SPECIFICATION
Part No.
MA206.A.AB.004
Product Name
MA206 Stingray GPS/2.4~2.5GHz Combination
Adhesive Antenna
Features
GPS/GALILEO - High gain LNA up to 32dB
2.4~2.5GHz
Height 10.8mm Diameter 51.7mm
GPS/GALILEO - Standard 3m RG174 cable and SMA(M)
connector
2.4GHZ – Standard 3m RG174 cable and RF-SMA(M)
RoHS Compliant
SPE-12-8-111/D/CM
Page 1 of 15
MA.206.A.A301111.B301151
1. Introduction
This is a combination high performance GPS/GALILEO and 2.4~2.5GHz antenna to
simplify AVL or Fleet management antenna systems worldwide. Its high quality low
profile covert housing can be attached onto the glass or even out of sight under the
dashboard. This combination is ideal for those applications that require durability, small
size, and covert installation.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions.
In practice, the peak gain of an antenna tested in free-space can degrade by at least 1
or 2dBi when put inside a device. So ideally you should go for a slightly higher peak
gain antenna than mentioned on the module specification to compensate for this effect,
giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate
layout, integration technique, or cable, Taoglas can make sure any of our antennas’
peak gain will be below the peak gain limits. Taoglas can then issue a specification
and/or report for the selected antenna in your device that will clearly show it complying
with the peak gain limits, so you can be assured you are meeting regulatory
requirements for that module.
For example, a module manufacturer may state that the antenna must have less than
2dBi peak gain, but you don’t need to select an embedded antenna that has a peak
gain of less than 2dBi in free-space. This will give you a less optimized solution. It is
better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once
that antenna gets integrated into your device, performance will degrade below this
2dBi peak gain due to the effects of GND plane, surrounding components, and device
housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing
a Taoglas antenna with a higher peak gain than what is specified by the module
manufacturer and enlisting our help will ensure you are getting the best performance
possible without exceeding the peak gain limits.
SPE-12-8-111/D/CM
Page 2 of 15
The standard version has 3 metres RG174 cable and SMA(M) connector on
GPS/GALILEO and RP-SMA(M) on 2.4~2.5GHz. The cables and connectors are
completely customizable according to customer request.
Features
GPS/GALILEO
High LNA Gain up to 32 dB
Miniaturized to 51.7x10.8mm
Low Noise 1.5 dB max
Wi-Fi
Advanced 2.4~2.5GHz
Other
Water Resistant IP 65
Quality textured covert design. Low profile
UV resistant ABS housing
Comes with high grade 3M double sided tape for quick and easy mounting
Customizable cables and connectors
SPE-12-8-111/D/CM
Page 3 of 15
2. Specifications
Performance Specifications
Items
GPS Antenna
2.4~2.5GHz
Features
High performance GPS ceramic
patch antenna with cutting edge
low noise amplifier
2400MHz to 2500MHz
Frequency
1575.42 MHz ± 2MHz
2.4 – 2.5 GHz
28dB typ.
Gain
Gain at Zenith: -1.0 dBi min
0 dB typ.
Axial Ratio :3.0 dB max
Noise Figure
2dB max.
Polarization
RHCP
Linear
DC Power Input
2.7~3.3V
Bandwidth
10 MHz min
100 MHz
VSWR
很抱歉,暂时无法提供与“MA206.A.AB.004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+332.057171+42.96046
