33-1010-05-0150
33-1010-05-0150
    TALLYSMANWIRELESS
33-1010-05-0150 数据手册
TW1010/TW1012 Embedded GPS L1 Antenna The TW1010/TW1012 is low cost, high gain, high performance, embedded GPS L1 antenna, specially designed for OEM industrial, military, precision positioning and timing applications. The TW1010/TW1012 features a precisely tuned single feed ceramic patch element. It has a two stage Low Noise Amplifier (LNA) with a mid-section SAW. An optional tight pre-filter is available with part number TW1012 to protect against saturation by high level sub-harmonics and L-Band signals. The TW1010/TW1012 covers the GPS L1 and SBAS (WAAS /EGNOS/MSAS) frequency band (1572.5 to 1578 MHz), and it offers great circular polarized signal reception, multipath rejection and out of band signal rejection. TW1010/TW1012 Dimensions with RG174 cable (mm) The TW1010/TW1012 has a built-in 35mm circular ground plane that can be augmented with host system ground surfaces. Patch Elements are susceptible to detuning by the local environment. Tallysman offers custom services to assist with integration of OEM modules into an end user solution. Custom cable lengths and connectors are available. Applications • • • • • • High Accuracy & Mission Critical GPS Precision Agriculture, Mining & Construction Military & Security Avionics Law Enforcement & Public Safety Fleet Management & Asset Tracking Features • • • • • • • Very low noise LNA: 1 dB (TW1010). Great axial ratio: SAW filter-> LNA stage 2 SAW Prefilter ->LNA stage 1 -> SAW filter-> LNA stage 2 26dB min., TW1010; 24dB min, TW1012, 1575.42MHz +/- 10MHz TW1010: 35dB. TW1012: >70dB. TW1010: 25dB. TW1012: >55dB. TW1010: >1650MHz >35dB. TW1012: >65dB.
33-1010-05-0150 价格&库存
很抱歉,暂时无法提供与“33-1010-05-0150”相匹配的价格&库存,您可以联系我们找货
