Specification
Part No.
: SP.1615.25.4.A.02
Product
: Globalstar 25mm 1615Mhz
Name
Features
Embedded Ceramic Patch Antenna
: 25mm*25mm*4mm
Globalstar Approved
Pin Mount
LHCP
CE Certified
RoHS Compliant
SPE-14-8-104/D/SS
Page 1 of 16
1. Introduction
This miniaturized 25mm square ceramic patch antenna is mounted via pin and
double-sided adhesive and is the optimal embedded antenna solution for
mobile Globalstar applications.
The antenna is tuned to a reference 60mm square ground-plane. With an
efficiency of nearly 80% at 1615 MHz, the antenna exhibits excellent upper
hemisphere radiation pattern stability. Axial ratio is less than 3 on antenna
operational angles, with a minimum axial ratio of 0.54 at zenith. The
SP.1615.25.4.A.02 gain and directivity characteristics have been analyzed and
approved by Globalstar.
Different device ground-planes and housing environments may require a
custom tuned antenna. Taoglas provides testing and support services to
characterize this antenna in your device and determine whether a custom
tuned solution is necessary. There is a minimum order quantity and possible
NRE for a custom solution. Contact your regional Taoglas office for support.
SPE-14-8-104/D/SS
Page 2 of 16
2. Specification Table
Parameter
Range Of Receiving
Frequency
Specification
Notes
1615.68 ± 4.1 MHz
Center Frequency
1615 MHz ± 3 MHz
With 60×60mm GND Plane
Bandwidth
26 MHz min
Return Loss@-10 dB
VSWR
1.5 max
Center Frequency
Peak Gain
5 dBi
Polarization
LHCP
Axial Ratio
3 Max. @ Zenith
Impedance
50 Ohm
Weight
5g
Frequency Temperature
Coefficient(τf)
Operating Temperature
-40°C to +105°C
Left Hand Circular
Polarization
0± 20ppm / °C
-40°C to +105°C
SPE-14-8-104/D/SS
Page 3 of 16
3. Electrical Specifications
3.1 Return Loss
SPE-14-8-104/D/SS
Page 4 of 16
3.2 Smith Chart
SPE-14-8-104/D/SS
Page 5 of 16
3.3 VSWR
SPE-14-8-104/D/SS
Page 6 of 16
3.4 Efficiency
3.5 Peak Gain
SPE-14-8-104/D/SS
Page 7 of 16
3.6 Radiation Pattern
The antenna was test in a ceritified ETS Anochoic Chamber, the setup is as
below,
Y
X
Z
SPE-14-8-104/D/SS
Page 8 of 16
3.4.1 XZ-Plane
Z
X
3.4.2 YZ-Plane
Z
Y
3.4.3 XY-Plane
X
Y
SPE-14-8-104/D/SS
Page 9 of 16
3.5 Axial Ratio
SPE-14-8-104/D/SS
Page 10 of 16
4. Mechanical Drawing
4.1 Antenna
SPE-14-8-104/D/SS
Page 11 of 16
4.2 SPD.25A Evaluation Board
SPE-14-8-104/D/SS
Page 12 of 16
4.3 PCB Footprint Recommendation
SPE-14-8-104/D/SS
Page 13 of 16
5. Packaging
50 pieces per tray
200 pieces per inner carton
800 pieces per outer carton
SPE-14-8-104/D/SS
Page 14 of 16
SPE-14-8-104/D/SS
Page 15 of 16
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice. Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-104/D/SS
Page 16 of 16
很抱歉,暂时无法提供与“SP.1615.25.4.A.02”相匹配的价格&库存,您可以联系我们找货
