ANT-916-WRT-SMA
ANT-916-WRT-SMA
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    ANT-916-WRT 是一种低剖面、面板安装的偶极子天线,适用于低功耗广域 (LPWA) 应用,包括 LoRaWAN、远程控制和 ISM 波段应用(902 MHz 至 930 MHz 范围)。
ANT-916-WRT-SMA 数据手册
Datasheet ANT-916-WRT-ccc 915 MHz External Panel-Mount Antenna The ANT-916-WRT is a low-profile, panel-mount dipole antenna designed for low-power, wide-area (LPWA) applications including LoRaWAN®, remote controls, and ISM band applications in the 902 MHz to 930 MHz range. The ANT-916-WRT antenna’s compact size allows it to be mounted in applications requiring a low profile and external antenna performance, such as wireless vending and traffic control equipment. The ANT-916-WRT antenna is designed with an integrated counterpoise that eliminates the need for additional ground plane in the product, making it ideal for applications with non-conductive or RF transparent enclosures. Connector options for the ANT-916-WRT antenna are: SMA plug (male pin), RP-SMA plug (female socket) or MHF1/U.FL-type plug (female socket). ANT-916-WRT-SMA Shown Features Applications • Performance at 915 MHz ― VSWR: ≤ 1.5 ― Peak Gain: 4.4 dBi ― Efficiency: 50% • Low-profile ― Height: 10.0 mm (0.40 in) ― Diameter: 19.0 mm (0.75 in) • Mounts permanently with pressure sensitive adhesive ring and provided nut • Low-power, wide-area (LPWA) applications ― LoRaWAN®, ITU-T Y.4480 • ISM applications • Remote control, sensing and monitoring ― Security systems ― Industrial machinery ― Automated equipment ― AMR (automated meter reading) • Internet of Things (IoT) devices • Smart Home networking Ordering Information Part Number ANT-916-WRT-UFL-150 ANT-916-WRT-UFL ANT-916-WRT-UFL-300 ANT-916-WRT-RPS ANT-916-WRT-SMA ANT-916-WRT-SMA-300 Description Antenna, 150 mm (5.91 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket) Antenna, 216 mm (8.50 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket) Antenna, 300 mm (11.81 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket) Antenna, 216 mm (8.50 in) of RG-174 coaxial cable, RP-SMA plug (female socket) Antenna, 216 mm (8.50 in) of RG-174 coaxial cable, SMA plug (male pin) Antenna, 300 mm (11.81 in) of RG-174 coaxial cable, SMA plug (male pin) Available from Linx Technologies and select distributors and representatives. WRT Series ANT-916-WRT-ccc Datasheet Table 1.   Electrical Specifications ANT-916-WRT 915 MHz 902 MHz to 930 MHz Frequency Range VSWR (max) 1.5 Peak Gain (dBi) 4.4 Average Gain (dBi) -3.2 50 Efficiency (%) Polarization Linear Radiation Impedance 50 Ω Max Power Wavelength 1/2-wave Omnidirectional 5W Dipole Electrical Type Electrical specifications and plots measured with a 102 mm x 102 mm (4.0 in x 4.0 in) reference ground plane. Table 2.   Mechanical Specifications Connection Coaxial Cable, minimum inside bend radius Weight ANT-916-WRT-UFL MHF1/U.FL-type plug 1.32 mm: 6.0 mm (0.24 in) 150 mm = 6.6 g (0.23 oz) 216 mm = 6.9 g (0.24 oz) 300 mm = 7.3 g (0.26 oz) ANT-916-WRT-RPS RP-SMA plug RG-174: 10.2 mm (0.40 in) 216 mm = 12.5 g (0.44 oz) ANT-916-WRT-SMA SMA plug RG-174: 10.2 mm (0.40 in) 216 mm = 12.5 g (0.44 oz) 300 mm = 13.5 g (0.48 oz) Model -40 °C to +90 °C Operating Temp. Range Height: 10.0 mm (0.40 in), Diameter: 19.0 mm (0.75 in) Dimensions Packaging Information The ANT-916-WRT antenna is placed in a clear plastic sleeve and sealed in clear plastic bags in quantities of 50 pcs. Bags are packaged in cartons of 250 (5 bags). Distribution channels may offer alternative packaging options. Product Dimensions Figure 1 provides dimensions for the ANT-916-WRT antenna. Adhesive Ring 8-sided plastic nut and mounting shaft M11 x 1.0 mm Ø5.3 mm (0.21 in) Counterpoise Ø19.0 mm (0.75 in) -SMA, -RPS -MHF1/U.FL 8.0 mm (0.32 in) 82.5 mm (3.25 in) See Ordering Information for cable length and termination options Figure 1.  ANT-916-WRT Antenna Dimensions 916 MHz 2 10.0 mm (0.39 in) WRT Series ANT-916-WRT-ccc Datasheet 8-sid Recommended Mounting Recommended The recommended enclosure mounting dimensions areMounting shown in Figure 2. The ANT-916-WRT series antenna is supplied with an integrated closed-cell pressure sensitive adhesive ring which-SMA, helps-RPS seal enclosures against external elements. The adhesive ring has a protective plastic backing that must be removed prior to installation. A pull tab has been provided for easy removal of the protective backing. The antenna can be permanently mounted using the provided nut which should be tightened-MHF1/-U.FL to 4.0 kgf/cm (5 in/ lbs) max. The recommended maximum enclosure wall thickness is 4.70 mm (0.188 in). -MHF4 Ø10.8 mm (0.43 in) See Or cable leng Figure 2.  ANT-916-WRT Series Antenna Recommended Enclosure Mounting Dimensions Antenna Orientation The ANT-916-WRT series antenna is characterized in two antenna orientations as shown in Figure 3. The antenna in free space characterizes use of an antenna attached to an enclosure-mounted connector which is connected by cable to a printed circuit board. Although the antenna is a dipole not requiring a ground plane for function, characterization with an adjacent ground plane (102 mm x 102 mm) provides insight into antenna performance when attached directly to a printed circuit board mounted connector. The two orientations represent the most common end-product use cases. Free Space Ø5.3 Co Center of Ground Plane Figure 3.  