FXP400.07.0100A
FXP400.07.0100A
    TAOGLASLIMITED
    FXP400.07.0100A
FXP400.07.0100A 数据手册
Specification Model No. : FXP.400 Part No. : FXP.400.07.0100A Product Name : High Efficiency Ultra Wide-Band Antenna with 100mm Ø1.13 cable IPEX MHF(U.FL) Features : High efficiency and ultra wide band Cover all LTE operation frequencies 100*38*0.1mm International Patent #: US 2009/0189825 A1 RoHS  REVISION STATUS Version Date Page Revision Description Prepared Approved 01 23 September 2009 All New release Giuseppe RuvioAHFR Dermot O'Shea 02 12 March 2010 All Update 3D Chamber result Zita Lin Dermot O’Shea © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Enniscorthy, Co. Wexford, Ireland info@taoglas.com +353 53 9169500 www.taoglas.com 1.0 Introduction This flexible wideband ultra wide band antenna has been designed by using DIT Antenna High Frequency and Research Centre patented antenna design methodology in Dublin, Ireland. Taoglas and DIT have developed this range of solutions following years of expertise and collaboration in design of high performance ultra wide band antennas for wireless devices. LTE system antenna (100x38x0.1mm) Taoglas have designed an ultra wideband antenna solution for global LTE “4G” systems. The bands are 690 MHz – 940 MHz and 1720 MHz – 3130 MHz. The antenna is delivered on flexible circuit material which is ideal for the radiation patterns of antennas with higher frequencies and wider bandwidth. The efficiencies of the antenna are over 70% across the bands. This material allows the antenna to be placed on the edge of a PCB and folded over the PCB or folded upwards and adhered to the device housing itself. The antenna is currently available with cable and connector and its own ground plane for evaluation purposes. © All Rights Reserved Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Enniscorthy, Co. Wexford, Ireland info@taoglas.com +353 53 9169500 www.taoglas.com 2.0 Specification ELECTRICAL Working Frequency 690940MHz 17203130MHz Gain 0.55~ 4dBi Polarization Linear Impedance 50 ohms Max Input Power 10 watts VSWR
FXP400.07.0100A 价格&库存
很抱歉,暂时无法提供与“FXP400.07.0100A”相匹配的价格&库存,您可以联系我们找货
