TG.30.8112
TG.30.8112
    TAOGLASLIMITED
    TG.30.8112
TG.30.8112 数据手册
Apex Right Angle TG.30 Part No: TG.30.8112 Features: 600-6000MHz Covers 5G/4G Bands Typical 50%+ Efficiency and 3dBi+ Peak Gain Dipole Terminal Antenna 90° termination with SMA(M) Connector RoHS and REACH Compliant SPE-12-8-120-I 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 7 4. Radiation Patterns 9 5. Mechanical Drawing 75 6. Packaging 76 Changelog 77 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-120-I www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Apex TG.30 is a Wideband Dipole 5G/4G Antenna – is primarily designed for use with 5G/4G modules, routers and devices that require the highest possible efficiency and peak gain to deliver best in class throughput on all major cellular bands worldwide between 600MHz and 6GHz. Introduction 1. This fixed 90 degree, connector mount, dipole antenna is primarily designed for use with 5G/4G modules and devices that require the highest possible efficiency and peak gain in order to deliver best-in-class throughput. 1. Typical Applications include: - Routers and Gateways - Access Points - Remote Monitoring 1. With very high efficiency on every cellular band globally it is an ideal solution for any device requiring high, reliable performance. It is also guaranteed to meet any type approval or carrier certification requirements from a RF standpoint. Introduction Introduction Introduction This patented antenna is available in White and Black versions. It is also available with with swivel 90 degrees and straight connectors. For further information please contact your regional Taoglas customer support team. SPE-12-8-120-I www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Band 3. 617~960 Band 1,2,3,4,9,23,25,35,39,66 Peak Gain (dB) (dBi) Freespace 57 -2.8 2.6 Edge_30X30cm_GP 53 -3.1 2.8 Centre_30X30cm_GP 19 -7.7 1.4 Freespace 50 -3.3 5.6 1427~1518 1710~2200 Edge_30X30cm_GP 66 -2.0 2.5 Centre_30X30cm_GP 67 -2.0 7.2 Freespace 80 -1.0 4.3 30X30cm_GP 66 -1.8 3.0 Centre_30X30cm_GP 64 -1.9 7.8 68 -1.7 4.2 62 -2.1 3.9 Centre_30X30cm_GP 31 -5.1 3.1 Freespace 69 -1.6 4.4 Edge_30X30cm_GP 50 -2.9 4.6 Centre_30X30cm_GP 56 -2.7 7.1 Freespace 63 -2.2 6.5 Edge_30X30cm_GP 48 -3.7 5.5 Specifications Freespace Antenna Characteristics2. Wi-Fi 2400 4G/3G Band 7,38,41 2400~2500 Edge_30X30cm_GP Antenna Characteristics 5GNR/4G Band 22,42,43,48,77,78 4. Average Gain Antenna Radiation Patterns3.Antenna Characteristics2. 4G/3G 3. (%) Antenna Characteristics 5GNR/4G Band 21,32,74,75,76 3. Efficiency Frequency (MHz) 5GNR/4G Band 5,8,12,13,14,17,18,20, 26,27,28, 29,71 4. Specifications 5G/4G Elecrical 2490~2690 3300~3800 Specifications Antenna Radiation Patterns3.Antenna Characteristics LTE5200/ Wi-Fi 5800 5150~5925 Centre_30X30cm_GP 43 -4.2 6.8 Freespace 66 -1.9 5.7 Edge_30X30cm_GP 42 -3.9 4.7 Centre_30X30cm_GP 35 -4.9 7.1 VSWR Impedance Polarization 3 Max 50Ω Linear Mechanical 4. 4. Casing Antenna Radiation Patterns UV Resistant PC/ABS Flammability Rating UL-94 Connector SMA Male Antenna Radiation Patterns3.Antenna Environmental Characteristics Temperature Range -40°C to 85°C Humidity 4. Non-condensing 65°C 95% RH Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-120-I Specifications www.taoglas.com 4 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 78 3300 to 3800 4400 to 5000 79 85 SPE-12-8-120-I 698-716 728-746 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ www.taoglas.com 5 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 0 -5 -10 Antenna Radiation Patterns -15 Return Loss [dB] 4. 4. -20 -25 Antenna Radiation Patterns3.Antenna -30 -35 Characteristics -40 -45 600 4. 1200 Characteristics 3.2 4. 1800 2400 3000 3600 Antenna Radiation Patterns3. Antenna Frequency [MHz] Freespace 4200 Edge_30X30cm_GP 4800 5400 6000 Centre_30X30cm_GP Efficiency 100 Antenna Radiation Patterns 90 80 70 4. Antenna Radiation Patterns 60 Efficiency [%] 4. 50 40 30 Antenna Radiation Patterns 20 10 4. 0 Antenna Patterns3. Antenna 600 Radiation 1200 1800 2400 3000 3600 Freespace Edge_30X30cm_GP Antenna Radiation Patterns3.Antenna SPE-12-8-120-I 4800 5400 6000 Frequency [MHz] Characteristics 4. 