ANT-868-WRT-RPS
ANT-868-WRT-RPS
    LINXTECHNOLOGIES(灵思)
    ANT-868-WRT 是一种低剖面、面板安装的偶极子天线,专为低功耗广域网(LPWA)应用设计,包括 LoRaWAN 和 Sigfox,远程控制和 ISM 波段应用。
ANT-868-WRT-RPS 数据手册
ANT-868-WRT-xxx Data Sheet by Product Description 19.0 mm (0.75") The WRT Series antenna is ideally suited for applications such as wireless vending, security, traffic, or power equipment which require an unobtrusive, tamper-resistant antenna solution. The tiny 19 x 11 mm radome installs through a small hole on the product and is anchored by a threaded base. An adhesive foam compression ring is used to resist the elements. The ½-wave antenna also features an integral counterpoise, which eliminates the need for a proximity ground plane. The antenna is suited for mounting in applications where the counterpoise will not be shielded from the antenna (non-conductive or open metal enclosures); installation where the counterpoise is within a shielded enclosure will affect the antenna performance. The antenna’s coax feed is available with SMA, RP-SMA, or a U.FL / MHF compatible connector. U.FL and I-PEX MHF connector standards are compatible with each other. Alternate coax lengths, connectors and custom colors are available for volume OEM customers. Adhesive Ring 11.0 mm (0.43") Remove protective plastic before installation SMA or or RP-SMA 6.0 mm (0.24") U.FL M11x1.0 mm Thread i-PEX silouette shown in shadow 85.0 mm (3.35") 5.26 mm (0.207") Features • • • • • • Low cost Unobtrusive Tamper resistant Integral counterpoise Indoor / outdoor Adhesive or permanent mount RG-174 Cable Length 216.0 mm (8.50”) Ordering Information ANT-868-WRT-RPS (with RP-SMA connector) ANT-868-WRT-SMA (with SMA connector) ANT-868-WRT-UFL (with U.FL / MHF compatible connector) Electrical Specifications Center Frequency: 868MHz Recom. Freq. Range: 855–880MHz Wavelength: ½-wave VSWR: ≤ 1.9 typical at center Peak Gain: 1.5dBi Impedance: 50-ohms Oper. Temp. Range: –40° to +90°C Connector: RP-SMA, SMA or U.FL / MHF Cable: RG-174 RP-SMA & SMA 1.32 mm U.FL Max. Recom. Torque: 4.0 kgf-cm Electrical specifications and plots measured on 10.16 cm x 10.16 cm (4.00” x 4.00”) reference ground plane –1– Revised 12/9/13 VSWR Graph VSWR 3:1 1.141 2:1 1:1 768MHz Reflected Power 25% 11% 0% 968MHz 868MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match will have a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this will be different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. –2– Data Sheet ANT-868-WRT-xxx by
ANT-868-WRT-RPS 价格&库存
很抱歉,暂时无法提供与“ANT-868-WRT-RPS”相匹配的价格&库存,您可以联系我们找货
