SPECIFICATION
Part No. : MA710.W.A.ABI.001
Product
Name
: White Pantheon Antenna 3in1 MA.710
Screw-Mount (Permanent Mount)
2 x 2G/3G/4G LTE MIMO Cellular Antenna
1 x GPS/GLONASS Antenna
Feature
: ● 2 x Cellular 2G/3G/4G Antennas (MIMO)
LTE/HSPA/GSM/GPRS/CDMA/UMTS
698~960MHz/1710~2170MHz/2300~2700MHz/2900-3500MHz
● 1 x GPS/GLONASS 1575.42/1602MHz Active Antenna
IP67 Waterproof
High Efficiency / Peak Gain Outdoor Antenna
RoHS Compliant
SPE-14-8-011/B/SS
Page 1 of 19
1. Introduction
The MA710 Pantheon antenna is an omnidirectional heavy-duty, fully IP67 waterproof
external M2M antenna for use in telematics, transportation and remote monitoring
applications. It includes two LTE MIMO antennas and one GPS/GLONASS antenna, in
the highest efficiency and peak gain possible. This antenna particularly finds its
application in mobile video, vehicle communications, location and fleet management,
safety & security, remote industrial equipment monitoring. The antenna consists of
two
LTE
MIMO
elements
698-960MHz,
1710-2170MHz,
2300~2700MHz,
2900-3500MHz. The antennas are designed to work equally well on LTE to deliver
maximum data rates, or on legacy 2G and 3G frequencies where LTE is not available.
The GNSS antenna is a wide-band GPS/GLONASS element tuned to have optimum
gain at 1575.42 MHz GPS and 1602MHz Glonass frequencies.
Mechanically, we have packed 3 high efficiency and gain antennas in an extremely
robust IP67 direct mount antenna package with excellent isolation (20dB+). The
strengthened domed housing is designed to deflect tree branches and wires that tend
to catch and break shark fin or rigid whip antennas. The Pantheon has its own internal
ground-plane and can radiate on any mounting environment such as metal or plastic
without affecting performance. The internal components are individually screwed
down onto a robust plate, preventing damage from regular vehicle vibrations. A
completely waterproof mounting seal prevents water from leaking under the housing.
The connectors and cable length are customizable. It is also available in Black
(MA710).
SPE-14-8-011/B/SS
Page 2 of 19
2. Specification Table
2G/3G/4G MIMO
Frequency
698~
787
GSM
850
824~
896
VSWR (max.)
2.5
2.5
3
2.5
2.5
2.5
3
2.5
Efficiency
66.17
51.88
47.87
39.97
47.67
45.97
28.73
38.35
Peak Gain
2.52
1.48
1.15
1.03
1.22
1.22
0.15
3.20
dBi
LTE
GSM
900
880~
960
DCS
PCS
1710~
1880
1850~1
990
WCDMA
I
1920~
2170
ISM
LTE
2400~
2500
2600~3500
MHz
MIMO 1
MIMO 2
VSWR (max.)
3.5
3.5
3.5
2.5
2.5
2.5
2
2.5
Efficiency
35.98
18.41
20.24
40.85
35.42
37.68
42.27
35.24
Peak Gain
1.56
-2.08
-2.31
1.69
0.86
2.06
2.99
2.97
dBi
Polarization
Vertical
Impedance
50
Ω
GPS-GLONASS
Centre Frequency
1575.42MHz / 1602MHz
Bandwidth
10MHz
Radiation
Efficiency
Passive Gain @
Zenith
VSWR
50 % (without cable)
4.0 dBi typ.(with ψ=140mm ground)
2
Impedance
50Ω
DC Power Input
Range
DC input
1.8V ~ 5V
1.8V
3.3V
4.0V
5.5V
MHz
1575.42
1602
1575.42
1602
1575.42
1602
1575.42
1602
VSWR
2
2
2
2
2
2
2
2
LNA Gain
17
17
29.2
29
31
31
32.3
32
Noise Figure
Power
Consumption
3.4
3.4
3.1
3.1
3.2
3.2
3.4
3.4
3.2
3.2
7.5
7.5
9.4
9.4
15
15
Band Attenuation
1535MHz: -20dB
1642MHz: -20dB
1520MHz: -20dB
1642MHz: -20dB
1520MHz: -20dB
1642MHz: -20dB
Cable
3m RG174 standard
Connector
SMA(M) standard
SPE-14-8-011/B/SS
1520MHz: -20dB
1642MHz: -20dB
Page 3 of 19
MECHANICAL
Antenna Dimensions
Height 85.7mm x Diameter 145.6mm
Casing
Wonderloy PC-540 PC/ABS Alloy
Waterproof
IP67
2G/3G/4G MIMO 1
3M Low Loss CFD-200 SMA(M)
2G/3G/4G MIMO 2
GPS/GLONASS
3M RG-174 SMA(M)
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 90°C
Humidity
Non-condensing 65°C 95% RH
* all measurements were conducted with 3m low loss CFD200 cable on cellular and
RG-174 cable on GPS/Glonass
SPE-14-8-011/B/SS
Page 4 of 19
LTE BANDS
Band Number
LTE/LTE- Advanced /WCDMA/HSPA.HSPA+
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LET only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
MIMO 1
MIMO 2
SPE-14-8-011/B/SS
Page 5 of 19
3. LTE MIMO
3.1. LTE MIMO 1 and LTE MIMO 2 Specification
3.1.1. Return Loss
LTE MIMO 1
LTE MIMO 2
3.1.2. Maximum Gain
LTE MIMO 1
LTE MIMO 2
SPE-14-8-011/B/SS
Page 6 of 19
3.1.3. Average Gain
LTE MIMO 1
LTE MIMO 2
3.1.4. Efficiency
LTE MIMO 1
LTE MIMO 2
SPE-14-8-011/B/SS
Page 7 of 19
3.2. Radiation Patterns
Y
Z
X
SPE-14-8-011/B/SS
Page 8 of 19
3.2.1. LTE MIMO 1 Radiation Pattern
XY plane
X
X
Y
Y
X
X
Y
Y
SPE-14-8-011/B/SS
Page 9 of 19
XZ Plane
Z
Z
X
X
Z
Z
Z
X
X
SPE-14-8-011/B/SS
Page 10 of 19
3.2.2. 3.2.2 LTE MIMO 2 Radiation Pattern
XY plane
X
X
Y
Y
Y
X
X
Y
Y
Y
SPE-14-8-011/B/SS
Page 11 of 19
XZ Plane
Z
Z
X
X
Z
Z
X
X
SPE-14-8-011/B/SS
Page 12 of 19
4. GPS/GLONASS
4.1. Block diagram
4.2. Return Loss
SPE-14-8-011/B/SS
Page 13 of 19
4.3. Radiation pattern
XZ-plane Free Space @1575.42MHz
SPE-14-8-011/B/SS
Page 14 of 19
YZ-plane Free Space @1575.42MHz
XZ-plane Free Space @1602MHz
SPE-14-8-011/B/SS
Page 15 of 19
YZ-plane Free Space @1602MHz
SPE-14-8-011/B/SS
Page 16 of 19
4.4 GPS/GLONASS LNA
SPE-14-8-011/B/SS
Page 17 of 19
5. Mechanical Drawing
SPE-14-8-011/B/SS
Page 18 of 19
6. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-011/B/SS
Page 19 of 19
很抱歉,暂时无法提供与“MA710.W.A.ABI.001”相匹配的价格&库存,您可以联系我们找货