4200 Centre_30X30cm_GP www.taoglas.com 6 3.3 Average Gain 4 Aver Gain [dB] 2 0 -2 -4 -6 -8 -10 600 1200 1800 2400 3000 3600 4200 4800 5400 6000 Frequency [MHz] Freespace 3.4 Edge_30X30cm_GP Centre_30X30cm_GP Peak Gain 8 6 4 Gain [dBi] 2 0 -2 -4 -6 -8 600 1200 1800 2400 3000 3600 4200 4800 5400 6000 Frequency [MHz] Freespace SPE-12-8-120-I Edge_30X30cm_GP Centre_30X30cm_GP www.taoglas.com 7 4. Radiation Patterns 4. 4. 4. 4.1 Antenna Radiation Patterns Test Setup – Freespace Antenna Radiation Patterns Y 4. Antenna Radiation Patterns X 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-12-8-120-I Z www.taoglas.com 8 4.2 650MHz _Freespace 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 9 750MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 10 890MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 11 1470MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 12 1805MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 13 1920MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 14 1990MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 15 2595MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 16 3550MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 17 5530MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 18 4.3 Test Setup –Edge_30X30cm_Ground plane Y Z SPE-12-8-120-I X www.taoglas.com 19 4.4 650MHz - Edge_30X30cm_Ground plane 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 20 750MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 21 890MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 22 1470MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 23 1805MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 24 1920MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 25 1990MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 26 2595MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 27 3550MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 28 5530MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 29 4.5 Test Setup – Centre_30X30cm_Ground plane Y Z SPE-12-8-120-I X www.taoglas.com 30 4.6 650MHz – Centre_30X30cm_Ground plane 2D & 3D Radiation Patterns 3D and 2D Radiation Patterns XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 31 750MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 32 890MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 33 1470MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 34 1805MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 35 1920MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 36 1990MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 37 2595MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 38 3550MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 39 5530MHz XY Plane SPE-12-8-120-I XZ Plane YZ Plane www.taoglas.com 40 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-120-I Mechanical Drawing www.taoglas.com 41 8. 6. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-120-I Mechanical Drawing www.taoglas.com 42 Changelog for the datasheet SPE-12-8-120 - TG.30.8112 Revision: I (Current Version) Date: Changes: Changes Made by: 2022-09-26 Updated specifications Cesar Sousa Previous Revisions Revision: C Revision: H Date: Changes: Changes Made by: 2022-05-05 Full datasheet template update and show data 600-6000. Gary West Revision: G Date: Changes: Changes Made by: 2012-10-04 Technical Writer Revision: B Date: Changes: Changes Made by: 2021-07-09 Added IP Rating Gary West Revision: F Date: Changes: Changes Made by: Date: 2012-09-27 Changes: Changes Made by: Technical Writer Revision: A (Original First Release) 2018-11-30 Removed IP rating Jack Conroy Date: Notes: Author: 2012-09-19 Technical Writer Revision: E Date: Changes: Changes Made by: 2015-03-30 Updated Spec with LTE table Andy Mahoney Revision: D Date: Changes: Changes Made by: SPE-12-8-120-I 2017-01-13 Technical Writer www.taoglas.com 43 www.taoglas.com © Taoglas SPE-12-8-120-I www.taoglas.com 44
TG.30.8112 价格&库存
很抱歉,暂时无法提供与“TG.30.8112”相匹配的价格&库存,您可以联系我们找货
