Specification
Part No.
PC27.09.0100A
Product Name
TheStripe™
850 / 900 / 1800 / 1900MHz GSM PCB Antenna
W/100mm 1.13 Coaxial Cable MMCX (M) R/A
Connector
Feature
100mm long, 1.13 mm diameter
Miniature Co-Axial Cable MMCX(M)RA
Dims: 34mm*7mm*0.8mm
RoHS Compliant
SPE-11-8-152/A
Page 1 of 9
1. Introduction
This miniaturized low profile PCB antenna is based on smart TheStripe™ antenna
technology. It consists of a PCB antenna and 1.13mm coaxial cable with MMCX(M) 90
degree connector.
Further optimization can be done upon receipt of the client’s device at a local Taoglas
facility.
2. Specifications
CELLULAR
Communication system
AMPS
GSM
DCS
PCS
Frequency Band
800MHz
900MHz
1800MHz
1900MHz
VSWR
3.59
2.02
2.21
2.3
Return Loss
-4.96 dB
-9.48 dB
-8.46 dB
-8.06 dB
Efficiency
56.84%
72.98%
63.52%
55.79%
Peak Gain
0.01dBi
1.2dBi
2.66dBi
1.25dBi
Average Gain
-2.45dB
- 1.37dB
- 1.97dB
-2.53dB
Impedance
50 Ohm
Radiation Pattern
Omnidirectional
Polarization
Horizontal
MECHANCIAL
Dimensions
RF Cable
RF Connector
34 * 7 * 0.8mm
RF Coaxial Cable ψ1.13 ± 0.1mm, L = 100 mm
Gray Color
MMCX(M)RA
ENVIRONMENTAL
Operation Temperature
-20°C to + 55°C
Storage Temperature
-30°C to + 75°C
Relative Humidity
40% to 95%
SPE-11-8-152/A
Page 2 of 9
3. Antenna Characteristics
3.1. Return loss
SPE-11-8-152/A
Page 3 of 9
3.2. VSWR
SPE-11-8-152/A
Page 4 of 9
4. Reliability
Test Items
Procedure
Requirement
Thermal Shock
Starting at -40 for 30 minutes and then
cycled to +85 to remain 30 minutes
(a complete cycle).
To repeat 5 complete cycles.
(Refer to IEC 68-2-14 Method Na)
1. The value of return loss
must be within product
specifications after this test.
2. No physical deformation
should be evident.
Storage
Temperature
(Cold)
Samples must be put into -30°C chamber
for 72 hours and samples shall be powered
during test.
(Refer to IEC 68-2-1 Method Aa)
1. The value of return loss must
be within product
should be evident.
Storage
Temperature
(Dry Heat)
Samples must be put into +75°C chamber
during test.
(Refer to IEC 68-2-1 Method Ba)
be within product
should be evident.
Operating
Temperature
(Cold)
Samples must be put into -20°C chamber
for 2 hours and samples shall be powered
during test.
met specification during
test/after test
2. No mechanical defects after
test.
Operating
Temperature
(Dry Heat)
Samples must be put into +65°C chamber
during test.
test/after test
test.
SPE-11-8-152/A
Page 5 of 9
5. Antenna Test Procedures and Setup
5.1. 3D Radiation Pattern Testing
Test Setup Diagram
SPE-11-8-152/A
Page 6 of 9
5.2. 3D Radiation Pattern Testing
850 MHz
1800 MHz
900 MHz
1900 MHz
SPE-11-8-152/A
Page 7 of 9
5.3. 3D Chamber Testing – Tabular Results
SPE-11-8-152/A
Page 8 of 9
6. Mechanical Drawings (Unit: mm)
6.1. Dimensions and Drawing
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or
disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-152/A
Page 9 of 9
很抱歉,暂时无法提供与“PC27.09.0100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 15+57.43226
- 55+54.68761
- 250+52.11222
- 550+49.87539
- 1600+47.81992
- 国内价格
- 10+77.24612
- 55+66.25032