ANT-916-WRT Test Orientations 3 WRT Series ANT-916-WRT-ccc Datasheet Free Space, No Ground Plane The charts on the following pages represent data taken with the antenna oriented in free space without a ground plane, as shown in Figure 4. Figure 4.  ANT-916-WRT in Free Space, No Ground Plane VSWR 5 930 902 Figure 5 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 10 1 0 900 905 910 915 920 Frequency (MHz) 925 Figure 5.  ANT-916-WRT VSWR, Free Space 4 930 935 Reflected Power (%) 40 WRT Series ANT-916-WRT-ccc Datasheet Return Loss 0 930 902 Return loss (Figure 6), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. -2 Return Loss (dB) -4 -6 -8 -10 -12 -14 -16 -18 -20 900 905 910 915 920 Frequency (MHz) 925 930 935 Figure 6.  ANT-916-WRT Return Loss, Free Space Peak Gain 5 930 902 The peak gain across the antenna bandwidth is shown in Figure 7. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 0 -5 -10 -15 -20 900 905 910 915 920 Frequency (MHz) 925 930 935 Figure 7.  ANT-916-WRT Peak Gain, Free Space 5 WRT Series ANT-916-WRT-ccc Datasheet Average Gain 5 930 902 Average gain (Figure 8), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. Average Gain (dBi) 0 -5 -10 -15 -20 900 905 910 915 920 Frequency (MHz) 925 930 935 Figure 8.  ANT-916-WRT Antenna Average Gain, Free Space Radiation Efficiency 100 930 902 Radiation efficiency (Figure 9), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 900 905 910 915 920 Frequency (MHz) 925 Figure 9.  ANT-916-WRT Antenna Radiation Efficiency, Free Space 6 930 935 WRT Series ANT-916-WRT-ccc Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are shown in Figure 10 using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. Radiation Patterns - Free Space XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 902 MHz to 930 MHz (915 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 XZ-Plane Gain 17 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 17 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 5 6 7 8 9 10 11 26 12 25 13 24 14 23 15 22 21 YZ-Plane Gain 20 19 18 17 16 902 MHz 915 MHz 930 MHz XY-Plane Gain Figure 10.  ANT-916-WRT Radiation Patterns, Free Space 7 WRT Series ANT-916-WRT-ccc Datasheet Center of Ground Plane The charts on the following pages represent data taken with the antenna oriented at the center of the ground plane, as shown in Figure 11. Figure 11.  ANT-868-WRT at Center of Ground Plane VSWR 5 930 902 Figure 12 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 1 10 900 905 910 915 920 Frequency (MHz) 925 Figure 12.  ANT-916-WRT VSWR, Center of Ground Plane 8 930 935 0 Reflected Power (%) 40 WRT Series ANT-916-WRT-ccc Datasheet Return Loss 0 930 902 Return loss (Figure 13), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. Return Loss (dB) -5 -10 -15 -20 -25 900 905 910 915 920 Frequency (MHz) 925 930 935 Figure 13.  ANT-916-WRT Return Loss, Center of Ground Plane Peak Gain 5 930 902 The peak gain across the antenna bandwidth is shown in Figure 14. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 0 -5 -10 -15 -20 900 905 910 915 920 Frequency (MHz) 925 930 935 Figure 14.  ANT-916-WRT Peak Gain, Center of Ground Plane 9 WRT Series ANT-916-WRT-ccc Datasheet Average Gain 5 930 902 Average gain (Figure 15), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. Average Gain (dBi) 0 -5 -10 -15 -20 900 905 910 915 920 Frequency (MHz) 925 930 935 Figure 15.  ANT-916-WRT Antenna Average Gain, Center of Ground Plane Radiation Efficiency 100 930 902 Radiation efficiency (Figure 16), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 900 905 910 915 920 Frequency (MHz) 925 930 Figure 16.  ANT-916-WRT Antenna Radiation Efficiency, Center of Ground Plane 10 935 WRT Series ANT-916-WRT-ccc Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are shown in Figure 17 using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. Radiation Patterns - Center of Ground Plane XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 902 MHz to 930 MHz (915 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 XZ-Plane Gain 17 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 17 YZ-Plane Gain 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 5 6 7 8 9 10 11 26 12 13 25 24 14 23 15 22 21 20 19 18 17 16 902 MHz 930 MHz 930 MHz XY-Plane Gain Figure 17.  ANT-916-WRT Radiation Patterns, Center of Ground Plane 11 WRT Series ANT-916-WRT-ccc Datasheet Website: http://linxtechnologies.com Linx Offices: 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 (541) 471-6256 E-MAIL: info@linxtechnologies.com Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their respective owners. Copyright © 2022 Linx Technologies All Rights Reserved Doc# DS22070-196ANT (Replaces DS21336-196ANT)
ANT-916-WRT-SMA 价格&库存
很抱歉,暂时无法提供与“ANT-916-WRT-SMA”相匹配的价格&库存,您可以联系我们找货
