ANT-418-HESM
ANT-418-HESM
    LINXTECHNOLOGIES(灵思)
    SMD
    ANT-418-HESM
ANT-418-HESM 数据手册
ANT-418-HESM Data Sheet by Product Description HE Series antennas are designed for direct PCB mounting. Thanks to the HE’s compact size, they are ideal for internal concealment inside a product’s housing. The HE is also very low in cost, making it well suited to high-volume applications. HE Series antennas have a very narrow bandwidth; thus, care in placement and layout is required. In addition, they are not as efficient as whip-style antennas, so they are generally better suited for use on the transmitter end where attenuation is often required anyway for regulatory compliance. Use on both transmitter and receiver ends is recommended only in instances where a short range (less than 30% of whip style) is acceptable. Outside 8.89 mm Diameter (0.35") Inside 6.35 mm Diameter (0.25") Wire Diameter 1.27 mm (0.05") 38.10 mm (1.50") Features • • • • • Very low cost Compact for physical concealment Precision-wound coil Rugged phosphor-bronze construction Surface-mount Recommended Mounting No ground plane or traces under the antenna 38.10 mm (1.50") No electircal connection on this pad. For physical support only. Electrical Specifications Center Frequency: Recom. Freq. Range: Wavelength: VSWR: Peak Gain: Impedance: Connection: Oper. Temp. Range: 418MHz 393–443MHz ¼-wave ≤ 2.0 typical at center 1.7dBi 50-ohms Surface-mount –40°C to +80°C 7.62 mm (0.30") 12.70 mm (0.50") Electrical specifications and plots measured on a 7.62 cm x 19.05 cm (3.00" x 7.50") reference ground plane 50-ohm microstrip line Ordering Information 3.81 mm (0.15") Ground plane on bottom layer for counterpoise. ANT-418-HESM (helical, surface mount) –1– Revised 5/16/16 Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plane relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. VSWR Graph VSWR 3:1 Reflected Power 25% 1.429 2:1 1:1 318MHz 11% 0% 518MHz 418MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com –2– Data Sheet ANT-418-HESM by
ANT-418-HESM 价格&库存
很抱歉,暂时无法提供与“ANT-418-HESM”相匹配的价格&库存,您可以联系我们找货
