounted in robust outdoor environment, pole-mounting and wall-mounting bracket is included. The antenna finds its usage in boosting cellular coverage in remote areas or difficult environments indoors and outdoors. SPE-12-8-128/D/PK Page 2 of 12 2. Specification ELECTRICAL Standard GSM GSM DCS PCS WCDMA I Band 850 900 1800 1900 2100 1850~199 0 1920~217 0 Frequency (MHz) 824~894 880~960 1710~188 0 Peak Gain (dBi) 1.55 2.13 4.47 4.49 4.89 Average Gain (dBi) 1.18 1.78 3.87 4.24 4.08 Efficiency (%) 63.4 75.7 81.2 88.8 87.3 Antenna Type Collinear Polarization Vertical Impedance 50 ohms Max Input Power 50 watts VSWR 150mph (>241km/h) SPE-12-8-128/D/PK Page 3 of 12 ENVIRONMENTAL Storage Temperature -40°C to +80°C Operating Temperature -40°C to +60°C Operating Humidity 10%~80% non-condensing Storage Humidity 5%~80% non-condensing 3. Antenna Characteristics 3.1 Return Loss SPE-12-8-128/D/PK Page 4 of 12 3.2 Maximum Gain 3.3 Efficiency SPE-12-8-128/D/PK Page 5 of 12 4. 3D Radiation Property SPE-12-8-128/D/PK Page 6 of 12 XY-plane X Y X Y SPE-12-8-128/D/PK Page 7 of 12 XZ-plane Z X Z X SPE-12-8-128/D/PK Page 8 of 12 5. Drawing SPE-12-8-128/D/PK Page 9 of 12 6. Packaging Antennas are packed in carton tubes inside PE bags. Mounting components are packed in the separate PE bag inside the tube SPE-12-8-128/D/PK Page 10 of 12 7. Antenna Installation Guide SPE-12-8-128/D/PK Page 11 of 12 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-128/D/PK Page 12 of 12
OMB.8912.03F21 价格&库存
很抱歉,暂时无法提供与“OMB.8912.03F21”相匹配的价格&库存,您可以联系我们找货
OMB.8912.03F21
    • 50+660.57982
    库存:43
