SPECIFICATION
Part No.
FXP29.07.0070A
Product Name
2100MHz 3G UMTS/HSPA+ Band
Flexible PCB Antenna
Features
1920-2170MHz Operation
Ground Plane Independent
1.5 dBi Peak Gain
12.7*8.4*0.24 mm Tiny dimension
IPEX MHFI (U.FL Compatible)
RoHS Compliant
Photo:
SPE-14-8-030/B/PK
Page 1 of 13
1. Introduction
The FXP29 is a unique super small monopole ultra-low profile antenna for
the 2100MHz 3G UMTS/ HSPA+ application band. The FXP29 antenna has
peak gain of 1.5dBi and efficiencies of 45%.
It is made from poly-flexible material, has a tiny form factor
(12.7mm*8.4mm*0.24mm) and has double-sided 3M tape for easy “peel
and stick” mounting onto the inner plastic housing of a device. It is an
ideal solution for compact M2M devices which require 3G functionality at
the 2100MHz band.
The cables length and connector are customizable. The standard length is
70mm and is recommended, some detuning and efficiency decrease is
observed on other cable lengths, see chart below for details.
SPE-14-8-030/B/PK
Page 2 of 13
2. Specification
ELECTRICAL
2100MHz UMTS/HSPA
Frequency (MHz)
1920~2170
Max Return Loss (dB)
-10
Peak Gain (dBi)
1.5
Efficiency (%)
45
Average Gain (dB)
-3.5
Radiation Properties
Omni-directional
Max Input Power (Watts)
5
Polarization
Linear
Impedance (Ohms)
50 Ohms
MECHANICAL
Dimensions (mm)
12.7*8.4*0.24 mm
Material
Flexible Polymer
Connector and Cable
IPEX MHF1 (U.FL) and 1.13 mm mini coax.
Weight(1pc)
0.42g
ENVIRONMENTAL RATINGS
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 85°C
Relative Humidity
40% to 95%
RoHs Compliant
Yes
*All results were measured with 70mm length 1.13mm coaxial cable and on 2mm
thickness ABS base.
SPE-14-8-030/B/PK
Page 3 of 13
3. Antenna Characteristics
3.1 Return Loss
3.2 Peak Gain
SPE-14-8-030/B/PK
Page 4 of 13
3.3 Efficiency
3.5 Average Gain
SPE-14-8-030/B/PK
Page 5 of 13
4. Antenna Radiation Patterns
4.1 Antenna setup
The antenna radiation pattern measured setup as shown the below,
Y
X
Z
SPE-14-8-030/B/PK
Page 6 of 13
4.2 Antenna radiation patterns
XY-Plane
X
Y
XZ-Plane
Z
X
SPE-14-8-030/B/PK
Page 7 of 13
YZ-Plane
Z
Y
SPE-14-8-030/B/PK
Page 8 of 13
5. DRAWING
SPE-14-8-030/B/PK
Page 9 of 13
6. Application Note
The FXP.29 antenna measured with difference cable length on plastic plate of 3 mm
thickness, the performance is shown as below,
Return loss
Efficiency
SPE-14-8-030/B/PK
Page 10 of 13
Average Gain
Peak Gain
SPE-14-8-030/B/PK
Page 11 of 13
7. Packaging
100pcs antenna per small PE Bag
Weight 100 pcs: 0.45Kg
SPE-14-8-030/B/PK
Page 12 of 13
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-030/B/PK
Page 13 of 13
很抱歉,暂时无法提供与“FXP29.07.0070A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+54.835101+7.12691
- 国内价格
- 15+30.90461
- 85+27.25312
- 100+25.41529
- 国内价格
- 16+47.28914
- 85+37.45521
- 100+34.90389
